Old 9th September 2012, 12:03   #81  |  Link
active1
Originally Posted by Myrsloik View Post
It is how my threading model works. Avisynth filters are for compatibility reasons limited so one instance may run on one core at one time. Avisynth-mt gets around this by creating multiple instances (one per thread), OR by making very unsafe assumptions.
Newly written and ported filters for the vs api can if done correctly handle multiple frames at once. See the included Lut/Lut2 function.
so there is a chance to make it even better than Avisynth MT in speed wise? (with only one filter)
active1 is offline   Reply With Quote
Old 9th September 2012, 12:10   #82  |  Link
TurboPascal7
TurboPascal7's Avatar
I think I've fixed the crop argument checks. Can you give an example of the optional arguments maybe not working?
Traceback (most recent call last):
  File "D:/test.py", line 21, in <module>
    source = w.std.CropAbs(clip=source, x=16, y=16)
  File "vapoursynth.pyx", line 434, in vapoursynth.Function.__call__ (cython\vapoursynth.c:7371)
vapoursynth.Error: 'CropAbs: argument width is required'
source = w.std.CropAbs(clip=source, x=16, y=16, width=-16, height=-16)
Works but outputs garbage. Should throw error or work like avisynth's crop (subtracting provided negative width/height values from clip's parameters).
6. It's already included in list_functions(), why do you need one more?
I don't really need another list_functions() method. I do want to know Core class constructor parameters, VideoNode.output() method parameters (wanted to test callback, added in r4) etc. Without documentation and any public API I don't see any ways to do it since reflection doesn't work well with cython. I'm asking for this too early, I guess.
TurboPascal7 is offline   Reply With Quote
Old 9th September 2012, 12:13   #83  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Not without porting filters, no. I'm not going to make another avisynth-mt mess. I intend to win people over in the end by being faster and more stable for most users.
Myrsloik is online now   Reply With Quote
Old 9th September 2012, 12:20   #84  |  Link
Myrsloik
Myrsloik's Avatar
Of course width is required, this only moves the upper left point.
fixed
Core constructor: def __cinit__(self, flatten = True, addcache = True, int threads = 0)
Not much of interest, really. Flatten is whether or not single return value functions get the returned dict flattened to a single value automatically. addcache controls automatic cache insertion.
Output declaration:
def output(self, object fileobj not None, bint y4m = False, int lookahead = 10, object progress_update = None):
Where lookahead is the number of frame requests it has going at once to keep throughput up and progress_update is a functions that could looks like this:
def print_frame(n, total):
print('Frame: %d/%d' % (n, total))
Old 9th September 2012, 14:02   #85  |  Link
active1
that's good too, i hope that we will not need to load any filter from avisynth someday.
i have a problem with ColorMatrix:
every filter above work very well, except ColorMatrix
is it not supported yet?
Old 9th September 2012, 21:20   #86  |  Link
Myrsloik
Myrsloik's Avatar
I released R5. Changes in the first post. If this one turns out well I'll start experimenting with other platforms.
Old 9th September 2012, 21:22   #87  |  Link
TheProfileth
Leader of Dual-Duality
TheProfileth's Avatar
r5:
more python output fixes
added accept_lowercase as a setting for the core constructor
python module refinement, now all objects have a string representation with more information
other minor fixes
Does this mean you can do things with all lowercase now?
I'm Mr.Fixit and I feel good, fixin all the sources in the neighborhood
My New filter is in the works, and will be out soon
TheProfileth is offline   Reply With Quote
Old 9th September 2012, 21:23   #88  |  Link
Myrsloik
Myrsloik's Avatar
Yes, I added it as an experiment and it's off by default. It may disappear again if I don't like it.
Old 9th September 2012, 21:24   #89  |  Link
wOxxOm
Oz of the zOo
this is great, let it be :-)
also, is there a way yet to create arbitrary clips like in avisynth's ScriptClip? The only way I see now is to loop through all frames and then core.std.splice individual frames after some processing which seems to defy the idea of lazy calculation in a ScriptClip.
wOxxOm is offline   Reply With Quote
Old 9th September 2012, 21:32   #90  |  Link
Reel.Deel
I have managed to finally output y4m but I do not know how to successfully pipe Vapoursynth to X264. Can someone please post a sample of how to achieve this?
@ Myrsloik
So I noticed that the vsvfw.dll is no longer included in r5. Is it still needed?
Old 9th September 2012, 21:34   #91  |  Link
Myrsloik
Myrsloik's Avatar
@ Myrsloik
It was never used. The vfw part still isn't anywhere near ready.
Old 10th September 2012, 00:00   #92  |  Link
TheFluff
Excessively jovial fellow
It's not supported yet. Vapoursynth doesn't have equivalents for all of the internal Avisynth functions yet, so filters like ColorMatrix that invoke internal Avisynth filters will break if the invoked function doesn't exist in Vapoursynth.
Old 10th September 2012, 00:07   #93  |  Link
Myrsloik
Myrsloik's Avatar
I'd like to add that I may never add any extensive invoke support on the avisynth side. I estimate that the time to port the few useful filters that use invoke and adding good enough support for it in vs is about the same. I know which one I'm going to pick.
Old 10th September 2012, 07:55   #94  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Ok so I finally got past the "test" phase of the installation instructions LOL. It turns out that I needed the Microsoft Visual C++ 2010 Redistributable Package (instead of the 2008 one) to get it working. The list.functions() is messed up in r5 compared to r3 (I don't have r4 around for some reason). Can't wait to dabble with a new interface and learn new things.
"I'll take a potato chip... and eat it!"
Yoshiyuki Blade is offline   Reply With Quote
Old 10th September 2012, 08:11   #95  |  Link
smok3
brontosaurusrex
smok3's Avatar
vapour is win only?
certain other member
smok3 is offline   Reply With Quote
Old 10th September 2012, 08:51   #96  |  Link
TurboPascal7
It isn't messed up. It just returns a string instead of printing it. Should be used like print(core.list_functions()).
Old 10th September 2012, 08:55   #97  |  Link
Yoshiyuki Blade
Novice x264 User
I see. Yeah, it looks fine when used that way.
Old 10th September 2012, 09:46   #98  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by smok3 View Post
vapour is win only?
Only until it's kinda stable.
Old 10th September 2012, 11:10   #99  |  Link
Reel.Deel
When I try loading the "official" MVtools (v2.5.11.3) it works fine, but when I try it on Dithers MVTools (v2.6.0.5) it just silently crashes the python command line.
Also, I'm happy to see DGIndexNV work on Vapoursynth.
Old 10th September 2012, 13:15   #100  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
However, DGMPEGDec can't be used because it requires avs internal crop function.
I used TS2AVI/MPEG2Dec3k after a long time...
my repositories
Chikuzen is offline   Reply With Quote
speed, vaporware, vapoursynth
