#7761 | Link | |
Pig on the wing
I have to note that I am not at all confident that the developers always know what they are doing. As mentioned earlier, the true QA people have left the building and unfortunately it shows. I'm also quite disappointed that clear bug reports are not responded at all even if the issues being corrected would benefit also commercial clients.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 8th August 2020 at 11:04. |
#7762 | Link | |
Well, it looks like I jumped to conclusions a bit too fast...
appearantly its not completely gone with rskip 1... just a lot less. So I'll try rskip 0 now... Quote:
x265.exe --crf 18 --preset veryslow --profile main10 --level-idc 4 --output-depth 10 --limit-refs 0 --psy-rdoq 1.5 --rskip-edge-threshold 4 --cu-lossless --subme 6 --merange 64 --max-merge 2 --keyint 480 --no-hdr10 --colorprim bt709 --colormatrix bt709 --transfer bt709 --range limited --deblock -2:-2 --selective-sao 0 --no-sao --high-tier --no-strong-intra-smoothing --rd-refine Just standard HD (no HDR). Will try CTU 32 and limit-tu 0 aswell. *edit: as I'm using the very slow preset as a base limit-tu was already set at 0 Last edited by K.i.N.G; 8th August 2020 at 13:26. |
#7764 | Link | |
Setting --rskip 1 with --ctu 32 seems to have fixed it. I'll have to try with some other problematic sources later to be sure. setting --rskip 2 wit a low --rskip-edge-threshold also seemed to give better results but I got tired of testing so I just went with rskip 1. Yes, its very frustrating how easily things just break apart with x265. Quite a lot of issues which I dont seem to remember having encountered with older versions of x265?! *edit: Nope, nevermind, still not fixed by adding --rskip 1 with --ctu 32, its still there in darker parts... Turning off rskip now... . Last edited by K.i.N.G; 10th August 2020 at 10:27. |
#7765 | Link | |
Pig on the wing
You are probably using the default aq-mode (2), which is worse in my opinion. It sometimes caused the ugly floating macroblocks in flat areas, and I cannot stand those so I'd test also --aq-mode 1 to make sure it's not the issue there. I also suggest removing --no-strong-intra-smoothing, there were some tests showing that the details are retained better that way.
#7767 | Link |
https://bitbucket.org/multicoreware/x265/commits/ = abandoned Mercurial repository. Obsolete.
https://bitbucket.org/multicoreware/x265_git/commits/ = current git repository. Use only now. |
#7768 | Link | |
Btw, thanks for the info. No wonder there was no updates since 30th of May. |
#7770 | Link |
It was announced half a year ago so we all could adapt in time.
#7771 | Link | |
Setting --aq-mode 1 also helps quite a bit! So now I'm testing with aq-mode 1, rskip 2 with rskip-edge-threshold 0.03 and re-enabled strong-intra-smoothing. So far its looking promessing... Thank you for these suggestions! I have several problematic sources to re-encode and that's going to take a few weeks(!). So, it will take quite some time before I can tell for sure that it fixed the issue, but its looking good so far. |
#7772 | Link | |
#7773 | Link |
https://bitbucket.org/multicoreware/x265/issues is gone and https://bitbucket.org/multicoreware/x265_git don't have an issue tracker.
#7776 | Link |
x265 v3.4+15-g45f1d01f8 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master |
#7777 | Link | |
Just my experience |
#7778 | Link | |
#7779 | Link | |
Pig on the wing
#7780 | Link | |
AMD Ryzen 9 3950X, 32GB DDR4-3200 CL16, RTX 2070, 1TB NVMe SSD, 56TB NAS |
