12th February 2015, 14:42 | #1301 | Link |
open BD-SUP error
Hello, I extracted the subtitle stream(BD PGS) from mkv file. Then I open the this .sup file with BDSup2Sub and save it to idx/sub. I can only see 20 lines. If I open this .sup file, I am able to see all 1300+ lines, but that software does not give option to save as idx/sub, so I still want to use BDSup2Sub. The error log while opening the sup file is:
Loading E:\Edge.of.Tomorrow\Edge.of.Tomorrow.2014.3D.BluRay.x264.DTS.track3_eng.sup #> 1 (00:00:15.599) #> 2 (00:00:37.621) WARNING: Missing PDS/ODS: last epoch is discarded #> 2 (00:00:39.039) #> 3 (00:00:40.791) WARNING: Missing PDS/ODS: last epoch is discarded #> 3 (00:00:42.918) #> 4 (00:00:45.003) WARNING: Missing PDS/ODS: last epoch is discarded #> 4 (00:00:45.921) #> 5 (00:00:48.006) WARNING: Missing PDS/ODS: last epoch is discarded #> 5 (00:00:49.717) WARNING: Invalid image size - ignored WARNING: Missing PDS/ODS: last epoch is discarded #> 5 (00:00:51.760) #> 6 (00:00:53.053) WARNING: Missing PDS/ODS: last epoch is discarded #> 6 (00:00:54.847) WARNING: <unknown> 0x50 ofs:0x0006a035 ERROR: PG missing at index 0x0006e742 Detected 0 forced captions. WARNING: missing end time of frame 6 -> fixed Decoding frame 1/6 at offset 0x00000108 Please advice. |
24th February 2015, 19:20 | #1304 | Link |
@igboo:
1) Okay, first create an SRT file with just the new subtitles you wish to add. Make sure the timing and everything are right. 2) Use a program like goSUP to turn your new SRT file into a BD SUP file. Try to match the colors, font and positions of your old subtitles because you can't change this later. 3) In BDSup2Sub load your old SUP file and then select output as XML/PNG to a folder. Call the output something like 'Original'. 4) In BDSup2Sub load your add-on SUP file and again output and save as XML/PNG. Save them to the same folder you put the output from step 3 in and name the files something like 'ADDON'. 5) Open the OLD and ADDON .XML files in Wordpad. Copy the relevant sections of code from your addon subs into the old subs and save it under a new name keeping an .XML extension. The pieces you are copying in the .XML should be ONLY between EVENT tags. There will be one entry for each new line you are adding. (Similarly you can delete a line between these tags.) Don't copy anything else. So a section should look like this: Code:
<Event InTC="00:03:09:11" OutTC="00:03:11:06" Forced="False"> <Graphic Width="575" Height="130" X="673" Y="888">ADDON_0005.png</Graphic> </Event> 6) Load the new .XML in BDSup2Sub and save it as a BD SUP file. Done. Last edited by DoctorM; 24th February 2015 at 19:52. |
22nd June 2015, 23:46 | #1306 | Link |
So I have this BD subtitle file taken directly from a Blu-ray I own. It's the german Avatar BD which contains all three editions (original cinema, extended cinema, collector's cut). https://www.dropbox.com/s/wjhkwtyzng..._4612.sup?dl=0 This one is for the collector's cut.
When I open it with the Java version 5.1.2 it finds 1487 frames but many of them have errors like missing end time. Frame 710 has a 1920x1080 sized subpicture and its content is shown in the little preview windows in the bottom right corner (and also in both top and bottom preview windows but you have to scroll). Frame 712 also has a 1920x1080 sized subpicture but its content is NOT shown anywhere. It is shown with these informations: Code:
screen size: 1920x1080 image size: 1920x1080 pos: (0,0) - (1920,1080) start: 01:10:01.130 end: 01:10:03.757 forced: yes screen size: 1920x1080 image size: 1920x1080 pos: (0,0) - (1920,1080) start: 01:10:01.120 end: 01:10:03.760 forced: yes If I open the XML in eg. Chrome or Notepad and jump to frame 710 I see Code:
<Event InTC="01:09:56:22" OutTC="01:09:59:13" Forced="True"> <Graphic Width="1920" Height="1080" X="0" Y="0">original_0710.png</Graphic> </Event> If I open the same file in the Qt version 1.0.2 it finds 1492 frames (because some frames are just split - frame XYZ with a duration of 1000 gets split into two frames with a duration of 500 each) but no errors at all. Frame 710 (now frame 711) is shown in the both top and bottom preview windows but not in the small in the bottom right corner. Same for Frame 712 (713). When I export to PNG/XML I get 1.971 png files. Some frames have only one png file, some have two png files and some have 3 or more. Frame 710 (711) has two. One is 1920x1080 with the subtitle in the top left corner and one is 827x126 and contains the subtitle beautifully centered. Frame 712 (713) has also two png files in the same format and style as for 710 (711). If I open the same file in Subtitle Edit it finds 1.487 frames, no errors at all but slightly different timings than in BDSup2Sub or the XML file. Frame 710 has 01:10:01,130 - 01:10:03,758 (duration 2,628). If I finally open the XML file I created with BDSup2Sub Java in BDSup2Sub I again get different behavior and timings. Frame 710 is now correctly shown in all three preview windows with the following informations: Code:
screen size: 1920x1080 image size: 800x92 pos: (563,806) - (1363,898) start: 01:10:01.114 end: 01:10:03.742 forced: yes screen size: 1920x1080 image size: 800x92 pos: (563,806) - (1363,898) start: 01:10:01.120 end: 01:10:03.760 forced: yes Actually I need three tools to fix a "broken" BDsup. BDSup2Sub Java, BDSup2Sub Qt and Subtitle Edit. I use Java to create a valid XML and most png files. Qt to get the png files Java wasn't able to read/create correctly. Subtitle Edit to get the correct timings. Last edited by an3k; 23rd June 2015 at 11:21. |
23rd June 2015, 12:24 | #1307 | Link |
PgcEdit daemon
I can perhaps explain why you have timing differences. The first reason is that BDSup2Sub re-arranges the timings to be in sync with the frames of the video stream. For example, the end time in your first example (01:10:03.757) is probably not exactly the time code of a specific video frame at 23.976fps. Therefore, it rounds it to the nearest frame, and that gives 01:10:03.760.
The big differences in timings you have noticed when converting to XML/PNG is probably due to a bug in the GUI and/or command line. I don't use the GUI often and therefore I can't be sure, but I know that you have to specify the input and output frame rate when you use the command line, as otherwise BDSup2Sub does a conversion (probably to 25 fps) anyway! The correct option for the java version and for a BD@23.976fps is --convert-fps 24p,24p (or --fps-source 24p --fps-target 24p for the ++ version). Note the terrible syntax: 24p doesn't mean 24fps, but 23.976! You have already the example of 2 bugs: the necessity to add the options to convert the frame rate to NOT convert it, and the discrepancy in the syntax of the frame rate. But if you use BDSup2Sub.jar from the CLI, it is possible to obtain correct results. (The rounding of the time codes will occur anyway, but it's not really a bug.) I suppose that you can play with the frame rate option in the first window of the GUI to obtain the same result, but I have never tried. I don't know why subtitle #712 is not visible. Indeed, it's a big problem. I know that some BD subtitles have special effects like fades that can confuse BDSup2Sub, and it's probably why BDSup2Sub++ generates several images instead of only one. The Java version is supposed to drop the invisible images and retain only the "best" one. Maybe there is another bug here and it keeps the fully transparent image? I don't use Subtitle Edit with BD3D2MK3D, simply because it cannot do what I need, and anyway, most conversions cannot be done from the CLI. But I like it when I need to convert manually a text based subtitle stream to BD SUP. As far as I know, it has no bugs. I wonder if it is justified to accuse BDSup2Sub of all problems you have had. As explained above, the timing problem is certainly a bug, but it can be solved. However, the other problems (such as the invisible subtitle or the multiple PNGs produced by the ++ version) are probably due mainly to your stream. According to the numerous error messages, that stream is seriously damaged. And that reminds me something I have discovered when I have converted Avatar 3D for the first time. At that time, BD3D2AVS (as it was called then) was using eac3to to demux the 3D MPLS. That worked well for the video and audio streams, but in some cases, it was impossible to demux the subtitles correctly. It's because in some 3DBDs (notably Avatar), the same subtitles are present with the same stream ID in the M2TS of the AVC view and in the M2TS of the MVC view. Most of the times, the subtitles are present in the AVC M2TS only, but for a reason I have never understood, there are exceptions. Since eac3to tries to demux the SSIF file (containing the AVC and MVC M2TS files joined together), it finds two different streams with the same ID, and it tries to demux them as one single stream. Of course, that cause numerous conflicts. Luckily, tsMuxeR 3D has not the same problem, and it can demux the subtitle streams correctly even in that precise case. Therefore, I suspect that perhaps the demuxer you have used may be the culprit. Anyway, if you have used eac3to, try tsMuxeR. (This apply only to the 3DBDs, but perhaps there are other problems when demuxing the 2D BDs too.)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 23rd June 2015 at 12:28. |
23rd June 2015, 14:38 | #1308 | Link | |||||
First of all thank you very much for feedback!
Whenever I used the GUI to load a BDsup I manually set "FPS Target" to 23.976 since it defaults to 25. BDSup2Sub.jar doesn't convert FPS when you export to BDsup but when exporting to eg. PNG/XML (I never tried the other formats) even when the "Change frame rate" checkbox is NOT checked. Quote:
I also experienced another bug. I open the original BDsup in the java version and export it as PNG/XML. The entry for the first frame is Code:
<Event InTC="00:00:39:18" OutTC="00:00:42:01" Forced="False"> <Graphic Width="1079" Height="62" X="416" Y="825">orig_0001.png</Graphic> </Event> Code:
<Event InTC="00:00:39:18" OutTC="00:00:42:01" Forced="False"> <Graphic Width="1077" Height="60" X="417" Y="826">new_0001.png</Graphic> </Event> Is the Java or Qt version still maintained or if not is there any other tool which I can use to modify BDsup files? |
23rd June 2015, 15:03 | #1309 | Link |
PgcEdit daemon
As far as I know, the development of the two versions has stopped. However, the source files are available, and it should be possible to continue to develop at least one of them, if someone is interested. It's not my case, sorry.
Thanks anyway for your comments. I don't think that it is possible to turn off the rounding of the time codes. The fact that the command line with the --convert-fps option gives the same result than the GUI is strange. Honestly, I don't understand. Have you verified if the frame rate in the XML is correct? The absurd X/Y positions you've seen in BDSup2Sub++ is also a known bug of that version. And I remember I have had many problems to capture the error messages of BDSup2Sub++ (when using the CLI). It uses a strange method that redirects the messages to a window. I have reported that problem to the author, but he has assured me that it's a QT "feature", and that there is no way to use the stderr stream "normally". Anyway, it's perhaps why you can't see the error messages in the GUI. And Subtitle Edit may be much more tolerant than BDSup2Sub. I don't know. For the difference of 1 pixel of the width and height of the bitmaps, it's probably because the subtitles are not cropped exactly the same way with the two versions. Have you verified if the width and height of the XML corresponds to the real size of the PNG?
23rd June 2015, 17:49 | #1310 | Link | |||
[QUOTE=r0lZ;1727459]The absurd X/Y positions you've seen in BDSup2Sub++ is also a known bug of that version. And I remember I have had many problems to capture the error messages of BDSup2Sub++ (when using the CLI). It uses a strange method that redirects the messages to a window. I have reported that problem to the author, but he has assured me that it's a QT "feature", and that there is no way to use the stderr stream "normally". Anyway, it's perhaps why you can't see the error messages in the GUI. And Subtitle Edit may be much more tolerant than BDSup2Sub. I don't know.[QUOTE]At least BDSup2Sub++ can export the pictures. With the help of both versions and Notepad I was able to fix my BDsup completely. Quote:
When opening a picture based subtitle file BDS2S.jar scans the pictures for non-alpha content and places that green border around it. Based on that the picture size is calculated. But BDS2S.jar leaves a 1 pixel space around the actual non-alpha content, identifying a picure as eg. 200x100. If you now export and open that exported version BDS2S.jar scans again but this time it doesn't (or maybe can't) leave a 1 pixel space around, thus identifying the same picture as 198x98. However, it correctly adjusts the position of the picture so a 200x100 picture located at 800x800 will result in a picture of 198x98 located at 801x801. The subtitle is actually at the same position. How I repaired my broken BDsup file:
23rd June 2015, 18:45 | #1311 | Link |
PgcEdit daemon
I see. Not easy to do that manually! Maybe if you have to do that several times, you should fix the source code instead. That will tale less time! ;-)
Seriously, if you decide to work on the source, please let me know. I know also a couple of bugs related to the palette generated for the VobSub format, and I have some suggestions. Thanks in advance!
6th July 2015, 16:52 | #1312 | Link |
load sup ripped with projectx
The revolution of a dvb ts is 1920x1080.
I rip sup and idx/sub from ts with projectx, but BDSup2Sub cannot load the sup file directly, the error message is "Offset xxxx out of bound..." After I rename the corresponding IFO file as the sup file, BDSup2Sub can load the sup file with many warnings, and the revolution is 720x576. How to load the ripped sup file with BDSup2Sub? Or How to rip sup from dvb ts at original revolution? Thank you very much. |
8th July 2015, 08:42 | #1313 | Link |
The IFO is not related to the HD subtitles if this is what you wanna know. The IFO is a convenience file put there to help the future processing of the SD (standard definition) subtitles, in particular the colours.
These being said I do not go into the nasty job of asking you if you know how to extract the HD subtitles with ProjectX. I assume you know it
Born in the USB (not USA) |
9th July 2015, 03:47 | #1314 | Link |
The language of TS is Traditional Chinese
Sup is ripped by PorjectX BDSup2Sub cannot load the sup file, the error message is "Offset xxxx out of bound..." Not only BDSup2Sub, but also BDSubEdit and SupRip cannot load the sup file I tried several TS files, only got the same errors |
9th July 2015, 12:32 | #1315 | Link |
I then suggest you to learn first how to extract the subtitles with ProjectX. I did and still do this and there are no problems at all.
But this is off-topic.
12th July 2015, 14:38 | #1316 | Link | |
Allow me to describe more clear.
The subtitle is shown in traditional Chinese. It's DVB subtitle, not DVB teletext Quote:
BDSup2Sub, BDSubEdit and SupRip cannot load the sup file ripped by ProjectX. SupViewer, Subtitle Edit and BDSup2Sub++ can load the entire sup file, SupRead can only load first frame, they all assume the revolution to be 720x576. Even though I check "enable HD subtitle", those softwares still assume the same revolution. If I use BDSup2Sub to load the ripped sub, upsize it to 1280x720 and export it to sup, all the softwares above can load the entire exported sup, except SupViewer, it showes error message. All I want to do are the following things 1. Rip sup from ts at original revolution and shape 2. Load the sup file with BDSup2Sub, downsize it to 1280x720 and export it to sub So all I want to know is how to rip standart sup from ts at original revolution, that's why I post another thread first |
15th July 2015, 05:17 | #1317 | Link |
Angel of Night
You already have the Sup files in original resolution, that's what it imports. BDSup2Sub converts Blu-ray subtitles to DVD subtitles, what other behavior would you expect? DVD SUB files are always DVD resolution. Only saving to Sony BDN XML will retain full resolution, after which you can batch process all the png files down to 1280x720 and convert them back to SUP.
Are you sure you wouldn't rather just convert them to text subtitles and forget the resolution problems? |
22nd July 2015, 07:16 | #1318 | Link |
I was taking a look at Avatar (the 2D Collector's Edition with the 3 versions).
I found that v5.1.2 shows blank frames with "WARNING: Problems during RLE decoding of picture OBJ at offset 0x003e1c0e" for anything in the Navi font. v5.0 and ++1.0.2 work just fine. Something has definitely gone wrong with the newer versions of BDSup2Sub. I know this has been discussed, but is anyone looking into it? Last edited by DoctorM; 22nd July 2015 at 07:21. |
22nd July 2015, 18:47 | #1319 | Link | |
