8th December 2008, 21:02 | #681 | Link |
Feature request: Can mkvmerge ignore data in it's own namespace within a chapter xml file? For example:
<?xml version="1.0" encoding="utf-8"?> <Chapters xmlns:x="http://custom-data-namespace"> <EditionEntry> <x:Data>I should be ignored because I'm in my own namespace.</x:Data> <EditionFlagHidden>0</EditionFlagHidden> <EditionFlagDefault>0</EditionFlagDefault> <ChapterAtom>...
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server |
8th December 2008, 23:45 | #682 | Link | |
MKVToolNix author
You can read my full announcement.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
8th December 2008, 23:48 | #683 | Link |
Is there a way to get mkvextract 2.4.1 to output timecodes that aren't in scientific notation?
For example, running `mkvextract timecodes_v2 video.mkv 1:timecodes.txt` on a file recently gave me output like Code:
999749 999790 999832 999874 999916 999957 999999 1.00004e+006 1.00008e+006 1.00012e+006 1.00017e+006 1.00021e+006 Is there a command-line option or something for mkvextract that tells it to just output regular numbers instead of the scientific ones? If not, can we get one in mkvtoolnix 2.4.2? |
8th December 2008, 23:52 | #684 | Link |
lost program in the net
Did you send them the file in question so they can fix it? The email address is newvirus@kaspersky.com; just use "Possible false-positive" as header. Their support in this regard is pretty good, all my reports were taken care of in less than 24h.
P.S. My Kaspersky remained completely silent. |
9th December 2008, 00:21 | #685 | Link | |
MKVToolNix author
9th December 2008, 00:22 | #686 | Link | |
MKVToolNix author
10th December 2008, 20:29 | #688 | Link |
is it possible some how to mux not fully encoded audio file? example:
ffmpeg -i audio.wav -acodec ac3 -ab 640k audio.ac3 and then encoding starts run this mkvmerge -o new_video.mkv old_video.mkv audio.ac3 so mkvmerge mux everything at speed of conversion of audio to ac3 |
10th December 2008, 21:01 | #690 | Link |
MKVToolNix author
No, mkvmerge requires all files to be finished and seekable (meaning that it will never support reading files via other protocols, e.g. ftp or http).
12th December 2008, 03:41 | #692 | Link |
The "splitting" feature works very well. But is it possible to end up with just 1 output-file (instead of at least 2)?
If for example I would only be interested in 20 minutes in the middle of a video (everything coming before and after, I would like to leave out). Thanks. |
12th December 2008, 09:49 | #693 | Link |
MKVToolNix author
No, that's not possible at the moment, and I don't think I'll implement something like that anytime soon.
12th December 2008, 13:00 | #694 | Link |
Hi
I have been using mkvmerge to create my video and flac audio mkv's. They play perfectly fine on the pc, but, when I use java playstation media server to stream them across, I always get stutter every 1 second. I have asked the question to the developer of the java streaming tool, and awaiting his reply, I just wanted to make sure I was not doing anything wrong when creating the mkv in the first place. As this stutter occurs with any mkv file I create only when streaming. Any ideas why this could be happeneing? I set the correct framerate for the elementary stream, correct aspect ratio, add the audio flac file and mux. All ok until i want to stream it. |
14th December 2008, 09:15 | #695 | Link |
Sleepy overworked fellow
How could I insert mkv files in another one, without appending them? I've seen this before... but I don't have the slightest idea how the chapters and file linking methods were combined.
Practical usage: Episode start - Opening - Episode - Ending - Preview Since "Opening" and "Ending" are the same for the whole series, I'd like to encode them only once and link them in the episodes to reduce overall size. Code:
Timecode example (random numbers, it's just for the concept): 3 files to link : Episode, Opening, Ending 00:00-02:00 (Episode 00:00-02:00) 02:00-03:30 (Opening 00:00-01:30) 03:30-23:30 (Episode 02:00-22:00) 23:30-25:00 (Ending 00:00-01:30) 25:00-26:00 (Episode 22:00-23:00) Thanks for any input.
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
14th December 2008, 10:58 | #696 | Link |
I don't know if it's possible, however can you add the possibility to add black boarders during playing? I think so it could be possibile to append stream with different resolution in the same container.
I am ripping The Dark Knight BD and I don't want to waste bitrate in the useless black boarders just for few IMAX scenes (but I don't want to cut them either XD), with these solution I could simply add boarders with a container option only when they are needed to not deform correct aspect ratio. Last edited by Snake91; 14th December 2008 at 11:06. |
14th December 2008, 13:41 | #697 | Link |
I have a feature request: Could it be possible to include support for having both chapters and tags in the same .xml file?
The reason why I'm asking is because it's annoying that you can't give editions names in the chapters file, you have to do it with a separate tags file. So if it was possible to have a file like this: Code:
<?xml version='1.0' encoding='UTF-8'?> <!-- <!DOCTYPE Tags SYSTEM 'matroskatags.dtd'> --> <Chapters> <EditionEntry> <EditionFlagOrdered>1</EditionFlagOrdered> <EditionFlagHidden>0</EditionFlagHidden> <EditionFlagDefault>1</EditionFlagDefault> <EditionUID>500030138</EditionUID> <ChapterAtom> [...] </Chapters> <Tags> <Tag> <Targets> <EditionUID>500030138</EditionUID> <TargetTypeValue>50</TargetTypeValue> </Targets> <Simple> <Name>TITLE</Name> <String>Normal</String> <TagLanguage>eng</TagLanguage> <DefaultLanguage>1</DefaultLanguage> </Simple> </Tag> [...] </Tags>
Where did neuron1 go? | Doom10 |
14th December 2008, 19:23 | #698 | Link | |
17th December 2008, 02:15 | #699 | Link |
I ran into this today and just wanted to report it. The "Save command line" doesn't save the command line. It only saves this
"mkvmerge" -o "" I guess I would ask for a feature where the command line stuff gets updated as the UI is used so it wouldn't be necessary to show the command line first and then saving it. It would also be nice to clear it when removing all content. Thanks much for considering this.
Chumbo |
17th December 2008, 08:32 | #700 | Link | |
MKVToolNix author
http://www.bunkus.org/videotools/mkv...20081217-48.7z
