7th July 2012, 13:47 | #1121 | Link |
PgcEdit daemon
MaistroX, maybe, after the conversion, you can also edit the org and/or align parameters in the IDX file. But note that some players ignore these values.
7th July 2012, 23:41 | #1122 | Link | |
Sry, but I dont seem to understand! :/
I want to use "move all" in Move All Captions, but I can only get them below, not at the top and "move all" in any way I tryed so far, please help! I dont want to move them one by one. Quote:
Higherst Offset Y I can set is 341, and it does not get the subs on top , them stay the same. Last edited by MaistroX; 7th July 2012 at 23:49. |
9th July 2012, 19:16 | #1125 | Link |
Posts: n/a
I first need to see if I can figure out why that was chosen. I assume there was a good reason and make sure the change doesn't break something else deeper in the code. But it won't be until probably after the 1.0.0 release.
I still have some memory leaks to iron out, some reorganization and some optimization I want to get in first. |
11th July 2012, 14:54 | #1126 | Link |
Hi, SassBot...
rc2 crash when import from BDN xml/png and export to idx/sub, if the subtitle is long more than 2000 lines or near. "Edit DVD Frame Palette" not work, any changes in this return to default. And for me at the moment this version have the same problem that the java version has. some lines of subtitle "randomly" appears with black background in my TV. should be a bug on color palette in java version and continues in this version. But i don't have programming skills to say if is a bug, I just report my problem use this tool. Last edited by mood; 11th July 2012 at 15:12. |
11th July 2012, 15:18 | #1127 | Link | ||
Posts: n/a
11th July 2012, 15:56 | #1129 | Link |
Ok...
I have two problems with this 2 subtitles... This sub restarts my TV: http://www.mediafire.com/?ca3xegs8uxtxx1w And this "randomly" appears with black background in my TV. http://www.mediafire.com/?4r3a3j6zn356j01 Is the same problem with java version. I take 2 cell phone pictures of my TV, look it. Take a look on pictures... -------------------------------------------------------------------------------------- I use AVIAddXSub to make idx/sub and i never have a problem. The only problem is the low resolution of subtitles. Last edited by mood; 11th July 2012 at 16:26. |
11th July 2012, 16:34 | #1131 | Link |
Ok...
here is the AVIAddXSub sub, and with this I don't have any black background or problem in my TV. http://www.mediafire.com/?f5h6w747xl10fct |
11th July 2012, 16:50 | #1134 | Link |
Posts: n/a
Ok good. Also that contains a fix for the editing the dvd palette frame, too. I finishing up some more refactoring and then I should hopefully have the final 1.0.0 release early next week. The color palette issue will come also with the outline transparency fix r0lz reported in the next iteration after the 1.0.0 release.
11th July 2012, 16:53 | #1135 | Link | |
take your time not worry... and thanks |
12th July 2012, 18:00 | #1138 | Link | |
