18th November 2015, 11:49 | #14001 | Link | ||
Can't seem to get it to work though, "show log" by right clicking the job and then selecting it doesn't seem to work here, am on Windoiws 10 though have made sure to run as Admin. Also, just doing a test with the standard base profiles with no modification at CRF 18 for HEVC/10bit, encoding goes fine at expected file size, but muxing produces a file that keeps on growing and never completes. Stopped it at 720GB! Any idea, thanks. (Sorry should have saved the mux output command fished out of temp folder) Quote:
20th November 2015, 06:54 | #14004 | Link |
Before I encode too many DVDs incorrectly (I've primarily done blurays in the past and interlaced material isn't an issue).
I'm ripping some older stuff that is interlaced. Want to make sure I'm doing this correctly. I've been opening the VOB in DGIndex. ------------------------------- If VOB is: Frame Rate: 23.976024 fps Frame Rate: Interlaced Field Order: Top Then in Ripbot Use: Deinterlace: TTF -> 29.97 FPS Decimate: Do not decimate (because the frame rate is already 23.976024?) ------------------------------- If VOB is: Frame Rate: Anything besides 23.976024 fps Frame Rate: Interlaced Field Order: Top Then in Ripbot Use: Deinterlace: Inverse Telecine Decimate: Restore -> 23.976 fps ------------------------------- Is this right? |
20th November 2015, 09:19 | #14005 | Link | |
And even when setting the Field Operation as Honor Pulldown Flags and it shows as 29.97fps and Interlaced, it's still no indication of how your DVD should be handled. For that you make a basic AviSynth script, open it in VDub to check, and use your eyes to tell. And if you know enough to make an AviSynth script and use Forced Film or Honor Pulldown Flags to make a D2V Project File, or IVTC or unblend or deinterlace, then my opinion is that you should do those things in a script which you then open in RipBot. These things are thoroughly explained in the docs included in the DGMPGDec package. All NTSC DVDs output interlaced 29.97fps (really 59.94 fields per second). Last edited by manono; 20th November 2015 at 09:22. |
20th November 2015, 14:23 | #14006 | Link |
Hi Atak,
I just would like to told you Thank You very much for adding multi-languages support in Ripbot264 ! It's helped me a lot! Save time and calculations. Also, i seen that Software has auto update when starting the app. Thums Up ! Great Work ! 8ternity
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
20th November 2015, 17:30 | #14007 | Link | |
I've read a ton on this prior to posting what you responded to, thinking I finally figured it out, there are no guides on how to specifically determine everything about your source, and then based on certain results you use these certain settings for Ripbot. I thought I found an easily understandable guide (something that didn't assume you had advanced technical understanding to start) and based on your quote it's incorrect (thehtpc.net/htpc-tips-and-tweaks/encoding-dvds-to-h-264-mkv-using-ripbot264/). For several of my Interlaced VOBs if I do TFF -> 29.97 or Inverse Telecine with and without decimate restore on, the resulting "preview scripts" all look the same to me. They look good but I can't have 4 different options all be the correct way to do it, and I don't know how to determine which is correct if they all look good. There is no easy guide for dealing with Ripbot and interlaced sources, but I'll keep reading. |
20th November 2015, 19:55 | #14008 | Link |
@essential
It is quite easy. If ripbot shows that your DVD movie has been detected as 29.97 fps then you should manually examine frames in "preview script". Ofcourse deinterlace option must be OFF! In Media Player Classic use arrows on keyboard to skip to next frame. If you see mix of progressive and interlaced frames then you should use INVERSE TELECINE + RESTORE 23.976 option. Normally pattern looks like this: 3 Progressive frames 2 Interlaced frames If you see only interlaced frames then use TFF -> xx.xx fps.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th November 2015 at 20:50. |
20th November 2015, 20:34 | #14009 | Link | ||
In addition, he is confusing anyone reading it by mixing up terms. There's a big difference between a full IVTC, decimating, and deinterlacing. If you have a video like that in the pictures above, what you do is IVTC, not deinterlace. And decimating is only the second step in the two-step IVTC process, the first being field-matching. |
20th November 2015, 21:00 | #14010 | Link | |
edit: Thanks Manono, you posted while I was replying. Last edited by essential; 20th November 2015 at 21:04. Reason: added manono |
20th November 2015, 21:45 | #14011 | Link | |
Like I said. Use Deinterlacer (TFF -> ) only if ALL frames are interlaced (no mix).
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th November 2015 at 21:48. |
25th November 2015, 08:45 | #14013 | Link |
hai atak.. may i know how to fix this one problem??cannot load AAC audio.. thanks..
http://i.imgur.com/vDhH32B.png |
26th November 2015, 15:14 | #14014 | Link |
yes . in cq mode chunks are always 1 min long.
26th November 2015, 18:28 | #14015 | Link |
More work for servers = less idle time = overall faster encoding
30th November 2015, 16:15 | #14016 | Link |
Atak
Great app -- just found this last week and so far, it has worked like a champ. I especially like the simplicity of the GUI, yet it is powerful where it needs to be. I had been using handbrake previously and find this far more effective -- esp. the batch mode. Two questions -- 1. In batch mode -- is there any way to set a default for color correction to go in one of the three choices vs. the none default? Specifically, I'm wanting to set mine up to default for color correction from tv->pc. This is due to several home recorded DVDs from a DVD recorder that had a black level color bug -- this setting mostly corrects that issue in corresponding encodes. Obviously, in batch, I can go into each corresponding entry and manually make the change prior to encode -- I was just hoping to automate that as much as possible and eliminate redundant clicks. I didn't know if there was a setting inside of one of the scripts that I could edit that would do this (vs. asking for a setting within the GUI).... 2. Probably a stupid question, but one I would throw out. Can you set up DE to operate on just one machine? I've gone through quite a bit of this thread to look for an answer to that -- it appears that you could, but not clear on how to specifically do that. Is it as simple as adding my ip address to the DE listing, with a :1000, :2000, etc. So, if my ip address is say 10.45.3.1 then I set up the server addresses starting with 10.45.3.1:1000, 10.45.3.1:2000, etc. I tried that, but I could not get the servers moving (they just remained "idle"). I'm sure I am doing something stupid wrong, and just need to tinker with it more to get it to work -- but thought I would ask that it is possible before spending too much time. Thanks again and thanks for the great app. g Sent from my iPad using Tapatalk |
30th November 2015, 18:52 | #14017 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 30th November 2015 at 18:56. |
30th November 2015, 23:37 | #14018 | Link | |
I guess its because I'm using a "real" IP address. Last edited by burt123; 1st December 2015 at 01:44. |
1st December 2015, 01:58 | #14019 | Link |
Batch encode & subtitles
Tried searching for this, but can't seem to find a definitive answer... Is there a straightforward way to add/include subtitles to all files when using batch encode, rather than having to add each file manually if subtitles are needed? Can you batch rip all or selected subtitles for each file at the same time as preparing a file? Sorry if this is obvious!
Appreciate any help! Last edited by 00-00; 1st December 2015 at 02:02. |
1st December 2015, 13:23 | #14020 | Link |
Atak
Thanks -- adding the color option to the batch mode would be a big time saver for me. I have it on auto update -- so look forward to the next update. I'll see if i can get the DE to work later this week when I have time to poke around with it. Thanks again! g Sent from my iPad using Tapatalk |
