Old 25th March 2014, 09:34   #21  |  Link
real.finder
Originally Posted by osgZach View Post
Ok Here is my sample.
I didn't really know the best way to cut it, so I opened my demuxed m2v in DGindex and ran a selection then saved out a D2V with the smaller cut Mpeg.
This section appears to be entirely film (DGindex says) but I the entire movie has 30p sections in it, so its not a simple IVTC. I would not approach it from that solution.
I believe this short clip will show the color issue around character lines, I thought looked similar to the clip mentioned above with the police officer.
Gall Force: Eternal Story, sample clip
(25mb)
for me DGindex say Video Type: NTSC
it fine with
mpeg2Source("E:\Temp.demuxed.d2v")
TComb
AnimeIVTC(1)
mcdaa3 #or daa / daa3
and for "the color issue around character lines"
the source has halo and chroma blend/bleed/halo but not need for chrfix in animeivtc
you can try
# it better to use it after dehalo
  input=last
  chrwa=input.awarpsharp2(depth=4,chroma=6).aWarpSharp2(depth=-1,chroma=2)
  gchrblu=chrwa.MergeLuma(chrwa.blur(0.1)).aWarpSharp2(depth=6,chroma=6) #you can use depth=18 or any Value fit your source
  Mergechroma(gchrblu)
edit: To avoid the inverse results awarpsharp2(depth=4,chroma=6) can be awarpsharp2(depth=4,chroma=5) or you can add awarpsharp2(depth=4,chroma=5) before awarpsharp2(depth=4,chroma=6)
new one here
and here related thread
See My Avisynth Stuff
Last edited by real.finder; 25th October 2015 at 00:19. Reason: add trick to fix chroma blend/bleed/halo v1.35 link
Old 25th March 2014, 19:01   #22  |  Link
osgZach
I'll give that a try thanks.
Should I call that before or after the IVTC ?
edit: in any case I get thrown an error from awarpsharp2, "chroma must be 0..4" think that's from the final line where it was 6?
osgZach is offline   Reply With Quote
Old 25th March 2014, 19:11   #23  |  Link
real.finder
after.
make sure you are using last ver. http://forum.doom9.org/showthread.php?t=147285
Old 1st April 2014, 01:42   #24  |  Link
real.finder
new version in 2nd post, probability it will be the last (At least for this period)
Old 7th April 2014, 18:17   #25  |  Link
bxyhxyh
I think comb detection arguments for TFM() should be there.
cthresh, blockx, blocky, MI
bxyhxyh is offline   Reply With Quote
Old 11th May 2014, 08:40   #26  |  Link
Leinad4Mind
Please, DeInterlace me!
Leinad4Mind's Avatar
Line 207: "srestore(omode=2, mode=4, thresh=44, cache=cache, dclip=fbbob.crop(10,0,-10,0)).srestore(frate=frate, mode=-4, speed=-4, cache=cache)"
This code will trigger an error: "ERROR: SRESTORE CAN ONLY CALLED ONCE!!!"
Who am I?! I'm GOD... 8for it... father of my godchilds.
Leinad4Mind is offline   Reply With Quote
Old 11th May 2014, 16:10   #27  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
You should sure of using Srestore 2.7g+ or newer.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 18th May 2014, 18:17   #28  |  Link
Leinad4Mind
Thanks for the info!
Old 23rd December 2014, 18:18   #29  |  Link
real.finder
Modifications and additions to the Thread (not animeivtc script)
Old 5th January 2015, 23:32   #30  |  Link
CureGecko
I am having issues with using mode 2.
Avisynth error:
LoadPlugin: unable to load "C:\Program Files (x86)\AviSynth 2.5\plugins\ReduceFlickerSSE3.dll", error=0x7e
(AnimeIVTC.avsi, line 208)
I have seen where people had issues similar and their issues related to AvsRecursion needing to be in C:\Windows\System32 and that is not the case here as I have it in both plugins and System32. I used http://www.dependencywalker.com/ and found what it required and that it was already existing on my system, MSVCR71.DLL and AvsRecursion.DLL. So I do not know where to go from here.
Any help is appreciative, thank you. I am using AnimeIVTC 2014-3-31.zip in-case that matters.
Note: If the options are needed to know, AnimeIVTC(mode=2, cbob=2, pattern=4)
CureGecko is offline   Reply With Quote
Old 6th January 2015, 13:12   #31  |  Link
CureGecko, Try this tool: http://forum.doom9.org/showthread.php?t=170647
EDIT: Should they not be in SysWOW64 instead of system32 ?
Old 6th January 2015, 18:55   #32  |  Link
CureGecko
Thank you, Avisynth Info Tool is a great help. It was that it needed to be in SysWOW64.
Old 15th January 2015, 03:24   #33  |  Link
bilditup1
bilditup1's Avatar
So am I correct in assuming this won't work with AviSynth MT? For one, eedi2 is not MT'd and now impossible to find...
ED1: Or not! See this page:
http://www.avisynth.info/?%E3%82%A2%...82%A4%E3%83%96
ED2: But it's only for AA anyway...OK...I think I'll try it first before saying anything else, heh...
bilditup1 is offline   Reply With Quote
Old 30th March 2015, 02:52   #34  |  Link
real.finder
script updated
Old 14th April 2015, 12:23   #35  |  Link
Great Dragon
Great Dragon's Avatar
For some reason I can't get it works with MC_A_bob filter like this
BlankClip(length=240, width=1440, height=480, pixel_type="YV12", fps=29.970, fps_denominator=1, audio_rate=44100, channels=1, sample_type="8bit", color=$000000).AnimeIVTC(2, killcomb=1, bbob=5, extbob=MC_A_bob())
But it works fine if every function starts with new line
Great Dragon is offline   Reply With Quote
Old 14th April 2015, 12:43   #36  |  Link
Great Dragon
I suppose it's because extbob should be a variable. So if I declare it before AnimeIVTC script it works.
bobclp=BlankClip(length=240, width=1440, height=480, pixel_type="YV12", fps=29.970, fps_denominator=1, audio_rate=44100, channels=1, sample_type="8bit", color=$000000).MC_A_bob()
BlankClip(length=240, width=1440, height=480, pixel_type="YV12", fps=29.970, fps_denominator=1, audio_rate=44100, channels=1, sample_type="8bit", color=$000000).AnimeIVTC(2, killcomb=1, bbob=5, extbob=bobclp)
Old 15th April 2015, 07:00   #37  |  Link
I have not looked closely at that but would say that the problem is actually that Last does not exist yet, it would only exist when entire line has returned a clip.
Just as this would not work (untested)
Blankclip.BilinearResize(Width*2,Height*2)
As Last does not exist as default clip for Width nor Height.
Old 15th April 2015, 12:14   #38  |  Link
real.finder
as StainlessS say
extbob should be a clip
animeivtc need a PAL or NTSC clip, and extbob just to use an external bob clip, and by use AnimeIVTC(2, bbob=5, extbob=MC_A_bob) MC_A_bob function will use the clip (last) that will input in animeivtc and output bob clip in extbob
and in the case like this BlankClip(length=240, width=1440, height=480, pixel_type="YV12", fps=29.970, fps_denominator=1, audio_rate=44100, channels=1, sample_type="8bit", color=$000000).AnimeIVTC(2, bbob=5, extbob=MC_A_bob())
MC_A_bob will get no clip
maybe I will try to make something can use an external bob function instead of external bob clip to solve this
Old 15th April 2015, 15:30   #39  |  Link
real.finder
script updated
try
BlankClip(length=240, width=1440, height=480, pixel_type="YV12", fps=29.970, fps_denominator=1, audio_rate=44100, channels=1, sample_type="8bit", color=$000000).AnimeIVTC(2, bbob=5, extbobf="MC_A_bob()")
Old 2nd May 2015, 02:21   #40  |  Link
real.finder
script updated
anime aa, animeivtc, chroma fix, deinterlace, mod
