Old 1st April 2009, 15:30   #181  |  Link
buzzqw
HDConvertToX author
@flebber
please sendme a sample
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 1st April 2009, 15:39   #182  |  Link
spida_singh
buzz, confirmed all now ok, copy audio option now ok as well, final m2ts includes audio
Link to my sample: http://www.sendspace.com/file/5ogcvz
regards
spida_singh is offline   Reply With Quote
Old 1st April 2009, 15:46   #183  |  Link
buzzqw
HDConvertToX author
@spida_singh
BHH
Old 1st April 2009, 16:34   #184  |  Link
flebber
Practising Schemer
http://www.4shared.com/file/96185525...d4/Sample.html
flebber is offline   Reply With Quote
Old 1st April 2009, 20:29   #185  |  Link
buzzqw
HDConvertToX author
@spida_singh
thanks for the sample
in next update will be fixed also
truehd/ac3
dts-es
ebedded ac3
@fleber
the sample file have MONO audio, and eac3to is unable to process it
BHH
Old 1st April 2009, 20:48   #186  |  Link
Sharc
Recent versions of HDC seem to crop too much into the picture (auto-cropping). Did you change the cropping sensitivity or number of sample frames?
Take for example SMD's clip of Lawrence of Arabia. It now crops top/bottom as 90/90 (not using mod16.txt) which turns it into a 2.53:1 movie. It should be 2.2:1. Earlier versions of HDC cropped correctly top/bottom as 58/54.
It would be helpful if one could do the cropping manually in a preview window using the mouse wheel
Old 1st April 2009, 22:37   #187  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Given the ongoing improvements of the encoding performance of Xvid (and x264), I wouldn't have thought we're not going to loose that much by using "Mod-8"....
Old 2nd April 2009, 00:40   #188  |  Link
flebber
Practising Schemer
I uploaded a different flv this time stereo
http://www.4shared.com/file/96260773...Boneyards.html
General
Complete name : C:\Documents and Settings\Family\dwhelper\Parkway Drive - Boneyards.flv
Format : Flash Video
File size : 9.37 MiB
Duration : 3mn 11s
Overall bit rate : 411 Kbps
Encoded date : Fri Oct 12 06:19:03 2007
Video
Format : VP6
Duration : 3mn 11s
Bit rate : 290 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.126
Audio
Format : MPEG Audio
Format version : Version 2
Format profile : Layer 3
Duration : 3mn 11s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Resolution : 16 bits
Writing library : LAME,d:e / \
Old 2nd April 2009, 01:12   #189  |  Link
Crono141
Sorry for the absense. About my problem; I have anyDVD running, which should decrypt on the fly, and a BR disc ISO I ripped using my PS3 (no PC BR drive). Ripbot264 encoded the same file/movie off the mounted ISO with no problem, but none of my set top boxes in the living room play the file (PS3/Xbox360). Plays on computer just fine.
ANYWAY:
I wanted to try out HDC to see if it produced a better more compatible re-encode. The file (off the mounted ISO) played in WMP12 without ripping the disc, so I don't think this is the issue.
Crono141 is offline   Reply With Quote
Old 2nd April 2009, 08:12   #190  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
REMEMBER MP4 cannot be larger that 4GB. X does not support 5.1 aac.
Old 2nd April 2009, 10:01   #191  |  Link
buzzqw
HDConvertToX author
update hdc
>fixed audio copy of "dts master audio"
>fixed audio copy of "ac3 ex"
>fixed audio copy of "ac3 surround"
>fixed NMT.txt and SAP.txt hidden options
>fixed problems when copy audio with new audio formats
>fixed audiocopy.txt hidden options
>fixed ar detection of some m2ts
>fixed audio copy of "truehd/ac3"
>fixed audio copy of "embedded ac3"
>fixed audio copy of "core.dts-es"
>added ffmpegaudio.txt as hidden options. when this file is used and input isn't directly supported (like flv) , audio is pre-processed to stereo wav with ffmpeg (if ffmpeg.exe is present in \applications folder) then passed to eac3to
>added "Crop obey to AR". This options will force autocrop to obey and respect aspect ratio detected by eac3to
>other minor corrections and cosmetic fixes
BHH
Old 2nd April 2009, 12:20   #192  |  Link
nikio
I took a look at HDConverTox screen shots, (the one of the AviSynth tab is missing ), it looks more tidy and intuitive.
As an idea for the future I'd just add a tab for the final muxing options.
Anyway, are you aiming to make HDConveTox take over completely from AutoMkv, for all functions?
nikio is offline   Reply With Quote
Old 2nd April 2009, 12:52   #193  |  Link
flebber
Practising Schemer
I added ffmpegaudio.txt to my hdc folder but it doesn't appear in the log.
HDConvertToX v.0.7.150.1323 report
Input File: C:\Rip\HDConvertToX_0.7.119.1194\temp\fullvideo.mkv
Codec Video: vfw
Width: 480
Heigh: 270
Framerate: 25.000
Framecount: 7234
Duration(hh:mm:ss): 0:4:50
Aspect Ratio: 1.7778
Resized resolution: 464 / 256
Crop Left: 8
Crop Top: 8
Crop Right: 8
Crop Bottom: 6
Start Hidden Options ->
Activate Hidden Option: Mod16
-> End Hidden Options
Old 2nd April 2009, 13:10   #194  |  Link
buzzqw
HDConvertToX author
@nikio
yes and no, most fuctions are already present.
feel free to suggest missing features
@flebber
ops, i missed it in log
but encoding should be fine (using ffmpeg)
BHH
Old 2nd April 2009, 14:44   #195  |  Link
spida_singh
buzz, when selecting save file, it does not automatically input the extention, I have to manually type ".m2ts" when saving it, can this be automated for all file extentions? And, is there currently a function like in automkv where i can save my settings, as i have to keep setting quality bar everytime the program opens.
regards
Old 2nd April 2009, 14:56   #196  |  Link
buzzqw
HDConvertToX author
it does (just tested) , BUT it don't change when changing container/codec
EDIT: redownload HDC, and create a qualX.txt ; where X can be 1 2, 3 4 5 6 .... and is the quality at start
BHH
Old 2nd April 2009, 15:25   #197  |  Link
Borgen
Keep full resolution?
Is it possible to keep the full resolution (720x576) with this software?
Have tried an early beta of this software and then it changed the resolution on the output file even if I specified that the cropping was 0,0,0,0
I dont want to do any resize on my encoding and keep the full resolution at 720x576.
Is this possible? (It worked just fine in AutoMKV....... )
Borgen is offline   Reply With Quote
Old 2nd April 2009, 15:43   #198  |  Link
buzzqw
HDConvertToX author
@Borgen
set crop to 0,0,0,0
then check Anamorphic (or edit height)
BHH
Old 2nd April 2009, 17:58   #199  |  Link
EEPROM
EEPROM's Avatar
Hi Buzz, congratulations for this new prgram !
I usually use programs like AutoGK or AutoMen so I do not know to use the filters.
Where can I find a guide to understand Basic-QMF-MVDegrain filters?
sorry for my bad english
EEPROM is offline   Reply With Quote
Old 2nd April 2009, 20:03   #200  |  Link
buzzqw
HDConvertToX author
Hi EEPROM and thanks for your kind words
i can only suggest to use the forum search, you will be overwhelmed by results
BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
