Old 29th September 2012, 21:45   #11801  |  Link
Pratyatosa
Originally Posted by Chetwood View Post
Are you sure about this? I mean, it's been a while since I tested the O!Play but it's a Realtek player and they can handle multiple audio tracks, as do all WDTVs (Sigma chipset).
I could be wrong.
In any case, I haven't been able to figure out a way to switch to the 2nd audio track. If there is a way to do it, that would be great.
Pratyatosa is offline   Reply With Quote
Old 30th September 2012, 02:35   #11802  |  Link
burt123
burt123's Avatar
I must be missing something, but I can't get the WakeOnLan function to work.
I have set the NIC to wake up, and I have added the appropriate MAC address to the encoder ini.
Any help will be appreciated.
Cheers
burt123 is offline   Reply With Quote
Old 30th September 2012, 04:30   #11803  |  Link
GMJCZP
GMJCZP's Avatar
Hello Atak_Snajpera:
I was converting an AVI video with MP3 audio with this setup (from mediainfo):
General
Complete name : C:\video.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 49,2MB
Duration : 21min.
Overall bit rate mode : Variable
Overall bit rate : 314Kbps
Encoded date : UTC 2012-09-22 02:31:14
Tagged date : UTC 2012-09-22 02:31:14
Writing application : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Video
Format : AVC
Format profile : Main@L2.0
Format settings, CABAC : Si
Format settings, ReFrames : 3marcos
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 21min.
Bit rate mode : Variable
Bit rate : 246Kbps
Maximum bit rate : 260Kbps
Width : 512pixeles
Height : 384pixeles
Display aspect ratio : 4:3
Frame rate mode : Constante
Frame rate : 23,976fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8bits
Scan type : Progresivo
Bits/(Pixel*Frame) : 0.052
Stream size : 38,6MB (79%)
Title : video
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=3 / deblock=1:1:1 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=260 / vbv_bufsize=260 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:0.60
Encoded date : UTC 2012-09-22 21:47:31
Tagged date : UTC 2012-09-22 02:31:21
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : 40
Duration : 21min.
Bit rate : 64,5Kbps
Maximum bit rate : 72,2Kbps
Channel(s) : 2canales
Channel positions : Front: L R
Sampling rate : 44,1KHz / 22,05KHz
Stream size : 10,1MB (21%)
Encoded date : UTC 2012-09-22 02:31:20
And I noticed that the audio was cut at the end a bit. After several tests I used Yamb to separate and rejoin the tracks and the problem was solved. Please check if in the process of joining tracks (muxing) at the end of the video processing is the problem. Thank you.
Any response Atak_Snajpera?
To the third time lucky?
GMJCZP is offline   Reply With Quote
Old 30th September 2012, 06:27   #11804  |  Link
Chetwood
Chetwood's Avatar
Have you pressed the language key on the remote? The original model I tested isn't available anymore but the O!Play HD2's manual shows the button right above the navigation keys. Usually you can use this to cycle through all audio streams present in the file.
MultiMakeMKV: MakeMKV batch processing (Win)
MultiShrink
: DVD Shrink batch processing
Offizieller Übersetzer von DVD Shrink deutsch
Chetwood is offline   Reply With Quote
Old 30th September 2012, 13:17   #11805  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Cheers
1) Wakeup On LAN works only for wifi -> LAN or LAN -> LAN. Obviously it won't work for LAN -> Wifi
2) Your mainboard must support Wake up on lan (check bios settings)
3) more info about wake on lan http://en.wikipedia.org/wiki/Wake-on-LAN
Old 30th September 2012, 13:21   #11806  |  Link
Atak_Snajpera
Ripbot264 always trims audio / video for the same duration.
BEFORE:
Video : 59s
Audio : 60s
AFTER:
Video : 59s
Audio : 59s
Old 30th September 2012, 15:41   #11807  |  Link
soneca
I could be wrong.
Any decent media player is able to handle multiple audio a long time!
Normally also keep track dubbed in cartoons for the nephews, the WDTV and Dune read smoothly.
soneca is offline   Reply With Quote
Old 30th September 2012, 17:47   #11808  |  Link
rsotome
Is anyone else having any problems with misplaced subs, when queuing up several encodes?
For instance, I'll queue up several movies/tv shows, etc, and sometimes the subs will be replaced with the subs from the next encode job, and sometimes vice versa, so in the end, some videos will have the wrong subs. I do check the settings before starting, and everything points to the right folder, but for some reason the subs will have been replaced.
It's not a consistent thing, but it does happen enough to be annoying.
If it helps, I only use .SRT & .ASS subs.
Any help would be appreciated.
rsotome is offline   Reply With Quote
Old 30th September 2012, 18:50   #11809  |  Link
Pratyatosa
I'll give it a try and let you know tomorrow.
Thanks for your help.
Old 1st October 2012, 17:35   #11810  |  Link
Pratyatosa
Bingo!
It was several months ago that I tried playing a video file with 2 audio tracks on my now discontinued Asus O!Play HDP-R1. I remember looking for an option on the menu, but I didn't think of the possibility that there might be a special key dedicated to the purpose. The icon on the key is very cryptic. I couldn't tell what it was supposed to represent until I already knew that it was the language button: the side of a head with a wave front coming from the mouth. It's on the very bottom of the remote.
I'm very grateful for your helpful hint, Chetwood.
Old 1st October 2012, 19:12   #11811  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by 73ChargerFan View Post
Wait - lots of receivers have ipod / aac support (Pioneer VSX-522-K, $250) or are they limited to 2.0 sources?
In all probability, yes, it will be limited to 2.0 sources. Looking at the receiver you posted, it looks like it will decode music audio AAC through the USB, and probably only 2.0 channels. It says nothing about decoding AAC for any other source.
Ryushin is offline   Reply With Quote
Old 1st October 2012, 19:39   #11812  |  Link
Ryushin
Ryushin's Avatar
Some 4x3 Sources Not Muxed Correctly
Hi Atak,
I seem to have a bit of a problem with the output of blu-ray sources that are 4x3. I have a few Criterion collection 4x3 sources that when they are muxed, the output is 16x9. This is also occurring with the recent release of Metropolis. Copping the selection by 240 left and right, and setting the size to 1440x1080 does not seem to produce the output as 4x3. It's still stretched to 16x9. Usually I have to use mkvmerge gui to remux it to get it to display 4x3 (and even then, there is still another line showing that the original display aspect ration is 16x9 according to the video section in mediainfo:
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 28mn
Bit rate : 7 164 Kbps
Maximum bit rate : 25.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Original display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.192
Stream size : 7.45 GiB (90%)
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=2:1.00
Default : Yes
Forced : No
The last two versions of mkvmerge created a mkv file that my TV cannot play. I don't know why that is yet, but I will spend some time figuring it out. As of right now, the mkv output of Ripbot264 plays flawlessly though DLNA to my Samsung C8000 TV.
Old 1st October 2012, 22:15   #11813  |  Link
Atak_Snajpera
in mkvmerge you have to disable header striping.
1440x1080 is always 16:9 in hdtv. the same with 1280x1080 (LUXETE channel was using this weird resolution for 16:9 content)
for 4/3 sources you can just force --sar 1:1 in .cmd file
Old 1st October 2012, 23:22   #11814  |  Link
Ryushin
Ryushin's Avatar
Thank you. After a hour or so of digging I found out about the header compression. I was finally able to use mkvmerge-gui to make a playable file again.
The command option --sar 1:1, would that be put in the MuxFiles.cmd?
Since 4x3 sources will be 1440x1080 in Blu-ray format, could I ask for a feature enhancement to force a certain aspect ratio or Anamorphic option in the GUI properties? I had no idea that someone would actually be doing a form of Anamorphic with HD content.
Old 2nd October 2012, 11:14   #11815  |  Link
Atak_Snajpera
sar goes to x264 command line
Old 2nd October 2012, 22:57   #11816  |  Link
empty1969
Feature Request
Atak,
First off great program! I have requested this feature before and wanted to do so again.
Sometimes when encoding in batch mode, I will have errors with the muxing. Since the program over writes the audio and video portions, I lose all the work that has been done. I do try to keep checking when I am home, but the other weekend I left the computer doing about 40 blu-ray episodes and when I got home, only 3 had been saved.
What I was hoping for is a feature that will store the temp audio and video files in the job directory before starting the next job.
Say the final output file is Lost S01E01, it would add -audio and -video to the names and move them into the job directory.
Thanks for your consideration.
Empty
empty1969 is offline   Reply With Quote
Old 3rd October 2012, 20:29   #11817  |  Link
Pratyatosa
Bug Report
Batch mode completely ignores the fact that MKV output is set as the default in the INI file.
Old 3rd October 2012, 20:33   #11818  |  Link
Pratyatosa
Another Item on My Wish List
That batch mode could also handle multiple M2TS (Blu-ray) files.
Old 3rd October 2012, 20:38   #11819  |  Link
Atak_Snajpera
bluray source requires user interaction so it cannot be added.
Old 3rd October 2012, 21:25   #11820  |  Link
Pratyatosa
Suppose that I want to simply compress some of the "extras" on a Blu-ray disk. Therefore, I copy a number of smaller M2TS files to a separate folder. The way it is now, I have to "fool" RipBot264 by changing all of the M2TS containers to MKV containers using http://llbest.com/?P=7i. Then batch mode works just fine, and I'm very grateful that you have added it.
But don't you think that having to do this time-consuming extra step is a little silly?
