Old 15th January 2020, 13:14   #58381  |  Link
QBhd
QB the Slayer
QBhd's Avatar
yes...
and I guess I should also say that I output to a 4k OLED (C8) so I don't "need" the tonemapping as much. It's easy for us with HDR displays to forget most users don't have this and need to tonemap to SDR or very low nits.
QB
QBhd is offline   Reply With Quote
Old 15th January 2020, 14:12   #58382  |  Link
nsnhd
Based on feedback that how amazing madVR tone mapping is, I've chosen a Non-HDR display at a very good price.
nsnhd is offline   Reply With Quote
Old 15th January 2020, 16:27   #58383  |  Link
stefanelli73
Originally Posted by chros View Post
Is it with d3d11 native in Lav?
yes....
stefanelli73 is offline   Reply With Quote
Old 15th January 2020, 17:02   #58384  |  Link
Siso
Siso's Avatar
I noticed something little strange today, using NGU AA low for chroma, and image doubling with NGU Sharp medium, the render queue stays most of the time 7-8/8, but sometimes it shows 6-7/8. I'm using 3440x1440p display, the card is gtx 1050 ti. Rendering times are ~ 21 ms.
Old 15th January 2020, 18:22   #58385  |  Link
this can be ignored.
Old 15th January 2020, 18:42   #58386  |  Link
nevcairiel
As long as you don't actually get any dropped frames, fluctuations in the queue are just normal operation.
nevcairiel is online now   Reply With Quote
Old 15th January 2020, 21:09   #58387  |  Link
mclingo
Originally Posted by stefanelli73 View Post
I don't agree, I saw the film both in PASSTHROUGH HDR and with Madvr's TONE MAPPING with the addition of a calibration in SDR DCI-P3 and sincerely watching the film with tone mapping is much better .... then with COMPROMISE ON HDR TONE & GAMUT MAPPING there is only a slight difference in colors that are a little less saturated, so I don't see what the problem is
Hi, There is a bug for all 5700 users at the moment, AMD HDR API is broken and not sendin BT2020 colour space to HDR tv's, this is likely why you are seeing unsaturated colours?
Turn on windows HDR, then Switch to passthrough and untick meta data in MADVR and have another look, can you report back what your see.
thanks
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 580 19.12.2 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:On / MADVR 10bit
Old 16th January 2020, 15:16   #58388  |  Link
mclingo
after 7 years of excellent work my intel 2700k is finally going out to pasture (ebay) - i'm upgrading to a ryzen 5 3600, however i'm sure i've heard some issues about ryzen and video output / madvr etc, anyone know of any issues I need to be wary of with MADVR?
Old 16th January 2020, 15:47   #58389  |  Link
stefanelli73
thanks
the slightly unsaturated colors are due to the COMPROMISE ON HDR TONE & GAMUT MAPPING function, which I repeat is forced to click to take advantage of the madvr tone mapping at 60hz .... with the PASSTHROUGH HDR I do not need to click on COMPROMISE ON HDR ... . for 60hz and the colors are correct, even using the Windows API.
The only difference I found between the AMD and the Windows API is that the latter is brighter .... but I always use Madvr tone mapping for 23.976 and 24hz, the vision is better with the addition also of a calibration in SDR DCI-P3
Old 16th January 2020, 16:22   #58390  |  Link
the trade for quality option has no effect on path through.
the point of path through it that the image is not touched and you get different results depending on the API which shows there is clearly an issue.
Old 16th January 2020, 17:19   #58391  |  Link
oldpainlesskodi
Don't know if they are that similar, but I have no issues using Ryzen 7 3700x, obviously with a discrete GPU.
Sapphire RX 5700 XT (20.1.3) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1904.1), Silverstone LC13B-E, Onkyo TX-NR686, Samsung UE55KS8000, Mission M35i speakers, Kodi Dsplayer 17.6 X64
oldpainlesskodi is offline   Reply With Quote
Old 16th January 2020, 18:42   #58392  |  Link
why should a CPU create issues with video output?
that's not how it works.
it's not effect the video driver in any way it is not effecting the video output in any way.
Old 16th January 2020, 20:21   #58393  |  Link
mclingo
I just thought I'd read somewhere there was an issue, glad to be wrong.
Old 17th January 2020, 15:13   #58394  |  Link
stefanelli73
that TRADE QUALITY FOR PERFORMANCE option, has no effect on the hdr passthrough I also know for what I have specified that I have used it for the tone mapping of madvr
Old 17th January 2020, 15:37   #58395  |  Link
el Filou
el Filou's Avatar
What mclingo meant is that there is/was (?) a bug affecting RX 5700 users, where if madVR itself switches the card to HDR mode, it then outputs Bt.709 colour space instead of Bt.2020, so the image is seriously (not slightly) undersaturated.
If you did not encounter this issue when you used passthrough and let madVR do the switch then it means something is different on your RX 5700 system, or the bug has been fixed.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 17th January 2020, 16:09   #58396  |  Link
oldpainlesskodi
The bug is still there in the latest 20.1.2 drivers.
Old 17th January 2020, 18:35   #58397  |  Link
DMU
Minor fix:
It then outputs Bt.709 colour space flag instead of Bt.2020, so the image is seriously (not slightly) undersaturated. If on your TV you can forcefully select BT.2020 color space, then the image will be normal.
AMD APU with Vega iGPU has same issue.
R3 2200G / Vega8 / Samsung UE40NU7100
Win10Pro 1909 / 4K RGB 59Hz / AMD 20.1.3
MPC-HC 1.9.1 / madVR 0.92.17 / FSW / 10bit@59Hz
DMU is online now   Reply With Quote
Old 17th January 2020, 20:08   #58398  |  Link
mclingo
Hi,this is rough representation of what I am seeing with RX 5700 bug, beginning of bladerunner 2049
https://1drv.ms/u/s!AgvFafeelEBij75e...ll3yw?e=nM5M1Y
Old 18th January 2020, 01:44   #58399  |  Link
Asmodian
Yes, that looks like what I would expect from that bug.
madVR options explained
Old 18th January 2020, 02:39   #58400  |  Link
WuNgUn
Man!
On a Plex media group on Facebook...
People trying to tell me their Firestick is a better renderer than a decent HTPC with MadVR/LAV upscaling, etc played thru Jriver MC or equivalent....
Some people's kids...
WuNgUn is online now   Reply With Quote
