Old 18th August 2016, 14:28   #1  |  Link
SuperLumberjack
French Registered User
SuperLumberjack's Avatar
I want to upscale a Super Nes video in HD
Hello
I'm new on this forum and I'm French. I try to upscale video captured with a Super Nes emulator (Snes9x) which are in a resolution of 256x224, in a resolution of 1408x1080.
[with Higan Emulator, the output resolution is 584x448 (or 584x480 with black bars), and it is known to be the more accurate emulator, so I took a proportional resolution]
My principal problem is this :
Pixel Aspect Ratio and Sampling
Analogue RGB signals from retro consoles use composite video or composite sync in addition to the color information. This type of sync doesn't contain information about the horizontal pixels. This is commonly called RGBS as opposed to RGBHV, where H and V stand for the horizontal and vertical sync. RGBHV is used in more modern devices for VGA for example. On CRTs it doesn't matter that there is no horizontal sync information, because each line of the picture is drawn across the whole screen. On LCD screens and for capture this is a problem. In the process of creating a digital version of the signal the picture lines are sampled and pushed into a mask of pixels. The number of pixels is fixed and doesn't take the original console into account. Usually there are 720 or 640 horizontal pixels after the sampling step.
sampling
240p signal with non-square pixels sampled and linedoubled to 720x480 pixel.
Retro consoles usually only have a low amount of pixels in the horizontal resolution. These pixels are stretched to fill a whole line on the screen. In the case of the SNES there are 256 pixels horizontally in each line on the console. To fill the screen the pixels are slightly stretched, resulting in pixels that are wider than tall. The actual pixel ascept ratio (PAR) for the SNES is 11:10. On a PC each pixel has the same width and height, or in other words a pixel aspect ratio of 1:1. In the sampled version of the signal each non-square pixel from the console influences the color of 1 or 2 horizontally adjacent square pixels making it slightly blurry on the horizontal axis.
(source : https://blz.la/rgb/)
Do you see what I mean ?
When I do an enlargement oh the image with classic resize filter, it becomes inaccurate horizontaly.
The best I tried is the SimpleResize, but the YV24 and RGB24 color formats aren't supported, so I have a loss of accuracy for the colors
Have you an idea for this ?
We can took this picture to begin :
Thanks for your help !
SuperLumberjack is offline   Reply With Quote
Old 19th August 2016, 18:58   #2  |  Link
davidhorman
I'm the Doctor
You can always take the three RGB channels, convert them to separate clips, and use simpleresize on each one. Something like this:
r=clip.showred.converttoyv12
g=clip.showgreen.converttoyv12
b=clip.showblue.converttoyv12
r2=r.simpleresize(... , ...)
g2=g.simpleresize(... , ...)
b2=b.simpleresize(... , ...)
mergergb(r2,g2,b2)
(not tested)
davidhorman is offline   Reply With Quote
Old 19th August 2016, 18:59   #3  |  Link
SuperLumberjack
I tried the SimpleResize with this base of code :
w=<new width, integer>
h=<new height, integer>
## Last=YV24
YToUV(
\ UToY.SimpleResize(w, h)
\ , VToY.SimpleResize(w, h)
\ , Last.SimpleResize(w, h)
But, it's not perfect.
http://forum.doom9.org/showthread.ph...01#post1777501
Strangly, I noticed on my notebook (with Intel HD4600 chipset), that in VirtualDub a upscaling was effective with previews.
See the picture in fullscreen. The upscaling by the Intel HD is effective in the left window. In the right window, I upscaled the image 4X with Nearest Neighbor filter.
This upscaling is effective in other programs (like ACDSee) too.
Intel HD upscaling vs. Bicubic
But it's enough impressive, because when we enlarge a picture, it's almost transparent. It's like stretching chewing-gum
Here is the image in ACDSee, when I zoom at 1000% :
Zoom 2000% :
Zoom 5000% :
Zoom 10000% :
Where can I find a filter like this for AviSynth ?
It could be the solution for this problem
Old 19th August 2016, 19:28   #4  |  Link
SuperLumberjack
mergergb(r2,g2,b2)
(not tested)
In the same moment ! Thanks for the answer
Yes, someone told me for the SimpleResize with YV24 color format (it was better than with RGB24, because it was directly in YV24)
Old 19th August 2016, 19:40   #5  |  Link
SuperLumberjack
How can I reduce the size of the images on this thread please ? It's too big
Old 19th August 2016, 19:45   #6  |  Link
mastrboy
Tried pointresize(1024,896) ? (basically 256*4x224*4)
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 19th August 2016, 19:53   #7  |  Link
SuperLumberjack
Yeah ! But it's ugly
In reality, the output resolution must be proportional to : 584x448.
It's the Higan (the Super Nes emulator known as the more accuracy) resolution.
So, I need to change the aspect ratio
I want 1408x1080 for the output resolution.
Old 19th August 2016, 20:01   #8  |  Link
mastrboy
I see, well then my idea is of course completely useless
Old 19th August 2016, 20:04   #9  |  Link
SuperLumberjack
No, because I tried with PointResize and others filters too
I tried many things
Old 19th August 2016, 20:09   #10  |  Link
feisty2
I'm Siri
feisty2's Avatar
Take a look at HQx
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 19th August 2016, 20:10   #11  |  Link
feisty2
I'm Siri
feisty2's Avatar
https://en.wikipedia.org/wiki/Hqx
Old 19th August 2016, 20:15   #12  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
http://avisynth.nl/index.php/PointSize
a collection of specialized resizers for pixel-art and other low resolution graphics (e.g. old or portable video game captures).
(including HQx)
raffriff42 is offline   Reply With Quote
Old 19th August 2016, 20:46   #13  |  Link
SuperLumberjack
Thanks !
But I don't like HQx and emulator filters
For me, the biggest problem is to get a transparency change of the aspect ratio. So the problem is this :
But for the upscaling, I prefer maybe Spline16 or Bicubic. A filter which doesn't cause this around the objects :
http://www.repaire.net/forums/attach...ing-png.34435/
Spline36, Lanczos, Blackman, Sinc, etc., it's bad for me !
Or I need to begin with Spline16 and Bicubic, and after continue with an other filter.
But I think I must change the aspect ratio in the end. It would be the best with a filter like the Intel HD upscaling. It's amazing when we enlarge a picture
Old 20th August 2016, 06:28   #14  |  Link
trip_let
But it can't be transparent, at least as long as the display device has square pixels. Either it's going to have to be interpolated and stretched by some resampler now or on playback, if you want the displayed aspect ratio correct.
Isn't the preview you're looking at just with some bilinear upsize or something like that?
Just a quick check of a couple things:
bilinear, convert to YUV444
nnedi3 doubled three times to 2048x1792, then Catmull-Rom (bicubic b=0, c=1/2) down to target and convert to YUV444
trip_let is offline   Reply With Quote
Old 20th August 2016, 09:40   #15  |  Link
SuperLumberjack
Hello. Thanks for your answer !
Bilinear, it's a bit too sweet.
I tried with Nnedi3 too. But with this filter in first position, we have some deformations of straight lignes.
See here :
http://image.noelshack.com/fichiers/...atmull-rom.png
AviSource()
ConvertToYV24()
nnedi3_rpow2(rfactor=4, nsize=0, nns=4, qual=1, etype=0, pscrn=2, threads=0, opt=0, fapprox=0)
BicubicResize(b=0, c=0.5, 1408, 1080)
I noticed, when we begin with a filter like Bicubic or Spline16, we haven't this problem.
See here :
AviSource()
ConvertToYV24()
Spline16Resize(512, 448)
nnedi3_rpow2(rfactor=2, nsize=0, nns=4, qual=1, etype=0, pscrn=2, threads=0, opt=0, fapprox=0)
I know, I'm too perfectionist
But it's not only for Super Nes videos. I want to use this for others low resolution videos later.
I search for a natural renderer. But not too sweet (and not too sharp). It's why I want to upscale my videos
For the transparency of the enlargement, I exactly find that it's not so bad with the upscaling of Intel HD chipset. But I don't know where I can find a similar thing.
Old 20th August 2016, 09:47   #16  |  Link
feisty2
I'm Siri
feisty2's Avatar
xbrz(6)
xbrz(6)
BicubicResize(1408, 1080,b=-1,c=0)
Old 20th August 2016, 10:09   #17  |  Link
SuperLumberjack
No sorry, it's too ugly !
As I said, I don't like filters like emulators filters.
I low pixel art, but I don't want neither it's like Nearest Neighbor
I want to find the good balance. I will show you an example after
Old 20th August 2016, 10:24   #18  |  Link
SuperLumberjack
This is sweet, but is a good compromise :
AviSource()
ConvertToYV24()
BicubicResize(b=0, c=0.5, 512, 448)
## Last=YV24
YToUV(
\ UToY.SimpleResize(1408, 1080)
\ , VToY.SimpleResize(1408, 1080)
\ , Last.SimpleResize(1408, 1080)
ConvertToRGB24()
But it's not perfect !
As I said, the pincipal problem is to get a change of the aspect ratio which is looking natural
Like on the CRT-screen, when horizontal resolution wasn't a problem.
All the difficulty comes from the nature of the image, because it's pixel art. When we enlarge an image, we can see the loss.
It's why this upscaling Intel thing seems to be interesting (up on the thread)
In fact, I want to preserve the essence of the pixel art, but enhance it to a HD resolution.
It's important that in movement, it remembers the sensations of the era (especially, this real 2D effect).
Old 20th August 2016, 10:48   #19  |  Link
SuperLumberjack
A little change :
AviSource()
ConvertToYV24()
BicubicResize(b=0, c=0.5, 584, 448)
## Last=YV24
YToUV(
ConvertToRGB24()
It's look more pixel perfect, but there is still a little thing which looks unatural in the relief.
Old 20th August 2016, 11:18   #20  |  Link
SuperLumberjack
Do you see what I mean by (almost) natural ?
AviSource()
ConvertToYV24()
Spline16Resize(1168, 896)
## Last=YV24
YToUV(
\ UToY.SimpleResize(2816, 2160)
\ , VToY.SimpleResize(2816, 2160)
\ , Last.SimpleResize(2816, 2160)
ConvertToRGB24()
Original picture :
It remembers me the original picture, but the immersion isn't perfect. It's why I need something more transparent for the change of the aspect ratio.
If somebody knows if I can find a filter like the Intel upscaling (see up in the thread). The enlargement looks almost transparent I find.
