5th May 2012, 12:48 | #7441 | Link |
Suspended for forum rule violations
Workaround:
Create MultiAVCHD compilation. In the "Title name: PART 1" or whatever your title is named. Fire up the output in your media player. Take full size screendumps of each background menu title, in my project 3 titles. Use your image editing software and open the 3 different screendumps. Create 3 new title text layers with the font you want to use, (the font that MultiAVCHD couldn't display). Align the new title text layers where you want them, on top of each MultiAVCHD title text screendump. Open MultiAVCHD and import the 3 new background images, one for each title. Works like a charm! Problem solved! Lots of creative fun! Regards |
6th May 2012, 17:11 | #7442 | Link |
I decided to put some DVD series on a single BD, for laziness.
I did this once and it worked ok. I tried today, after a long pause, to repeat the performance. My findings: no audio delay considered when there is one (the first BD had all at 0 this is why I haven't noticed it) most subtitles were not recognized (like importing 24/781) - again due to the lack of subtitles in the previous BD I couln't notice it It appears that this subject was not addressed, no audio delay on DVD appeared on this forum in junction with multiavchd. Any ideas? PS: I tried to recover the subtitles from a correctly remuxed episode (apart from the audio delay) but tsmuxer upscaled them to 1080p24 from 576i50 when instructed to demux them. Go figure
Born in the USB (not USA) |
7th May 2012, 14:15 | #7443 | Link |
Since tsmuxer fails on some mkv files and not all I assume that they are cinavia protected and can't be converted? Is there a way to convert cinavia protected .mkv files using multiavchd?
7th May 2012, 17:38 | #7444 | Link |
@laz305
Hi! Cinavia in no way interferes with or limits copying or converting any type of file(s). Cinavia's "claim to fame" is that if you copy a disc that contains Cinavia protection, any and all copies that you make will also contain Cinavia. |
8th May 2012, 08:15 | #7450 | Link | |
I used the old school approach, I demuxed all the streams of all the episodes with pgcdemux (noted the delays), I converted by hand all the subtitles to BD SUPs with BDsub2sup, reimported in multiavchd, again by hand, one by one, and set the corresponding audio delays. So far so good. But the audio delay issues have been not solved. I don't have right now the paper, but the first episode had a 0ms delay, now 0ms, the second had again 0ms, after remuxing it had -80ms, the third had 424 before, some 360 after, another one had -8ms, after -80ms and so on. It looks like something like -80ms rounded to the next integer has automatically been added. The episodes come from commercial DVDs so authoring or encoding errors may safely be excluded. Searches in this forum revealed that both tsmuxer and multiavchd can cope with delays. I am now confused about the actual cause .... and solution
8th May 2012, 17:25 | #7453 | Link | ||
@laz305
8th May 2012, 20:42 | #7454 | Link | |
10th May 2012, 20:03 | #7455 | Link |
I've tried goSUP, the one included in multiAVCHD and I downloaded the standalone one. When I open it up, I click on a .srt file and then click convert and it always comes back with the current time stamp and the message, Nothing to do! easySUP works fine on the same srt file, so I'm sure the file isn't corrupt. Anyone have any ideas what is going on?
15th May 2012, 19:57 | #7456 | Link |
with the latest multiavchd, When I added an additional audio track, it showed up in a new tab "other audio" and it did not get muxed with m2ts? whats that about??
A quick search on forums showed this: So, could someone tell me the proper method to mux in a new audio? I have a BD with only LPCM - I encoded a DTS and am trying to add/mux to the same disk in re-author mode. |
15th May 2012, 21:40 | #7457 | Link | |
NY Frame of Mind
I don't know how you encoded the DTS, but I'm assuming that you used DTS Master Audio Suite and encoded the lpcm individual wavs to either DTS-HD or standard DTS ? If this is the case, you can't enter the *.dtshd (or *.cpt) track directly into multiavchd. You have to demux first with tsmuxer, to remove the extraneous hex entries. Not sure where the "other audio" tab came from. Click on the properties of the appropriate m2ts and you will see the dialog box below. With the "audio" tab visible, click add (red circle #1). An explorer will pop up, navigate to the audio track you want to add, highlight and click OK. In this case I added the DTS-HD and pressed the "up" button to move it to the first position, so it's the default audio track. You can also "remove" any unwanted audio in this tab. I also "blank" out any warnings or other umwanted material at this time. Click OK (circled red #2) and this dialog will close and the main screen appears. Press "start" and the processing will begin. Takes about 15-20 min to complete.
"Talk to me Goose" Last edited by rapscallion; 15th May 2012 at 22:02. Reason: added info |
16th May 2012, 00:22 | #7458 | Link | |||||
16th May 2012, 15:00 | #7459 | Link | ||
NY Frame of Mind
The only time you would do it this way is if you were remuxing so that the intended result was the movie file only, with no menus, extras, etc. Quote:
The DTS MAS software creates files with an extra 140 bytes of header information at the beginning of the files. This is done so studio authoring house software recognizes the file/header as DTSHD. It's stripped out in the resulting, final audio track that's on a BD disc. Fortunately, Tsmuxer strips it out as well, during the demux process.
"Talk to me Goose" Last edited by rapscallion; 16th May 2012 at 17:38. Reason: added info |
16th May 2012, 17:23 | #7460 | Link | |
