Old 15th January 2009, 18:43   #341  |  Link
Glorioso
I'm getting the error in the image attached, any ideas?
Glorioso is offline   Reply With Quote
Old 15th January 2009, 21:15   #342  |  Link
xeniste
xeniste's Avatar
Hi Dean,
First I have the same problem with the _temp directory.
Second, it's much worse.
First, I have downloaded from your site the multiAVCHD_1.3_PAL_LITE.rar, copied all the files inside in a separate directory and used it like explained.
As I have a Topfield receiver, after having copied .rec files to my computer, I first use H264TS_Cutter v.111 to transform them in normal .ts.files and to cut all the unnecessary parts. It gives me a "clean" .ts.file.
Then, I use a program called tsMuxeR, which produces a true BD-structure with all folders needed.
Finally, I use your program.
So, yesterday I tried to make a test disk from 2 clips done as described below. It was quite instantly done, the player accepted the disk without problems. But I had the same clip recorded twice as Title 1 & 2, the second clip was not there.
Today, I have launched your program to make a real disk of 3 films. It told me that a new version was available, downloaded all files and made all as yesterday. But in the AVCHD directory, it was only one film,
Then, I re-launched the program, it downloaded some more files - and this time, it moved none of the films to the target directory, there were only the menu files.
Then, I tired to add .ts files.
And I received this message : Only first audio and video streams will be included...
And really, it was only one film inside!
Can you explain, what's going wrong?
Windows XP Pro, PAL.
Thank you in advance.
xeniste is offline   Reply With Quote
Old 15th January 2009, 21:18   #343  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
It won't affect the output. Just an error that TEMP folders cannot be deleted. It will be fixed soon.
Old 15th January 2009, 21:23   #344  |  Link
deank
deank's Avatar
Current version is 1.5.
You don't need this step, as multiAVCHD accepts TS files.
Only first audio stream and only first video streams are used off of .*ts files.
I guess I can. Please PM/post your LOG file (from LOG tab).
Old 15th January 2009, 21:27   #345  |  Link
xeniste
xeniste's Avatar
Here it is :
Author message: [15/01/2009] build 197 (latest is: 197) - Individual menu for if titles less than 6. Bugfixes for NTSC menu.
[22:12:02] Log started for multiAVCHD v1.5 (build 197)
[22:12:02] Processing...
[22:12:02] Processing 3 files/folders.
[22:12:02] Converting transport stream file to AVCHD (H:\VIDEO_TS\BRAY\UN JOUR SUR TERRE_mux.ts_new_cut.ts).
[22:12:02] Generating meta file for tsMuxer...
[22:12:02] Only first audio and video streams will be included...
[22:12:02] M2TS stream split set at 3999MiB...
[22:12:02] Creating BluRay folders (tsMuxer)...
[22:28:12] Done!
[22:28:12] CLPI transfer: H:\_TEMP\20090115-2212027600\BDMV\CLIPINF\00001.clpi -> H:\AVCHD\BDMV\CLIPINF\00000.clpi
[22:28:12] M2TS transfer: H:\_TEMP\20090115-2212027600\BDMV\STREAM\00001.m2ts -> H:\AVCHD\BDMV\STREAM\00000.m2ts
[22:35:08] CLPI transfer: H:\_TEMP\20090115-2212027600\BDMV\CLIPINF\00002.clpi -> H:\AVCHD\BDMV\CLIPINF\00001.clpi
[22:35:08] M2TS transfer: H:\_TEMP\20090115-2212027600\BDMV\STREAM\00002.m2ts -> H:\AVCHD\BDMV\STREAM\00001.m2ts
[22:38:53] MPLS transfer: H:\_TEMP\20090115-2212027600\BDMV\PLAYLIST\00000.mpls -> H:\AVCHD\BDMV\PLAYLIST\00000.mpls
[22:38:53] Old pointer to 00001.m2ts in 00000.mpls now set to -> 0
[22:38:53] Old pointer to 00002.m2ts in 00000.mpls now set to -> 1
[22:38:53] Converting transport stream file to AVCHD (H:\VIDEO_TS\BRAY\LE PEUPLE MIGRATEUR_mux_cut.ts).
[22:38:55] Generating meta file for tsMuxer...
[22:38:55] Only first audio and video streams will be included...
[22:38:55] M2TS stream split set at 3999MiB...
[22:38:55] Creating BluRay folders (tsMuxer)...
[22:39:06] Done!
[22:39:06] Converting transport stream file to AVCHD (H:\VIDEO_TS\BRAY\MICROCOSMOS_mux.ts_new_cut.ts).
[22:39:06] Generating meta file for tsMuxer...
[22:39:06] Only first audio and video streams will be included...
[22:39:06] M2TS stream split set at 3999MiB...
[22:39:06] Creating BluRay folders (tsMuxer)...
[22:39:14] Done!
[22:39:14] Preparing authoring information...
[22:39:14] Copying 1 sec blank video data.
[22:39:14] Creating static/lite top PAL menu.
[22:39:14] Trying to download 00002.litePAL1...
[22:39:49] Proper lite menu Page #1 downloaded!
[22:39:50] Setting menu for 1 titles...
[22:39:50] New offset for m2ts#1 -> 0
[22:39:50] New offset for mpls#1 -> 00000
[22:39:50] Setting titles #2 to #40 to point top menu.
[22:39:50] Fixing clip files...
[22:39:50] Completed.
[22:39:50] Done!
[22:39:50] H:\AVCHD folder created!
[22:39:50] Burn its CONTENTS to DVD-UDF 2.50...
Old 15th January 2009, 21:54   #346  |  Link
deank
deank's Avatar
Please check the log after you update to build 200. It should be more informative.
--- (earlier said...)
It seems tsMuxer did not process your second and third input .ts files. Try to load one or the other directly to tsMuxer and see if you'll get any output - and more important - tell me what properties does tsMuxer detect of your audio/video streams inside .ts.
You didn't use cut_start/cut_end in tsMuxer tab, did you?
At this point only AC3 audio streams and AVC/VWC1/MPEG-2 video streams are supported when importing ts/mts/m2ts files, tho not all are compliant with AVCHD standard.
Check if your second .ts file has AC3 audio or (L)PCM audio.
Old 15th January 2009, 22:55   #347  |  Link
xeniste
xeniste's Avatar
You are absolutely right - they have the MPEG sound - I could not imagine, that the channel uses this, and a 2-way output!
And I had not used tsmuxer to cut, because files were cut before in H264TS_Cutter.exe - the only quick program, that allows to SEE the content.
Otherwise, why yesterday I have had a clip recorderd twice, and nothing for the second one ?
Old 15th January 2009, 23:28   #348  |  Link
deank
deank's Avatar
It was not 'recorded' twice. It was just a glitch in multiAVCHD when you use 'no menu' option, so you had your first title dubbled as "top menu" and "first title". It was fixed earlier today. I guess your second title was not compliant, too.
Old 15th January 2009, 23:48   #349  |  Link
xeniste
xeniste's Avatar
I will re-test it tomorrow.
But that time, BOTH clips were compliant - AC3 sound. By the way, I had never used "no menu" option - the greatest interest of your program is the menu!
Old 16th January 2009, 06:10   #350  |  Link
jfcarbel
Programmer
When you click the ADD buttons they should open the last used source directory - even after a restart of the program.
I just tried the latest version and it does not seem to open the last used source when I hit add.
Cool. I see you added the feature to only display the number of titles needed on the menus. Thanks!
jfcarbel is offline   Reply With Quote
Old 16th January 2009, 08:50   #351  |  Link
turbojet
Originally Posted by kaid View Post
*grumble*... >:-( It wasn't his idea!
Thanks for your idea! I never got a chance to use your linux alternative. I do most work on windows. Linux is mainly a server setup and forget it os for me.
Old 16th January 2009, 09:03   #352  |  Link
pkho
I run some test mkv and the result is in vertical stretched 4:3. BDedit CLIPINF also tells it is 4:3. Any way to fix it?
pkho is offline   Reply With Quote
Old 16th January 2009, 09:55   #353  |  Link
deank
deank's Avatar
Added new option in authoring tab:
[x] Show non-existent titles (for LITE menu only)
If checked - first menu page will show Titles #1 - #6 as in previous builds.
If unchecked - first menu page will show only needed titles.
Old 16th January 2009, 14:50   #354  |  Link
Glorioso
Like i said in the PM the MKV i was usung there war corrupted. I0ll try further today, but the operation stoped there, no output was made.
Old 16th January 2009, 16:50   #355  |  Link
nwg
Latest version is working great again. Any reason why you chose 6 as the number of actual titles in the first menu. I wonder if this can be expended to say 10 and two rows of 5? If I add 9 will it show 20 in the menus?
nwg is offline   Reply With Quote
Old 16th January 2009, 18:23   #356  |  Link
deank
deank's Avatar
Originally Posted by nwg View Post
Latest version is working great again. Any reason why you chose 6 as the number of actual titles in the first menu?
it is 5 title, not six. i just picked a number. and because it is compatible with previous releases. making it more than five would requre rewriting of the code and incompatibility with any previous releases.
i may implement it in next version. no updates before monday. my flight has more than 4 hours delay and ilm not sure when i'll be back home.
Old 16th January 2009, 21:25   #357  |  Link
xeniste
xeniste's Avatar
And there is no title menu at all - only the main page with MULTIAVCHD. And the disk starts by playing the first title at a glance. Show non-existent titles unchecked.
Why?
One more question : what the option Sequental title playback gives?
Old 16th January 2009, 22:16   #358  |  Link
PassThePeas
I'm sure that with a little patience and a good browser you will find the answer in this very thread ....
PassThePeas is offline   Reply With Quote
Old 17th January 2009, 01:25   #359  |  Link
Glorioso
After last update the error i reported was gone. Very nice application.
Questions :-)
1 - How can i order the files, i've used 2 mkv, namedxxx-01.mkv and xxx-02.mkv and they appeared inverted in the menu.
2 - Can i change the names in the Menu?
Old 17th January 2009, 02:31   #360  |  Link
Razputin
Currently not available but should be made available in a future release. No idea how soon.
Razputin is offline   Reply With Quote
