Old 23rd July 2013, 01:19   #21  |  Link
Why do we have two identically named threads about this? Which one should I close after linking to the other?
Old 23rd July 2013, 07:11   #22  |  Link
IanB
Avisynth Developer
Check with Wilbert, I believe he split post #148 through #162 off from the other thread, but post #148 was by Forensic and they wanted the thread owned by StainlessS. So post #148 (global post 1636945) became the owner of the other orphan thread and post #149 (global post 1636961) became the owner of this thread.
Perhaps you can remerge the 2 threads and "clone" an earlier dated post by StainlessS (eg global post 1636921) and press it into service as the owner for this thread.
IanB is offline   Reply With Quote
Old 23rd July 2013, 10:42   #23  |  Link
RgbAmplifier v1.01, with Gavino mod, see first post.
Old 23rd July 2013, 12:23   #24  |  Link
Oy, I'll leave it to Wilbert then. Thanks.
Old 23rd July 2013, 18:09   #25  |  Link
Wilbert
I'm a loss at what to do. Yes originally #148 was the first one of this thread. Since that post was not from StainlessS, i removed it from this thread (and moved the contents to the third post of this thread; #3). I thought that was sufficient. Perhaps Forensic didn't see that and moved it also to a new thread, so that's why there are two of them. So, tell me what i need to do ...
Old 23rd July 2013, 20:11   #26  |  Link
I wouldn't try to tell you what to do, Wilbert!
I'll have a look and maybe make a suggestion. It just seems confusing to forum members to have the same thread title and same subject matter.
Old 23rd July 2013, 21:15   #27  |  Link
I am well confused, Forensic, please delete your thread, thankyou.
Old 24th July 2013, 08:50   #28  |  Link
Forensic
Alternate discussion deleted
As requested, the other discussion has been deleted.
StainlessS, thank you for your work on this. When you post the new RgbAmplifier plug zip file (which I am very anxious to try) please include:
Gavino's [allow a zero multiplier]
Assert(Multiplier>=0.0 && Multiplier<10.0,"RgbAmplifier: 0.0 <= Multiplier < 10.0 ("+String(Multiplier)+")")
Gavino's [new color is added to the color avg value, not the color value]
newred = Round(redavg + (Multiplier * ( red - redavg)))
newgreen = Round(greenavg + (Multiplier * ( green - greenavg)))
newblue = Round(blueavg + (Multiplier * ( blue - blueavg)))
creaothceann's [corrected math, same as my original post]
color=(newred*256+newgreen)*256+newblue
Please include the above documentation in the text file.
Forensic is offline   Reply With Quote
Old 24th July 2013, 12:32   #29  |  Link
@Forensic,
I refer the honourable gentleman to the post I made some moments ago:
[EDIT: Margaret Thatcher's favourite reply during PM's question time, with 'post' substituted for 'reply']
EDIT: Also, can you remove your dead link from this post:
http://forum.doom9.org/showthread.ph...70#post1637870
EDIT: Perhaps you would also like to insert a link to this thread, into your currently last post in
RT_Stats thread, here: http://forum.doom9.org/showthread.ph...44#post1637744
Old 24th July 2013, 17:21   #30  |  Link
Forensic
@StainlessS
The dead link reference has been removed and my original RT_Stats comment now directs here. That should alleviate all the double post confusion.
Thank you for the new version. This plug has so much potential and is building excitement among my forensic colleagues.
Last edited by Forensic; 24th July 2013 at 18:36. Reason: Just realized where the new version is. Duhhhhh
Old 24th July 2013, 21:38   #31  |  Link
Your Forensic colleagues seem to be an excitable bunch.
Old 24th July 2013, 22:15   #32  |  Link
Forensic
We often get cases that haunt us for years after the enhancement is unsuccessful . Each tool allows us to revisit those cases. Besides, we love our profession.
Old 24th July 2013, 22:23   #33  |  Link
Yes, but promise me something, you aint gonna nail me with my own "Stuff", give me a get out of jail free card, please.
Old 24th July 2013, 22:28   #34  |  Link
I think from 5 upwards is considered serial killer, Let me have at least 4, so I know where to draw the line.
Old 24th July 2013, 23:38   #35  |  Link
Forensic
I will promise you this: If a major case is solved using this tool, I will post about it here (as much as it can be talked about).
Old 9th September 2013, 23:52   #36  |  Link
RgbAmplifier v1.02. see 1st post.
Sped up a little, especially if RMin/RMax etc at defaults (0,255).
Multiplier max now changed from 10.0 to 20.0.
Old 10th September 2013, 08:28   #37  |  Link
Forensic
Thanks for the speed improvements. I will test it later this week.
Old 7th June 2014, 19:33   #38  |  Link
New version, RgbAmplifier - Forensic Tool - v1.03 - 7 June 2014
Minor update. If called on same frame as previous call, then does not reset (ie does not newly re-read radius-1 frames either side of target frame).
Avoid possible cache bug here:- http://forum.doom9.org/showthread.ph...27#post1682827
where would unnecessarily re-read up to 198 frames whenever a frame was requested more than once in succession.
Above noted bug would have no further effect on RGBAmplifier.
See 1st post.
Old 10th December 2014, 02:38   #39  |  Link
Reel.Deel
Looking for something else I came across Forensic's webpage, pretty cool.
http://www.forensicprotection.com/RgbAmplifier.html
Old 10th December 2014, 02:52   #40  |  Link
Yes RD, I came across that page + more about 6 months ago, I followed a few of his cases and such, with court verdicts and the like. Forensic is a minor celebrity it seems.
EDIT: Was wondering if he was OK as not been around for some time. Seems he was last active at some forensic shindig
in mid November 2014, so he is up and about. Am still though wondering what happened to Martin53, he went away on
safari and aint been heard of since (although, as well as 'safari' he also said I think 'going to the East' [in PM] so maybe India
or somewhere, not though heard the word 'safari' connected with India, usually Africa).
