30th August 2011, 10:26 | #9601 | Link |
Its not like its a small "bug", their overall design by choosing OpenCL is severly limited, its doubtful that they'll design a new interface just like that. You can do the same with DXVA2, including deinterlacing, even without a renderer - except that its damn slow for ATI/AMD cards because of the limited GPU->CPU transfer speed.
I don't know if its a driver or a hardware problem, but i'm quite sure it affects all GPU->CPU transfers. AMD/ATI isn't all that famous for their HPC/GPGPU capabilities. If they want to fix something, they should work on the transfer speed issue, and make using DXVA2-renderless support a viable alternative.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th August 2011 at 10:28. |
30th August 2011, 10:32 | #9602 | Link | |
Sadly it interferes with madVR even in Exclusive mode so I disabled it ... it was a nice feature otherwise. madshi, in the last few days I've noticed some random dropping of frames without any of the queues dropping low. They moved from 7-8/8 to 6/8 but not lower and despite this I got 5-9 dropped frames maybe in series of 3 for 2-3 seconds. Sadly the problem is random and not reproducible I haven't change any settings in past few months and I'm pretty sure this problem didn't exist in v0.73. I'll try to confirm if it's only v0.74 that has it but does anybody else experiencing the same and have any idea what could be wrong?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
30th August 2011, 10:33 | #9603 | Link |
Fantasy Codecs writer
To madshi
If madvr.ax where the folder does not contain libmfxsw32.dll avcodec-53.mvr avutil-51.mvr these three files, then do not enable internal decoder! or put this seeting to Registry not to bin file! thanks! |
30th August 2011, 10:37 | #9604 | Link | ||
I tried.
If only they implemented OpenCL <-> D3D9 interop. That would make a lot of things easier. And it should be possible with the current hardware, too. Some earlier version of their SDK actually had limited OpenCL <-> D3D9 interop, but then they suddenly dropped it, without any explanations. Quote:
Ah, I understand! Will do that... |
30th August 2011, 11:13 | #9605 | Link | |
30th August 2011, 11:18 | #9606 | Link |
I'd guess at least it wouldnt getting any worse then
30th August 2011, 11:23 | #9607 | Link | |
30th August 2011, 11:57 | #9608 | Link |
That shift trick would work only with Bilinear sampling, but not with any other linear filter (Bicubic, Lanczos, Spline etc). And I think Lanczos3 with no shift will still look noticeably better than Bilinear with a 0.25 shift. Preserving the original pixels is very much overrated, IMHO. But if you think you can improve on madVR scaling quality with a simple Avisynth linear resampler with a 0.25 shift, then post some comparison screenshots that proof that and I'll consider implementing it.
30th August 2011, 13:02 | #9610 | Link | |
NVIDIA GPUs are used for HPC (High-performance computing) and GPGPU tasks all over the world. They even have a dedicated card just for that (the Tesla). The key point was that GPGPU tasks typically also need good performance of GPU->CPU transfers, similar to how a CUDA decoder works, or a DXVA2-renderless decoder would - but its nothign you need for "normal" video playback or games, usually you just sent it to the GPU for display, you don't want to get it back. Between AMD/ATI and NVIDIA, thats a clear win for NVIDIA. Which is why AMD trys to push into that world with their next generation, but IMHO they are too late. CUDA is basically an industry standard by now, and OpenCL is only very slowly catching up (and is handy-capped to some degree) PS: Regarding driver issues - why is it that i always read on eg. AVSForums about the latest Catalyst breaking someones playback chain, but very rarely about NVIDIA drivers doing something like that? Sure, the drivers are not perfect (which software is?), and i could name several key points that need fixing myself, but at least there is some progress without huge regressions.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th August 2011 at 13:08. |
30th August 2011, 13:08 | #9612 | Link |
There is a *HUGE* regression with newer NVidia drivers, though: Presentation glitches when playing back content at a higher refresh rate. E.g. playing back 25fps content at 50Hz is really bad here on my 9400. I have to switch to D3D11 presentation and play with the tweaks to make the presentation glitches go away. From reading through this thread it appears that AMD users don't have this problem.
30th August 2011, 13:16 | #9613 | Link | |
Do you actually get non-smooth video? Speaking of DX11, i noticed the desktop/mpc-hc is not properly re-drawn if i exit FSE mode directly to windowed mode via hotkey (or double-click in MPC-HC). It works properly if i bring up a context menu in full-screen first to exit exclusive mode, and then double click to get into windowed mode. Works all fine with DX9. PS: I don't consider that huge, huge would be breaking playback completely, or making any kind of material unwatchable, without a screw i can turn to simply fix it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th August 2011 at 13:32. |
30th August 2011, 13:51 | #9614 | Link | ||
Well, you have to consider how much time I spent to implement all those nasty tweaks to work around the problem. It was probably around 2-3 full weeks of my programming time, no exaggeration, just to work around NVidia driver problems. And even through the tweaks do seem to help, users being forced to play around with those tweaks is very ugly, especially because it seems that everybody needs different tweaks. Personally, I do consider this problem "huge". In theory exclusive mode presentation was supposed to be rock stable. In real life it's quite the opposite, with NVidia at least. |
30th August 2011, 13:55 | #9615 | Link | |
Before those drivers, i didn't really need any tweaks, default settings worked quite smooth.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th August 2011 at 13:57. |
30th August 2011, 14:03 | #9616 | Link |
I'm not sure with which driver version exactly the issue was introduced. When I first implemented the "final exclusive mode rendering path" several months ago, some people already had problems and some people did not. Of course different people were using very different driver versions. Personally, I was using the latest CUDA beta driver versions. Anyway, my general impression was that AMD users had no big trouble with presentation glitches, while NVidia users had. That was a few months ago. Maybe the situation got even worse with 270 drivers now? Or maybe those months ago some people were already using very new beta drivers? I don't really know for sure...
30th August 2011, 14:50 | #9618 | Link | |
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
30th August 2011, 15:05 | #9619 | Link | |
30th August 2011, 15:27 | #9620 | Link | |
