Old 8th September 2018, 10:36   #6341  |  Link
Ma
The bug is in commit 2.8+48 https://bitbucket.org/multicoreware/...66b1fbeb421b2c
Now it is only one function to allocate analysis_data in multilib x265 8bit+10bit+12bit -- it is from 8bit part and sse_t type is uint32_t in this function. For 10bit and 12bit sse_t type is uint64_t, so this function allocate only half required memory for distortionData if you use multilib x265 for encoding 10bit or 12bit.
Patch proposition:
diff -r 88ee12651e30 source/encoder/api.cpp
--- a/source/encoder/api.cpp	Thu Aug 16 18:27:01 2018 +0530
+++ b/source/encoder/api.cpp	Sat Sep 08 06:45:23 2018 +0200
@@ -411,13 +411,18 @@
     bool isVbv = param->rc.vbvMaxBitrate > 0 && param->rc.vbvBufferSize > 0;
     int numDir = 2; //irrespective of P or B slices set direction as 2
     uint32_t numPlanes = param->internalCsp == X265_CSP_I400 ? 1 : 3;
+#if X265_DEPTH < 10
+    int numCUs_sse_t = param->internalBitDepth > 8 ? analysis->numCUsInFrame * 2 : analysis->numCUsInFrame;
+#else
+    int numCUs_sse_t = param->internalBitDepth > 8 ? analysis->numCUsInFrame : (analysis->numCUsInFrame + 1) / 2;
+#endif
     //Allocate memory for distortionData pointer
     CHECKED_MALLOC_ZERO(distortionData, x265_analysis_distortion_data, 1);
-    CHECKED_MALLOC_ZERO(distortionData->distortion, sse_t, analysis->numPartitions * analysis->numCUsInFrame);
+    CHECKED_MALLOC_ZERO(distortionData->distortion, sse_t, analysis->numPartitions * numCUs_sse_t);
     if (param->rc.bStatRead)
-        CHECKED_MALLOC_ZERO(distortionData->ctuDistortion, sse_t, analysis->numCUsInFrame);
+        CHECKED_MALLOC_ZERO(distortionData->ctuDistortion, sse_t, numCUs_sse_t);
         CHECKED_MALLOC_ZERO(distortionData->scaledDistortion, double, analysis->numCUsInFrame);
         CHECKED_MALLOC_ZERO(distortionData->offset, double, analysis->numCUsInFrame);
         CHECKED_MALLOC_ZERO(distortionData->threshold, double, analysis->numCUsInFrame);
Test x265 Windows binary (multilib exe + patch) www.msystem.waw.pl/x265/x265-2.8+66-patched.7z
Ma is offline   Reply With Quote
Old 8th September 2018, 13:56   #6342  |  Link
K.i.N.G
I'm encoding an 4:2:2 1920x1080p 10bit video with HDR and i'm getting this error/warning:
x265 [error]: Recommended Settings for HDR: colour primaries should be BT.2020,
transfer characteristics should be SMPTE ST.2084,
matrix coeffs should be BT.2020,
the input video should be 10 bit 4:2:0
Disabling offset tuning for HDR videos
But the encoding just continues... is it safe to ignore this or should i convert the video to 4:2:0 (i'd rather not but if i really have to...)?
K.i.N.G is offline   Reply With Quote
Old 8th September 2018, 14:39   #6343  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by K.i.N.G View Post
I'm encoding an 4:2:2 1920x1080p 10bit video with HDR and i'm getting this error/warning....
4:2:0 is still the chroma sub-sampling standard for all commercially released video. No domestic hardware players supports 4:2:2.
Old 8th September 2018, 14:51   #6344  |  Link
K.i.N.G
I'm pretty sure my nvidia shield tv plays it just fine. And I'd be surprised if even the internal player of my tv couldn't handle 4:2:2 to be honest, but I cant test it right now (not at home for the whole weekend).
My concern is that I'm not sure what "disabling offset tuning for HDR videos" exactly means... Will the resulting encode still be HDR?
Old 8th September 2018, 16:42   #6345  |  Link
SeeMoreDigital
...And I'd be surprised if even the internal player of my tv couldn't handle 4:2:2 to be honest...
None of my smart TV's can. And my OPPO can't recognise such video streams placed within any supporting container!
Old 8th September 2018, 17:31   #6346  |  Link
RieGo
i agree. you won't be happy with a 4:2:2 video file. i encoded one file in 422 by accident. none of my devices could play it. plex also couldn't read it iirc. only pc could handle the file.
IMHO best thing to do would be convert your file to 4:2:0 before encoding. (or maybe it's just a problem with your source filter) you won't see a big difference and x265 won't have any problems with hdr metadata
RieGo is offline   Reply With Quote
Old 10th September 2018, 09:15   #6347  |  Link
mini-moose
Odd question maybe...
Do switches like --max-cll or --master-display have any effect on the actual video encode or are they more like flags for your HDR device?
mini-moose is offline   Reply With Quote
Old 10th September 2018, 11:17   #6348  |  Link
sneaker_ger
flags
Old 10th September 2018, 22:17   #6349  |  Link
katzenjoghurt
Hi guys,
I'm currently trying to convert Star Wars Episode III to x265... and hell... it's a beast.
This movie gives me super ugly artifacts in dark scenes.
Original: https://i.imgur.com/PA9cWuR.png
Encoding: https://i.imgur.com/HpVbyf4.png (with meagre 2,300kb/s in that scene, 4,500kb/s on avg for the whole movie)
My settings were: --crf 23 --tune grain --profile main12 --output-depth 12 --rskip --qcomp 0.8 --no-open-gop --no-deblock --no-strong-intra-smoothing
I already tried aq-mode 3 but to retain an okayish quality I had to set the aq-strength to 1.5 and ended up with 12 mbit/s for this scene.
I then tried aq-strength 3 and ended up with with perfect quality... and wopping 43 mbit /s.
Why are dark scenes so much more costly than brighter scenes?
This does not feel right...
What can I do?
katzenjoghurt is offline   Reply With Quote
Old 10th September 2018, 22:30   #6350  |  Link
sneaker_ger
Why did you not lower crf?
Old 11th September 2018, 04:08   #6351  |  Link
Selur
Selur's Avatar
Also:
Boosting the brightness and looking at the source sometimes shows lots of compression artifacts, so some smoothing/denoising of the dark areas might help to understand where the bit rate goes.
Dark areas often contain lots of noise and artifacts which the encoder interprets as details that should be preserved.
Old 11th September 2018, 05:16   #6352  |  Link
benwaggoner
Yeah, I recommend doing 2-pass VBR encoding when trying to figure out quality/bitrate tradeoffs, and then figuring out the optimal CRF from there.
Ben Waggoner
My Compression Book
Old 11th September 2018, 11:29   #6353  |  Link
Forteen88
Herr
@katzenjoghurt. Maybe you should set x265: --zones
and increase/decrease bitrate where you want.
Forteen88 is offline   Reply With Quote
Old 11th September 2018, 11:41   #6354  |  Link
LigH
LigH's Avatar
Intentionally, aq-mode 3 is supposed to help with dark scenes, even without zones; but it needs a matching aq-strength too, and sufficient bitrate, and possibly other circumstances — and still can't work wonders...
New German Gleitz board
Old 11th September 2018, 14:42   #6355  |  Link
Forteen88
Herr
Are you aware of that GPU-decoding (certain newer GPUs) doesn't support 12-bits x265-video, but maximum 10-bits x265-video?
Old 11th September 2018, 15:10   #6356  |  Link
LigH
LigH's Avatar
And if you have source material with only 8 bit precision per color component, an internal precision of 12 bit per quantization coefficient would be a waste anyway.
Old 11th September 2018, 18:45   #6357  |  Link
brumsky
Hi guys,
What can I do?
To me it looks like your PSY values are set very high. That could be an effect of tune grain though. Have you tried it without tune grain? Maybe take tune grain out and try playing with the PSY values. I've found aq-mode 3 to work well but it needs a bit high bit rate to help it. When I use aq-mode 3 I try to set the strength setting between .85-1, then up the bit rate as needed to reach my target quality.
brumsky is offline   Reply With Quote
Old 11th September 2018, 21:15   #6358  |  Link
katzenjoghurt
Hey brumsky et al.!
Yes... psy_rd was set to 4.
I kept grain mode but reduced psy_rd to 1 and set crf to 21 now and the artifacts are gone (while the file size got a bit smaller) ... the result is a bit smeared though.
Also it kills most of the grain.
https://i.imgur.com/eqQJXy7.png
Lowering Crf or Psy further won't do any good though... quite the contrary. At least on that example scene.
Old 11th September 2018, 21:25   #6359  |  Link
katzenjoghurt
I didn't know that this is good practice.
Tried it out but didn't find any sweet spot yet though. :-/
Just something I tried out... 12-bit seemed to have helped in this thread. But no. Didn't work out for me.
Old 12th September 2018, 19:54   #6360  |  Link
excellentswordfight
Lost my old account :(
Tune grain usually gives pretty bad results, I found it to be usefull in very few instances.
I would start over with main10, keep --no-strong-intra-smoothing and --no-sao, try a slower preset and a lower CRF value. If that doesnt give you good results start playing with AQ and qcomp
excellentswordfight is offline   Reply With Quote
