Old 24th November 2005, 12:29   #61  |  Link
CruNcher
CruNcher's Avatar
The Greatest Game Ever Played Trailer
1920x1080p AVG 6 Mbit Max 22 Mbit (Main Profile)
Athlon 64 Venice 3000+ 1.8 GHz @ 2.4 GHz
32.03 ffdshow 21.11.05
31.27 nero 4.2.1.0
30.98 ateme 2.2.1.0
It is about Time
Old 24th November 2005, 12:49   #62  |  Link
redfordxx
x264 or what?
redfordxx is offline   Reply With Quote
Old 24th November 2005, 16:02   #63  |  Link
CruNcher
CruNcher's Avatar
http://trailer.nerodigital.com/eng/184.html <- this H.264 (AVC) Nero Sample
It is about Time
Old 24th November 2005, 16:24   #64  |  Link
ac-chan123
Why is the MPEG4 Part 2 ASP encoded file always smaller than the H.264 encodec one(and which profile is used in the H.264 encodes)?
ac-chan123 is offline   Reply With Quote
Old 24th November 2005, 16:42   #65  |  Link
bond
31.27 nero 4.2.1.0
30.98 ateme 2.2.1.0
wow interesting results! i thought the new nero is sooo fast?
Ogg Theora | Ogg Vorbis
Old 25th November 2005, 23:35   #66  |  Link
bobololo
On the same clip, using the same filters (except for ffdshow which is 20051124). I got those figures on my P4 3 GHz with HT :
36.9 fps with nero
24.4 fps with ateme
22.7 fps with ffdshow
I did the measurements using Haali timeCodec application. The difference compared to CruNCher's results are due to multi-thread optimization of nero.
bobololo is offline   Reply With Quote
Old 26th November 2005, 06:05   #67  |  Link
bond
36.9 fps with nero
24.4 fps with ateme
interesting, can you also test it without multithread?
and do you know what nero "multithreads" during decoding?
Old 26th November 2005, 06:25   #68  |  Link
Manao
Well, since the clip in question has only one slice, it's the decoding process itself that is threaded. I would say that one thread decode the cabac and another make the MC / deblocking.
Manao is offline   Reply With Quote
Old 18th December 2005, 15:25   #69  |  Link
tomos
nero's codec is multithreaded? i'm trying it now to play back a clip i've made (1080p) and one core is maxed out on my 4400+ - i'm getting around 16fps on it. my 3800+ overclocked plays it fine (barely). same with ffdshow and libavcodec
tomos is offline   Reply With Quote
Old 18th December 2005, 18:24   #70  |  Link
Manao
Nero 7 is multithreaded, afaik.
Old 18th December 2005, 19:28   #71  |  Link
tomos
thank you
was trying with v6 before. now working properly
cant use it in mplayer-c, have to use neros player to get it working for some reason
Old 18th December 2005, 19:51   #72  |  Link
bond
indeed, nero limits their decoder to only work in nero showtime
Old 18th December 2005, 19:55   #73  |  Link
tomos
shame, its not a bad player, but mpC is better.
hopefully libavcodec will be multithreaded some day may keep on using x264 from now on, i found it nicer on hdtv material than divx - although a lot slower
Old 9th January 2006, 11:43   #74  |  Link
PicardGK
36.9 fps with nero
24.4 fps with ateme
Just for the record this nero result is probably false (see http://forum.doom9.org/showthread.ph...588#post764588 ).
Unlikely. Such huge inter communication between threads would be more pain. But non reference b-frames can be decoded in a different thread.
PicardGK is offline   Reply With Quote
Old 10th January 2006, 21:02   #75  |  Link
ChronoReverse
Athlon64 Winchester 3000+ @ 2.25GHz (250x9) ~3500+
VMR9
44.8 CoreAVC 0.0.0.3
28.3 ffdshow 21.12.05 GCC SSE2
ChronoReverse is offline   Reply With Quote
Old 16th January 2006, 15:11   #76  |  Link
Inventive Software
Turkey Machine
@Bond: Perhaps CoreAVC should be added to this, bearing in mind it can be played on your machine now.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 13th February 2006, 01:02   #77  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
First legend : "MPEG4 AVC is slow" ... and at this time MPEG4 AVC is faster than all the other codec with better quality.
Second legend : "MPEG4 AVC is hard to play".
why not general comparison with other codec:
MPEG4 ASP + FFDShow dec PP0 (default) and PP4
MPEG4 ASP + XviD dec PP0 (Default) and PP4
MPEG4 ASP + DivX dec PP0 and PP4 (Default)
VP7 + VP7 dec PP0 and PP2 (default)
VC-1 + DMO dec PP0 and PP4 (default)
IMO MPEG4 AVC + CoreAVC dec is faster than MPEG4 ASP + PP4 dec or VC-1 + PP4 dec
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 13th February 2006, 08:32   #78  |  Link
berrinam
berrinam's Avatar
Originally Posted by Sagittaire
IMO MPEG4 AVC + CoreAVC dec is fastest than MPEG4 ASP + PP4 dec or VC-1 + PP4 dec
You mean AVC with super-fast options, and ASP with slow options, like your other test? Sounds good.
berrinam is offline   Reply With Quote
Old 13th February 2006, 11:53   #79  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
... lol
1) My speed encoding test all possible encoding setting for all codec (fastest and slowest setting for all codec) and fast encoding setting for AVC are by far very better for quality and speed than MPEG4 ASP slow setting. "Slow setting" for MPEG4 ASP here are not extreme setting but usual setting for all XviD/DivX user like default setting for XviD (ME6, VHQ1, Chroma, Trelli)
2) Use CoreAVC dec is not an "super-fast options" but just decoder choice and PP4 is default setting for DivX dec for example. Doom9 in this test use PP4 for all MPEG4 ASP dec ...
3)
MPEG4 ASP + FFDShow dec PP0 are slow options ?
VP7 + VP7 dec PP0 are slow options ?
VC-1 + DMO dec PP0 are slow options ?
For my Sempron MPEG4 AVC + CoreAVC (CABAC, High Profil, 16 ref and bref ... aka hardest setting for AVC decoding) is better for speed decoding than MPEG4 ASP (and without QPel or GMC ... aka not hardest option for ASP decoding) + PP4 ...
Old 13th February 2006, 11:55   #80  |  Link
bond
actually i think i indeed will add an asp sample to the comparison, encoded with slowest settings possible and decoded with the fastest asp decoder (which is ffdshow afaik)
