11th July 2011, 13:11 | #13801 | Link | |
I can reproduce this issue in graphstudio and mediaportal too. With different source splitter (Haali/LAV/MPC Matroska), i made my test on mkv. On the all combination (all crash when i remove FFDShow DXVA): http://dl.dropbox.com/u/10536084/FFD...VA_FFDShow.jpg http://dl.dropbox.com/u/10536084/FFD...VA_FFDShow.jpg http://dl.dropbox.com/u/10536084/FFD...VA_FFDShow.jpg I do like Hoborg, set EVR Renderer as High merit to be the one loaded first. If we disconnect output pin of FFDShow DXVA before remove filter = no crash This is strange that you can't get it. Thanks.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 11th July 2011 at 19:02. |
11th July 2011, 17:32 | #13802 | Link |
Hi.
I noticed there is an ugly pixelation on some h.264 video streams if FFDShow DXVA decoder is in use. This pixelation wasn't here before, so i did some research. I tracked down that the relase 3883 introduce the pixelation, becouse 3882 is ok. Here is video sample. Normal FFDshow video decoder is not affected.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 11th July 2011 at 21:35. |
11th July 2011, 20:31 | #13803 | Link |
Sample link is broken.
MPC-HC 2.1.7.2 |
11th July 2011, 21:35 | #13804 | Link |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 12th July 2011 at 12:28. |
11th July 2011, 23:55 | #13805 | Link |
The following CVID in MOV container is still not working with current LAVFilter and ffdShow:
http://www.mediafire.com/?1nr37wujo5g8c65 See this posting for more details. |
12th July 2011, 22:23 | #13806 | Link |
@hoborg
DXVA decoding issue is fixed. @Sven75 Decoding with the Cinepak VFW codec of Windows is fine too. I don't know what is wrong, so you have to ask nevcariel to check what changed in ffmpeg.
MPC-HC 2.1.7.2 |
13th July 2011, 06:03 | #13807 | Link |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
13th July 2011, 09:22 | #13808 | Link |
もこたんインしたお!
libavcodec/h261.c libavcodec/h261dec.c libavcodec/h261dec.c: In function 'h261_decode_frame': libavcodec/h261dec.c:623:1: error: 'Picture' has no member named 'pict_type' libavcodec/h261dec.c:623:1: error: 'Picture' has no member named 'pict_type' libavcodec/h261dec.c:624:1: error: 'Picture' has no member named 'pict_type' make: *** [../../obj/MinGW32/ffmpeg/libavcodec/h261dec.o] Error 1
[I'm human, no debug]
14th July 2011, 10:23 | #13809 | Link |
Some ffdshow crash that I'm getting in VirtualDub:
VirtualDub crash report -- build 34610 (release) -------------------------------------- Disassembly: 6d1b0e00: 140f adc al, 0fh 6d1b0e02: 85f9 test ecx, edi 6d1b0e04: fd std 6d1b0e05: ff db 0ffh 6d1b0e06: ff83c4205b5e inc dword ptr [ebx+5e5b20c4] 6d1b0e0c: 5f pop edi 6d1b0e0d: 5d pop ebp 6d1b0e0e: c3 ret 6d1b0e0f: 90 nop 6d1b0e10: 55 push ebp 6d1b0e11: 57 push edi 6d1b0e12: bf08000000 mov edi, 00000008 6d1b0e17: 56 push esi 6d1b0e18: 89fe mov esi, edi 6d1b0e1a: 53 push ebx 6d1b0e1b: 83ec24 sub esp, 24h 6d1b0e1e: 8b5c244c mov ebx, [esp+4ch] 6d1b0e22: 8b6c2448 mov ebp, [esp+48h] 6d1b0e26: 8b4c2438 mov ecx, [esp+38h] 6d1b0e2a: 8b542440 mov edx, [esp+40h] 6d1b0e2e: 29df sub edi, ebx 6d1b0e30: 29ee sub esi, ebp 6d1b0e32: 89f8 mov eax, edi 6d1b0e34: 0fafc6 imul eax, esi 6d1b0e37: 0faffd imul edi, ebp 6d1b0e3a: 0faff3 imul esi, ebx 6d1b0e3d: 0fafdd imul ebx, ebp 6d1b0e40: 8b6c2444 mov ebp, [esp+44h] 6d1b0e44: 89442408 mov [esp+08h], eax 6d1b0e48: 897c240c mov [esp+0ch], edi 6d1b0e4c: 89742410 mov [esp+10h], esi 6d1b0e50: 85ed test ebp, ebp 6d1b0e52: 895c2414 mov [esp+14h], ebx 6d1b0e56: 0f8ea7020000 jle 6d1b1103 6d1b0e5c: 8b44243c mov eax, [esp+3ch] 6d1b0e60: 89d6 mov esi, edx 6d1b0e62: c7442418000000 mov dword ptr [esp+18h], 00000000 00 6d1b0e6a: f7de neg esi 6d1b0e6c: 8d742600 lea esi, [esi+00h] 6d1b0e70: 0fb638 movzx edi, byte ptr [eax] 6d1b0e73: 0faf7c2408 imul edi, [esp+08h] 6d1b0e78: 897c2404 mov [esp+04h], edi 6d1b0e7c: 0fb67801 movzx edi, byte ptr [eax+01h] 6d1b0e80: 0faf7c240c imul edi, [esp+0ch] 6d1b0e85: 897c241c mov [esp+1ch], edi 6d1b0e89: 0fb66c1001 movzx ebp, byte ptr [eax+edx+01h] <-- FAULT 6d1b0e8e: 01d0 add eax, edx 6d1b0e90: 8d1c30 lea ebx, [eax+esi] 6d1b0e93: 891c24 mov [esp], ebx 6d1b0e96: 0fb639 movzx edi, byte ptr [ecx] 6d1b0e99: 0faf6c2414 imul ebp, [esp+14h] 6d1b0e9e: 897c2420 mov [esp+20h], edi 6d1b0ea2: 0fb63c13 movzx edi, byte ptr [ebx+edx] 6d1b0ea6: 0faf7c2410 imul edi, [esp+10h] 6d1b0eab: 8d7c3d1c lea edi, [ebp+edi+1ch] 6d1b0eaf: 8b6c2420 mov ebp, [esp+20h] 6d1b0eb3: 037c2404 add edi, [esp+04h] 6d1b0eb7: 037c241c add edi, [esp+1ch] 6d1b0ebb: c1ff06 sar edi, 06h 6d1b0ebe: 8d7c3d01 lea edi, [ebp+edi+01h] 6d1b0ec2: d1ff sar edi, 1 6d1b0ec4: 89fb mov ebx, edi 6d1b0ec6: 0fb67901 movzx edi, byte ptr [ecx+01h] 6d1b0eca: 8819 mov [ecx], bl 6d1b0ecc: 8b1c24 mov ebx, [esp] 6d1b0ecf: 897c2404 mov [esp+04h], edi 6d1b0ed3: 0fb66c1302 movzx ebp, byte ptr [ebx+edx+02h] 6d1b0ed8: 0fb67c1301 movzx edi, byte ptr [ebx+edx+01h] 6d1b0edd: 0faf6c2414 imul ebp, [esp+14h] 6d1b0ee2: 0faf7c2410 imul edi, [esp+10h] 6d1b0ee7: 8d7c3d1c lea edi, [ebp+edi+1ch] 6d1b0eeb: 0fb66c3001 movzx ebp, byte ptr [eax+esi+01h] 6d1b0ef0: 0faf6c2408 imul ebp, [esp+08h] 6d1b0ef5: 8d2c2f lea ebp, [edi+ebp] 6d1b0ef8: 0fb67c3002 movzx edi, byte ptr [eax+esi+02h] 6d1b0efd: 0f db 0fh 6d1b0efe: af scasd 6d1b0eff: 7c db 7ch Built on Althena on Sat Jun 18 14:40:53 2011 using compiler version 1400 Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3] Memory status: virtual free 1942M/2048M, commit limit 4967M, physical total 2046M EAX = 02a9ce50 EBX = 00000081 ECX = 01d75ed0 EDX = 000001b0 EBP = 0000205c ESI = fffffe50 EDI = 00000000 ESP = 0012f6e8 EIP = 6d1b0e89 EFLAGS = 00010296 FPUCW = ffff027f FPUTW = ffffaaaa Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'ffmpeg'... ...reading address 02A9D001. Pointer dumps: EAX 02a9ce50: 81818181 81818181 81818181 81818181 83838383 83838383 83838383 83838383 ECX 01d75ed0: 81818181 81818181 81818181 81818181 83838383 83838383 83838383 83838383 ESP 0012f6e8: 02a9cca0 00002040 00000040 00000000 00000000 00000000 00000007 00000000 0012f708: 00000081 01c962a0 00000000 01cb25c0 00000000 6d1a29b2 01d75300 02a9c280 0012f728: 000001b0 00000008 00000000 00000000 00000000 fffff4c4 00000000 fffff884 0012f748: 00000000 00000000 00000000 00000000 000002c0 01d160e0 00006428 000002c0 Thread call stack: 6d1b0e89: ffmpeg!av_vc1_decode_frame [6d000000+1ade00+3089] 6d1ab778: ffmpeg!avcodec_default_get_buffer [6d000000+19cb70+ec08] 016dcde0: ffdshow!configureEnc [01590000+1013b0+4ba30] 016dcd20: ffdshow!configureEnc [01590000+1013b0+4b970] 6d2204ef: ffmpeg!av_vc1_decode_frame [6d000000+1ade00+726ef] 6d147a8f: ffmpeg!av_h264_decode_frame [6d000000+a8b50+9ef3f] 6d078f29: ffmpeg!avcodec_get_encoder_info [6d000000+71030+7ef9] 6d1ad0c8: ffmpeg!avcodec_default_get_buffer [6d000000+19cb70+10558] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c92019b: ntdll!RtlAllocateHeap [7c910000+100c4+d7] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c92019b: ntdll!RtlAllocateHeap [7c910000+100c4+d7] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c920222: ntdll!RtlAllocateHeap [7c910000+100c4+15e] 7c92019b: ntdll!RtlAllocateHeap [7c910000+100c4+d7] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 6d19c421: ffmpeg!avcodec_decode_video2 [6d000000+19c390+91] 017be45c: ffdshow!configureEnc [01590000+1013b0+12d0ac] 016d57f8: ffdshow!configureEnc [01590000+1013b0+44448] 7e383416: USER32!EditWndProc [7e360000+23000+416] 7c9200b8: ntdll!RtlFreeHeap [7c910000+ff2d+18b] 7c920041: ntdll!RtlFreeHeap [7c910000+ff2d+114] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 7c9200b8: ntdll!RtlFreeHeap [7c910000+ff2d+18b] 7c920041: ntdll!RtlFreeHeap [7c910000+ff2d+114] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 7c920041: ntdll!RtlFreeHeap [7c910000+ff2d+114] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 7c9200b8: ntdll!RtlFreeHeap [7c910000+ff2d+18b] 7c920041: ntdll!RtlFreeHeap [7c910000+ff2d+114] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 7c9200b8: ntdll!RtlFreeHeap [7c910000+ff2d+18b] 7c920041: ntdll!RtlFreeHeap [7c910000+ff2d+114] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 017cbd66: ffdshow!DllGetClassObject [01590000+236d60+5006] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 017cec6a: ffdshow!DllGetClassObject [01590000+236d60+7f0a] 017bee3a: ffdshow!configureEnc [01590000+1013b0+12da8a] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 017bf071: ffdshow!configureEnc [01590000+1013b0+12dcc1] 7c92005d: ntdll!RtlFreeHeap [7c910000+ff2d+130] 017cbd66: ffdshow!DllGetClassObject [01590000+236d60+5006] 017bf1dd: ffdshow!configureEnc [01590000+1013b0+12de2d] 00c52ed1: ff_vfw!DriverProc [00c50000+2c40+291] 75ec1938: MSVFW32!ICSendMessage [75ec0000+190d+2b] 75ec4df4: MSVFW32!ICDecompress [75ec0000+4db7+3d] 10005d0a: WMV!VDGetPluginInfo [10000000+4010+1cfa] 10005ed2: WMV!VDGetPluginInfo [10000000+4010+1ec2] 004eb8c4: VDVideoSourcePlugin::streamGetFrame() 0043bdc0: VDFilterFrameVideoSource::RunRequests() 00437965: VDFilterAccelUploader::RunRequests() 00447af2: FilterSystem::Run() 0046ff78: VDProject::UpdateFrame() 7e36882a: USER32!GetDC [7e360000+86c7+163] 7e3689cd: USER32!GetWindowLongW [7e360000+88a6+127] 7e3689ea: USER32!GetWindowLongW [7e360000+88a6+144] 7e37a43b: USER32!PeekMessageA [7e360000+1a340+fb] 00472ba3: VDProject::Tick() 0045facc: WinMain@16() 005e2df6: __tmainCRTStartup() 7c817077: kernel32!RegisterWaitForInputIdle [7c800000+1702e+49] -- End of report fccHandler WMV Plugin 2.5 for VirtualDub ffdshow tryouts 1.1.3919 Crashing file example: Code:
General Format : Windows Media File size : 335 MiB Duration : 30mn 55s Overall bit rate mode : Constant Overall bit rate : 1 514 Kbps Maximum Overall bit rate : 1 612 Kbps Encoded date : UTC 2011-07-06 20:54:49.364 Video ID : 2 Format : VC-1 Format profile : AP@L1 Codec ID : WVC1 Codec ID/Hint : Microsoft Description of the codec : VC-1 - VC-1 Advanced Profile Duration : 30mn 55s Bit rate mode : Constant Bit rate : 1 500 Kbps Width : 852 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.122 Stream size : 332 MiB (99%) Language : English (US) Audio ID : 1 Format : WMA Format version : Version 2 Codec ID : 161 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 9.2 - 96 kbps, 44 kHz, stereo 2-pass CBR Duration : 30mn 55s Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 21.2 MiB (6%) Language : English (US) Last edited by Dstruct; 14th July 2011 at 10:48. |
14th July 2011, 11:16 | #13810 | Link |
Does it also crash in DirectShow?
I doubt I can fix it, but please post a sample file anyway.
MPC-HC 2.1.7.2 |
14th July 2011, 13:43 | #13812 | Link |
ffdshow_rev3933_20110712_clsid.exe
問題簽章: 問題事件名稱: APPCRASH 應用程式名稱: mpc-hc.exe 應用程式版本: 1.5.2.3314 應用程式時間戳記: 4e110c47 錯誤模組名稱: ffmpeg.dll 錯誤模組版本: 0.0.0.0 錯誤模組時間戳記: 4e1b9114 例外狀況代碼: c0000005 例外狀況位移: 0024e3a0 作業系統版本: 6.1.7601.2.1.0.256.1 地區設定識別碼: 3076 其他資訊 1: 0a9e 其他資訊 2: 0a9e372d3b4ad19135b953a78882e789 其他資訊 3: 0a9e 其他資訊 4: 0a9e372d3b4ad19135b953a78882e789 |
14th July 2011, 14:52 | #13813 | Link |
Need more info. You did not even mention what kind of file it is.
If it only crashes with a particular file, then I need a sample.
MPC-HC 2.1.7.2 |
14th July 2011, 19:16 | #13815 | Link |
MPC-BE DEV
Hi! This happens when the video is done through NV12. When NV12, disabled, everything works without errors. I got it going on on any video files (avi, mkv, mpg, ts, ...). ffdshow x86/x64 rev. 3932, 3933, 3934, 3935, 3936, 3937.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
14th July 2011, 20:58 | #13816 | Link |
Fixed
MPC-HC 2.1.7.2 |
15th July 2011, 18:23 | #13818 | Link |
You need at least 4.4.0, or enable SSE.
MPC-HC 2.1.7.2 |
16th July 2011, 00:35 | #13820 | Link |
もこたんインしたお!
Use xhmikosr's base full msys/mingw package? And then get a 4.5.3 mingw package from either komisar or xvidvideo.ru (and use /etc/fstab to make another folder be mounted as /mingw) >_>
...or just use the included 4.6.1 if that works for you.
