11th June 2010, 21:04 | #7981 | Link |
I dont care so should you
No. Well it depends on the encryption of the disc. Are you using an on the fly decrypter like anydvd...
My Installer's || |
11th June 2010, 21:22 | #7983 | Link |
Yeah using anydvd HD with blurays and normally I use the anydvd ripper and then point ripbot at the m2ts on the mounted iso, but it would be cool if I could just read it from disc and skip the ripping step? Is there risk of skips when reading from disc that there wouldn't be reading the ripper-verified complete copy from hard drive?
11th June 2010, 21:27 | #7984 | Link |
No. you should be ok
My Installer's || |
12th June 2010, 05:42 | #7987 | Link |
400 pages and counting
ok, so I just found this piece of software this evening. I've looked around and can't find a good tutorial. I'd like it to use with my BluRay movies. Would someone kindly point me in the right direction. I did get through around 30 pages, but 3 years of postings are difficult to weed through.
12th June 2010, 06:26 | #7988 | Link |
Hello Atak,
I dont know if this is where I would report a problem with RipBot264 but I noticed that 24fps sources are not automatically converted to 30fps using the iPod/iPhone profile. Im sure you are aware that iPod Touch and iPhone both require 30fps for video playback. I realize RipBot264 has a speed setting that can be changed in the properties. However, that particular tool uses the AviSynth "AssumeFPS" filter which naturally changes the speed of the video playback. I believe a better way to change the frame rate without affecting the playback speed would be to use the AviSynth "ConvertFPS" filter which uses a "Blend Mode" by default. It introduces minor motion blur during action scenes but it's very minimal and doesnt affect the quality of the experience as viewed on the portable devices. I tested the filter out on one of the AVS scripts that your tool generates and it seems to work fine AND the video playback speed is not affected. Please let me know if I am looking at this the wrong way or if I am missing something =) Thanks! |
12th June 2010, 08:13 | #7989 | Link | |
is it "1_audio_Undetermined.aac" ? That's the only thing I saw there. I don't understand the wavpcm and the audio selection screen. If not much trouble, please show me what it is w/ screenshots. ty EDIT It seem if I changed it into Base3.0 profile, I can't re-encode. I was always using base4.0. I'll ty figuring out what's wrong, but help is still needed and would be appreciated. Last edited by gambit7; 12th June 2010 at 08:25. |
12th June 2010, 21:22 | #7991 | Link |
i read through a lot of this thread and didn't see this question so forgive me if it has been asked.
on ripbot 1.15.1 when i load my video in, in the lower left hand corner it says, "please wait, indexing video stream." main issue: on the newest version, 1.16.0 nothing happens. when i load my video it doesn't say anything in the lower left hand corner, and my video never loads. i've left it for a long time hoping it would eventually load. i'm back to 1.15.1 for now. is this a known issue? is there a fix? secondary question: also, this is a preference question. is there a general rule when encoding 1080p down to 720p, do you keep the DTS 5.1 or go down to the 640kpbs? i've been going down to the 640kbps because the video kbps seems so much higher, but i didn't know if the general rule is to keep 5.1 DTS? thanks. |
13th June 2010, 00:11 | #7992 | Link |
I have a show that is VC1, and I'm converting the mkv from 1080 to 720. All the episodes except one went through fine using 1.16.0. For this one episode I kept getting avs2yuv.exe crashing. I switched back over to 1.15.1 and it went through fine. Any ideas?
13th June 2010, 04:25 | #7995 | Link | |
13th June 2010, 06:00 | #7996 | Link |
Hey Atak,
I have some AVI files here with two audio tracks. When I import the file in Ripbot, it only demuxes the second audio track, not the first. The first is german, the second english. I only need the german stream. Is the error caused by FFMPEG or is there something missing in the command line? |
13th June 2010, 08:17 | #7997 | Link |
I am also having the AVCHD muxing problem (after switching to the new RipBot264 v1.16.0 ) when re-encoding my Blu-Ray's to AVCHD.
Converting to .mp4 for my iPad is working fine and I also tried encoding a Blu-Ray to .mkv and no problem there either, so I guess I will have to go back to an older version to solve the problem and wait for an update that solves the AVCHD muxing bug ? I know that I can abort RipBot while muxing and mux manually, but I was really happy with the option to have the RipBot shut down my computer when it was done Thanks for a great program Atak_Snajpera, I have been using RipBot for the past year, and this is the first time I am having any problems, so I am very impressed with RipBot and stability in general Keep up the great work Best Regards Denner |
13th June 2010, 11:51 | #7998 | Link |
I`m using latest RipBot and when making x264 v1.16.0 and when encoding movies to 1280 x 5xx first pass using like no more than 20-30% cpu and second pass no more than 65-80% on my Intel core quad 8300 @3Ghz. I also uncheck that low priority button and still encoding first pass with only 7 fps and second pass 6 fps
Should i replace x264.exe with core2 optimized code? edit: i try replaced and didn`t help Last edited by Washka; 13th June 2010 at 11:57. |
13th June 2010, 11:57 | #7999 | Link |
Hello everybody!
I had the chance to appreciate Atak's nice app. Only one problem: how to preserve automatically the original quality? The source file bitrate was 19Mb, but the resulting output bitrate was only 4mbits. I have attached the Mediainfo report from the source and the output file. Thanks for every help *************************************** O R I G I N A L **************************** Generale ID : 1 Complete name : 00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 6,02 GiB Duration : 40min Overall bit rate : 21,5 Mbps Maximum Overall bit rate : 35,5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : AP@L3 Duration : 40min Bit rate : 19,8 Mbps Width : 1 920 pixel Height : 1 080 pixel Display aspect ratio : 16:9 Frame rate : 23,976 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressivo Bits/(Pixel*Frame) : 0.398 Stream size : 5,55 GiB (92%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 40min Bit rate mode : Costante Bit rate : 384 Kbps Channel(s) : 6 canali Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48,0 KHz Stream size : 110 Mb (2%) Language : Russo Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 40min Bit rate mode : Costante Bit rate : 448 Kbps Channel(s) : 6 canali Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48,0 KHz Stream size : 129 Mb (2%) Language : Inglese *************************************** O U T P U T **************************** Generale Complete name : out.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1,30 GiB Duration : 40min Overall bit rate : 4 652 Kbps Encoded date : UTC 2010-06-04 06:16:41 Tagged date : UTC 2010-06-04 06:16:41 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Si Format settings, ReFrames : 3 fotogrammi Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 40min Bit rate mode : Variabile Bit rate : 4 331 Kbps Maximum bit rate : 18,4 Mbps Width : 1 920 pixel Height : 1 080 pixel Display aspect ratio : 16:9 Frame rate mode : Costante Frame rate : 23,976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressivo Bits/(Pixel*Frame) : 0.087 Stream size : 1,21 GiB (93%) Title : Bugs Writing library : x264 core 96 r1613 81e75e9 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr Encoded date : UTC 2010-06-04 06:16:41 Tagged date : UTC 2010-06-04 06:18:56 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 40min Bit rate mode : Variabile Bit rate : 317 Kbps Maximum bit rate : 333 Kbps Channel(s) : 6 canali Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48,0 KHz Stream size : 91,1 Mb (7%) Title : Imported with GPAC 0.4.6-DEV (internal rev. 5) Language : Inglese Encoded date : UTC 2010-06-04 06:18:27 Tagged date : UTC 2010-06-04 06:18:56 |
13th June 2010, 12:36 | #8000 | Link | ||
@stasi remux all avis to mkv
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th June 2010 at 12:39. |
