29th June 2013, 19:54 | #17541 | Link | |
"C:\Users\xxxxxx\Desktop\xxxxxx\BD_Rebuilder\tools\x264.exe" "I:\xxxxxxx\WORKFILES\VID_00009.AVS" --preset slow --bluray-compat --ref 4 --b-adapt 1 --b-pyramid strict --weightp 1 --open-gop --qpmin=0 --bitrate 6490 --level 4.1 --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads 12 --slices 4 --thread-input --opencl --stats "I:\xxxxxx\WORKFILES\VID_00009.AVS.264.stats" --pass 2 \--output "I:\xxxxxxxx\WORKFILES\VID_00009.AVS.264" Last edited by jdobbs; 29th June 2013 at 23:41. |
29th June 2013, 21:52 | #17542 | Link |
@jdobbs
Hi ! Thanks for the quick reply ! I tried that, also making sure I rebooted my PC between uninstalls and installs, and also making sure I downloaded the tools using the links provided by you and I get the exact same results. It's wierd since I've been using your software for approximately 2 years now and about half of the time I use it for BD to DVD conversion with subtitles and never had any issues. Everything seems to be working fine, it converts the subtitles, multiplexes the audio and video and stops when trying to stream the subs in... It's the same thing whether I rip with AnyDVD or DVDFab. Should I try uninstalling and reinstalling again ? With 'James and the Giant Peach' : [06-29-13] BD Rebuilder v0.44.14 (beta) [12:28:51] Source: JAMESANDTHEGIANTPEACH_00100 - Input BD size: 24,21 GB - Approximate total content: [01:19:25.051] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [12:28:51] PHASE ONE, Encoding - [12:28:51] Processing: VID_00066 (1 of 1) - [12:28:51] Extracting A/V streams [VID_00066] - [12:46:56] Reencoding video [VID_00066] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 114*247 frames - Bitrate: 6*687 Kbs - [12:46:57] Reencoding: VID_00066 - [14:02:46] Video Encode complete - [14:02:46] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (fra): Reencoding audio to AC3... [14:06:39]PHASE ONE complete [14:06:39]PHASE TWO - Rebuild Started - [14:06:39] Building ALTERNATE OUTPUT Structure - [14:06:39] Converting 3 subtitles to DVD format. - [14:07:43] Starting MPLEX. - [14:10:05] Multiplexing 3 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - WARNING: Failed to integrate Subtitle_02 - WARNING: Failed to integrate Subtitle_03 - [14:10:27] Building DVD File Structure. - ERROR in attempt to create DVD structure (DVDAUTHOR) [14:10:27] - Failed to REBUILD Today, I also tried 'Argo' with the same behavior : [06-29-13] BD Rebuilder v0.44.14 (beta) [14:32:34] Source: ARGO_00100 - Input BD size: 29,41 GB - Approximate total content: [02:00:22.256] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [14:32:35] PHASE ONE, Encoding - [14:32:35] Processing: VID_00015 (1 of 1) - [14:32:35] Extracting A/V streams [VID_00015] - [14:55:30] Reencoding video [VID_00015] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 173*161 frames - Bitrate: 4*111 Kbs - [14:55:30] Reencoding: VID_00015 - [16:11:03] Video Encode complete - [16:11:03] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (fra): Reencoding audio to AC3... [16:17:36]PHASE ONE complete [16:17:36]PHASE TWO - Rebuild Started - [16:17:36] Building ALTERNATE OUTPUT Structure - [16:17:36] Converting 5 subtitles to DVD format. - [16:21:50] Starting MPLEX. - [16:23:57] Multiplexing 5 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - WARNING: Failed to integrate Subtitle_02 - WARNING: Failed to integrate Subtitle_03 - WARNING: Failed to integrate Subtitle_04 - WARNING: Failed to integrate Subtitle_05 - [16:24:04] Building DVD File Structure. - ERROR in attempt to create DVD structure (DVDAUTHOR) [16:24:05] - Failed to REBUILD Thanks for the help ! |
29th June 2013, 23:42 | #17543 | Link | |
29th June 2013, 23:45 | #17544 | Link |
@tiamat911
I just ran one of the jobs you reported as having a problem: Code:
---------------------- [06/29/13] BD Rebuilder v0.44.15 (beta) [10:48:55] Source: SILVER_LININGS_PLAYBOOK_00005 - Input BD size: 26.05 GB - Approximate total content: [02:02:06.944] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [10:48:56] PHASE ONE, Encoding - [10:48:56] Processing: VID_00006 (1 of 1) - [10:48:56] Extracting A/V streams [VID_00006] - [10:55:39] Reencoding video [VID_00006] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 175,671 frames - Bitrate: 4,481 Kbs - [10:55:39] Reencoding: VID_00006 - [11:54:25] Video Encode complete - [11:54:25] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [11:58:40]PHASE ONE complete [11:58:40]PHASE TWO - Rebuild Started - [11:58:40] Building ALTERNATE OUTPUT Structure - [11:58:40] Converting 2 subtitles to DVD format. - [12:01:57] Starting MPLEX. - [12:04:04] Multiplexing 2 subtitles into stream. - [12:08:03] Building DVD File Structure. [12:10:59] - Encode and Rebuild complete [12:10:59] JOB: SILVER_LININGS_PLAYBOOK finished. Could you post the contents of your BDREBUILDER.INI file so I can see if there is anything odd there? Last edited by jdobbs; 29th June 2013 at 23:48. |
30th June 2013, 00:03 | #17545 | Link |
I'm in NTSC mode and all BD rips I've used where ripped by myself from the North American releases of the movies I tried to convert... And like I said, I'm not havint any issues if I exclude the subtitles, the errors only show up with subtitles.
Here's my BDREBUILDER.INI file from my last test (ARGO). [Options] VERSION=0.44.0.14 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_3D=0 NEROAAC=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=1 ALTCRF=23 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 [Paths] SOURCE_PATH=J:\ WORKING_PATH=D:\BD & DVD\ARGO\ I just noticed something, is it possible I'm having this issue because the destination folder as a "&" in it ?? |
30th June 2013, 00:33 | #17546 | Link | |
30th June 2013, 00:50 | #17547 | Link | ||
---------------------- [06/29/13] BD Rebuilder v0.44.15 (beta) [17:37:57] Source: SILVER_LININGS_PLAYBOOK_00005 - Input BD size: 26.05 GB - Approximate total content: [02:02:06.944] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [17:37:58] PHASE ONE, Encoding [17:37:58]PHASE ONE complete [17:37:58]PHASE TWO - Rebuild Started - [17:37:58] Building ALTERNATE OUTPUT Structure - [17:37:59] Converting 2 subtitles to DVD format. - [17:41:15] Starting MPLEX. - [17:43:58] Multiplexing 2 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - WARNING: Failed to integrate Subtitle_02 - [17:44:00] Building DVD File Structure. - ERROR in attempt to create DVD structure (DVDAUTHOR) [17:44:00] - Failed to REBUILD Good catch!! |
30th June 2013, 01:34 | #17548 | Link |
@tiamat911
Ok, I have it. The problem is that the "&" (ampersand) has a special meaning in XML. SPUMUX uses an XML descriptor as input to the muxing. So the XML interpreter had an issue when it saw it in the path name. I'll need to modify my code to look for an "&" in the path and change it to an "&" or a numeric character reference. |
30th June 2013, 03:13 | #17549 | Link |
When I posted that last post, I lunched a new converting job with a different destination folder. I was out for a few hours and when I came back (just now), I saw that my job finished without any errors and I also saw your replies... and then it came to me that I started to have this issue when I completely re-organised my hard drive/folders and change the name of my BD/DVD workfolder from simply 'DVD' to 'BD & DVD'
I'm happy I could contribute and I'm also happy that you asked my to post my .INI file since it's what made me realise that the & could be the probleme... Thanks again for your help, quick replies, great patience... and thanks for that great piece of software ! |
30th June 2013, 04:13 | #17550 | Link | |
I've fixed it for the next release. |
30th June 2013, 06:58 | #17551 | Link |
aka Rabomil
I tried to resize the bonus material by adding "e:r:spline16resize(640,360)" and it works almost perfectly. Almost perfectly, because short videos (deleted scenes of about 40 seconds) get resized, but also get a bitrate that would be appropriate for 1080p. That it gets resized shows that it gets recognized as bonus material.
Although it doesn't have much impact on the total size, it would be nice to have all bonus material encoded the same way. |
30th June 2013, 10:26 | #17552 | Link |
Discovered a title which gives BD-RB problems: the Danish TV thriller The Killing, series 2. Both discs have 5 episodes, an hour each.
Ran a movie-only backup of both discs by selecting a "play all" playlist. On backup disc 1, audio sync is fine for the first 4 episodes, but badly off in episode 5. On backup disc 2, audio sync is fine in episode 1, but badly off in episodes 2-5. MediaInfo says the source files are 24.00fps progressive. Backups were created with "KEEP_HD_AUDIO=1" so DTS-HD MA tracks were copied over as-is. LOG for disc 1: Code:
[06.24.13] BD Rebuilder v0.44.14 (beta) [18:33:16] Source: THE_KILLING_DK_S2D1_00002 - Input BD size: 42,23 GB - Approximate total content: [04:58:36.000] - Target BD size: 23,73 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Ultra High Quality (Extremely Slow), Two Pass - Output folder: U:\_ENCODES\ - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [1] is defaulted ON. [18:33:18] PHASE ONE, Encoding - [18:33:18] Processing: VID_00007 (1 of 5) - [18:33:18] Extracting A/V streams [VID_00007] - [18:51:26] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 86*304 frames - Bitrate: 8*735 Kbs - [18:51:26] Reencoding: VID_00007, Pass 1 of 2 - [19:09:56] Reencoding: VID_00007, Pass 2 of 2 - [20:56:40] Video Encode complete - [20:56:41] Processing audio tracks - Track 4352 (dan): Keeping original audio - [20:56:41] Processing: VID_00008 (2 of 5) - [20:56:41] Extracting A/V streams [VID_00008] - [21:10:21] Reencoding video [VID_00008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 86*112 frames - Bitrate: 8*749 Kbs - [21:10:21] Reencoding: VID_00008, Pass 1 of 2 - [21:29:03] Reencoding: VID_00008, Pass 2 of 2 - [23:13:11] Video Encode complete - [23:13:11] Processing: VID_00009 (3 of 5) - [23:13:11] Extracting A/V streams [VID_00009] - [23:16:54] Reencoding video [VID_00009] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 86*040 frames - Bitrate: 8*750 Kbs - [23:16:54] Reencoding: VID_00009, Pass 1 of 2 - [23:35:28] Reencoding: VID_00009, Pass 2 of 2 - [01:20:38] Video Encode complete - [01:20:39] Processing: VID_00010 (4 of 5) - [01:20:39] Extracting A/V streams [VID_00010] - [01:23:19] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 86*304 frames - Bitrate: 8*770 Kbs - [01:23:19] Reencoding: VID_00010, Pass 1 of 2 - [01:41:48] Reencoding: VID_00010, Pass 2 of 2 - [03:26:34] Video Encode complete - [03:26:35] Processing: VID_00011 (5 of 5) - [03:26:35] Extracting A/V streams [VID_00011] - [03:29:13] Reencoding video [VID_00011] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 85*224 frames - Bitrate: 8*777 Kbs - [03:29:13] Reencoding: VID_00011, Pass 1 of 2 - [03:47:31] Reencoding: VID_00011, Pass 2 of 2 - [05:31:13] Video Encode complete [05:31:13]PHASE ONE complete [05:31:13]PHASE TWO - Rebuild Started - [05:31:13] Rebuilding BD file Structure [05:37:45] - Encode and Rebuild complete [05:37:45] JOB: THE_KILLING_DK_S2D1 finished. Code:
[06.25.13] BD Rebuilder v0.44.14 (beta) [22:02:59] Source: THE_KILLING_DK_S2D2_00002 - Input BD size: 42,40 GB - Approximate total content: [05:07:35.458] - Target BD size: 23,73 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Ultra High Quality (Extremely Slow), Two Pass - Output folder: U:\_ENCODES\ - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [1] is defaulted ON. [22:03:01] PHASE ONE, Encoding - [22:03:01] Processing: VID_00006 (1 of 5) - [22:03:01] Extracting A/V streams [VID_00006] - [22:16:21] Reencoding video [VID_00006] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 88*128 frames - Bitrate: 8*434 Kbs - [22:16:21] Reencoding: VID_00006, Pass 1 of 2 - [22:35:27] Reencoding: VID_00006, Pass 2 of 2 - [00:21:56] Video Encode complete - [00:21:56] Processing audio tracks - Track 4352 (dan): Keeping original audio - [00:21:56] Processing: VID_00007 (2 of 5) - [00:21:56] Extracting A/V streams [VID_00007] - [00:24:50] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 88*427 frames - Bitrate: 8*466 Kbs - [00:24:50] Reencoding: VID_00007, Pass 1 of 2 - [00:43:51] Reencoding: VID_00007, Pass 2 of 2 - [02:35:16] Video Encode complete - [02:35:16] Processing: VID_00008 (3 of 5) - [02:35:16] Extracting A/V streams [VID_00008] - [02:38:08] Reencoding video [VID_00008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 88*512 frames - Bitrate: 8*424 Kbs - [02:38:08] Reencoding: VID_00008, Pass 1 of 2 - [02:56:45] Reencoding: VID_00008, Pass 2 of 2 - [04:43:31] Video Encode complete - [04:43:31] Processing: VID_00009 (4 of 5) - [04:43:31] Extracting A/V streams [VID_00009] - [04:46:23] Reencoding video [VID_00009] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 88*560 frames - Bitrate: 8*486 Kbs - [04:46:23] Reencoding: VID_00009, Pass 1 of 2 - [05:05:38] Reencoding: VID_00009, Pass 2 of 2 - [06:54:32] Video Encode complete - [06:54:33] Processing: VID_00010 (5 of 5) - [06:54:33] Extracting A/V streams [VID_00010] - [06:57:22] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 89*304 frames - Bitrate: 8*427 Kbs - [06:57:22] Reencoding: VID_00010, Pass 1 of 2 - [07:16:51] Reencoding: VID_00010, Pass 2 of 2 - [09:09:28] Video Encode complete [09:09:29]PHASE ONE complete [09:09:29]PHASE TWO - Rebuild Started - [09:09:29] Rebuilding BD file Structure [09:16:18] - Encode and Rebuild complete [09:16:18] JOB: THE_KILLING_DK_S2D2 finished. episode 1 - 00:59:56.000 episode 2 - 00:59:48.000 episode 3 - 00:59:45.000 episode 4 - 00:59:56.000 episode 5 - 00:59:11.000 total 04:58:36.000 BACKUP disc 1 00000.m2ts length - video 04:58:36.000 - audio 04:58:34.016 SOURCE disc 2 lengths episode 1 - 01:01:12.000 episode 2 - 01:01:24.458 episode 3 - 01:01:28.000 episode 4 - 01:01:30.000 episode 5 - 01:02:01.000 total 05:07:35.458 BACKUP disc 2 00000.m2ts length - video 05:07:35.458 - audio 05:07:33.483 update: Ripped the DTS-HD MA tracks using MeGUI (i.e. eac3to) which does a 2nd pass on the audio file after ripping, fixing gaps and overlaps. The result is a file which syncs perfectly to BD-RB's output. Last edited by colinhunt; 30th June 2013 at 11:39. |
30th June 2013, 14:24 | #17553 | Link | |
Instead of a Movie-Only backup of the "Play All" playlist, why wouldn't you just do a "Quick-Play Backup"? It will keep all the episodes and make it a lot more convenient for playback... Last edited by jdobbs; 30th June 2013 at 16:39. |
30th June 2013, 21:17 | #17554 | Link |
@ jdobbs
@ omegaman7 "The Mentalist" S1 D1 Episode 1... SD_PROGRESSIVE and Setup's IVTC 3:2 does well, just doesn't display any indicator in the log that it's happening as it does when using Full Backup. Something else I noticed that perhaps you haven't?? BD-RB picks the middle episode as the biggest. Yet, it shows in the list as under an hour; same as the other episodes. It should reflect the total time of all episodes...correct? Thanks. Back to the root as to why I was testing this.. From my Optical Drive, I've not noticed any out of sync importing the first episode from DVD when the render is good.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
30th June 2013, 21:33 | #17555 | Link | ||
30th June 2013, 22:56 | #17556 | Link | |
Only one rooster, need be in the hen house... |
1st July 2013, 02:17 | #17557 | Link | |
1st July 2013, 23:20 | #17558 | Link |
@ jdobbs
Okay. That's a software difference between HandBrake and BD-RB. Cool, it's not a BD-RB bug. Movie only; Alternate MKV/MP4 vs Full Backup.
