5th June 2005, 21:08 | #122 | Link |
Deleted the .vaf, and didn't get that error anymore. However, about a third of the way through the encode, CCE gives an error and says encoding failed. If I click OK, it jumps almost to 80% and continues - and then a little later, you get another encoding failed message, and the progress meter jumps further.
I finally just gave up and installed 2.67 - everything seems to work great with this version. Not sure if I've got some whacked registry pieces or what. Seems like I just reloaded this damned machine. Thanks for the help - glad to be using BEM2V finally! |
7th June 2005, 10:07 | #123 | Link | |
sorry to jump to an old topic about batchencodem2v but... is it normal that it keeps on saying me
pls note: ccefront is in c:\progs\dvdrip\ccefront (even the ini is there) while batchencodem2v is in c:\progs\dvdrip\batchencodem2v any clue? thanks Gemon |
11th June 2005, 19:28 | #124 | Link | |
Wewkiee
...yeah...but...why on earth would I compare apples with apples? |
25th June 2005, 14:49 | #125 | Link |
Wewkiee
ccefront is now supported in batchccews. please use that instead... it ties into ccefront a different(better) way. i may change batchencode to do it the same way but intend to work mostly on batchccews, so likely not.
