Old 25th February 2016, 19:56   #41  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
LoRd_MuldeR update their upload at post http://forum.doom9.org/showthread.ph...72#post1757872 , I think is already patched now.
Is correct?
Nope. But I can do a full re-build with the patch included, if anybody can confirm that the problem does actually exist in the build without the patch and that is was fixed in the patched build.
Old 7th May 2016, 22:06   #42  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, has opus mode lossless? If not, will it be implement any day? Thanks
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 7th May 2016, 22:46   #43  |  Link
mariush
If you want lossless, use FLAC. It's standardized, fast and supported on lots of devices.
mariush is offline   Reply With Quote
Old 8th May 2016, 14:17   #44  |  Link
Overdrive80
Anime addict
I know flac, but my question is for other reason... I want compare that encoder lossless is more efficient (in terms of compression factor) if opus would have mode lossless.
Old 8th May 2016, 17:00   #45  |  Link
Brazil2
Originally Posted by Overdrive80 View Post
I want compare
http://wiki.hydrogenaud.io/index.php...ess_comparison
https://en.wikipedia.org/wiki/Compar...coding_formats
Brazil2 is offline   Reply With Quote
Old 19th May 2016, 10:25   #46  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Opus would not be suitable in any way as a lossless codec. It works as well as it does because it generates a lot of fake (but close enough) data, like HE-AACv2 but even deeper and extended all the way to perceptually lossless. Codecs designed from the ground up for lossless are much better at it, and neither of Opus's are.
Old 22nd May 2016, 13:42   #47  |  Link
LoRd_MuldeR
Software Developer
libopus v1.1.x-git / opus-tools v0.1.9 [2016-05-22]
FWIW, here's another set of fresh Opus v1.1.x binaries:
opus-tools.2016-05-22.zip
Old 22nd May 2016, 13:54   #48  |  Link
LoRd_MuldeR
Software Developer
Yeah, lossy and lossless audio formats work quite differently.
All the "lossless" audio codecs I know work in time domain. These codecs pretty much come down to: The encoder predicts the next sample value using some fancy prediction function and then transmits the delta (difference) to the actual sample value. The decoder performs the same prediction and then adds the transmitted delta value, in order to restore the original sample value. This is how FLAC, Monkey's Audio and friends work. Easy to see why this is lossless.
"Lossy" codes, on the other hand, typical work in frequency domain. First step is to transform the input samples from time domain into frequency domain. Then Psy-modelling is used to decide which frequency bands get more bits (e.g. more fine-grained quantization) and which get less bits (e.g. more coarse quantization). This is how MP3, AAC and friends work. The transform to the frequency domain and the inverse transform), which are typically done in floating-point math, probably already causes rounding errors that make the whole process non-lossless. And the quantization certainly makes it lossy. You could leave out the quantization, yes. But then compression probably sucks, because entropy coding won't save any bits.
Old 22nd May 2016, 19:21   #49  |  Link
Motenai Yoda
Motenai Yoda's Avatar
Well DTS-MA and TrueHD should work, even if in part, in the frequency domain.
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 22nd May 2016, 19:24   #50  |  Link
Brazil2
Thanks for this
Just a little question though:
Previous version reported:
opusenc opus-tools v0.1.9-git SSE2 [2016-02-20] (using libopus 1.1.2-git SSE2 [2016-02-20])
While the new version reports:
opusenc opus-tools v0.1.9-git SSE2 [2015-05-22] (using libopus 1.1.x-git SSE2 [2015-05-22])
I assume libopus 1.1.2 is still used ?
Old 22nd May 2016, 19:43   #51  |  Link
LoRd_MuldeR
Software Developer
I built latest Git "master" branch. So this is actually post v1.1.2 release
(I have no idea whether the next release will be v1.1.3 or v1.2.0 or v2.0.0, but currently PACKAGE_VERSION says "1.1.x-git")
Old 22nd May 2016, 21:28   #52  |  Link
Brazil2
Thanks for the precision
Old 18th July 2016, 16:37   #53  |  Link
IgorC
Some news
Version 1.1.3 released
https://www.opus-codec.org/
Neon optimizations improving performance on ARMv7 and ARMv8 by up to 15%
Fixes some issues with 16-bit platforms (e.g. TI C55x)
Fixes to comfort noise generation (CNG)
Documenting that PLC packets can also be 2 bytes
Includes experimental ambisonics work (--enable-ambisonics)
Work in progress 1.2 (quality improvements)
IgorC is offline   Reply With Quote
Old 5th August 2016, 22:44   #54  |  Link
Reino
Reino's Avatar
LoRd_MuldeR, could you compile a set of fresh post v1.1.3 binaries?
My hobby website
Reino is offline   Reply With Quote
Old 6th August 2016, 04:17   #55  |  Link
Motenai Yoda
Opus 1.1.3 compiled with mediaautobuild suite (gcc 6.x), x64 only
http://filenurse.com/download/b70a58...788595f62.html
link will expire in a week
Old 29th August 2016, 05:29   #56  |  Link
filler56789
SuperVirus
filler56789's Avatar
Another up-to-date build of OpusTools
[compiled with GCC 4.8.5]
[C:\]
=> opusenc --version
opusenc opus-tools 0.1.9-24-g746e2af (using libopus 1.1.3)
Copyright (C) 2008-2013 Xiph.Org Foundation
http://forum.videohelp.com/threads/3...-3-for-Windows
filler56789 is offline   Reply With Quote
Old 3rd September 2016, 12:31   #57  |  Link
hajj_3
I hope that the opus developers concentrate on low bitrate audio as xhe-aac is far superior at 12-64kbps. Some digital radio platforms like DRM have support for this.
Old 3rd September 2016, 13:14   #58  |  Link
Gravitator
Привет.
What improvement noticed through ambisonics?
Gravitator is offline   Reply With Quote
Old 7th September 2016, 03:39   #59  |  Link
IgorC
Last time I have tried Opus 1.1 at 64 kbps it was superior to best HE-AAC encoders 64 kbps and on par with xHE-AAC. Opus 1.1 was inferior to HE-AAC at 48 kbps.
But the situation is changing now. Several months ago Opus 1.2 (early alpha) was already at least on par or somewhat better than HE-AAC at 48 kbps.
Also xHE-AAC is a great format its main scope is 12-32 kbps.
Its performance is very close to normal HE-AAC at 48-64 kbps.
You can easily confuse xHE-AAC and highestly optimized HE-AAC (such as Fraunhofer Winamp's encoder) at 64 kbps.
It's very likely that upcoming Opus 1.2 will be at least on par with xHE-AAC at bitrates 48 kbps and higher. It also to expect a reasonable quality from it at 32-40 kbps.
Old 8th September 2016, 01:53   #60  |  Link
Motenai Yoda
IIRC opus did some stuff on the lbr branch
did you compare opus vs hev2 or vs hev1 coz seems hev2 is still a bit better on 32-48kbps
