23rd November 2017, 02:06 | #5781 | Link |
Cannot select languaje
The One Click Encoder window is not resizeable and the input selector field is too wide and part of it, the part that allows to select an option, is outside the window limits:
https://www.dropbox.com/s/hn0v75nqo0...ptura.png?dl=0 Last edited by Pko; 23rd November 2017 at 02:13. |
23rd November 2017, 02:51 | #5782 | Link |
Also, the audio processing gets hung forever for some files:
Log: https://www.dropbox.com/s/s9j3ztspkevs73h/log1.log?dl=0 Capture: https://www.dropbox.com/s/5tw3vocnuc...83%29.png?dl=0 The task uses 31% CPU permanently and never ends MeGUI 2774 updated |
23rd November 2017, 10:54 | #5783 | Link |
Your log seems ok, but sometimes the NeroAacEnc have troubles with not congruent parameters:
-lc -q 0.3 In Automatic profile (always recomended with Variable BitRate) a quality of 0.3 output -he profile, use 0.32 at least to obtain -lc quality. EDIT: With a music sample file (48 KHz) I obtain a HE 88 Kb/s with -q 0.3 LC 90 Kb/s with -q 0.32 LC 94 Kb/s with -q 0.35 I recommend at least 0.35 for LC (it's not good work in limits) @Zathor Maybe in Nero AAC configuration dialog you can disable the AAC Profile, and let in Automatic, when Variable Bitrate is selected. And replace the label with: Variable Bitrate, Q > 0,31 for AAC LC (Q=selected)
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 23rd November 2017 at 11:55. Reason: add info |
25th November 2017, 09:28 | #5785 | Link |
This is intentional. Read the changelog.
DirectShoiwSource is the most unreliable way to process media files. If you really want to use it, enable it manually. It's your own risk. |
25th November 2017, 16:18 | #5788 | Link | |
http://rationalqm.us/board/viewtopic.php?f=8&t=605 EDIT: Solution found Last edited by Zathor; 26th November 2017 at 18:33. |
26th November 2017, 19:57 | #5789 | Link |
2787 [AVS Script Creator] added mpls as supported input type [File Indexer] added mpls as supported input type [File Indexer] do not reset the output path when selecting a different indexer if the path has already been set 2786 [DGIndex* Indexer] all: support absolute paths in the index files when written with Full_Path_In_Files=0 IM/NV: ensure that ResponseOnAudioMismatch=0 is not set (if set, it will be set to 1) 2785 [Nero AAC Encoder] if VBR is used the profile will automatically be selected |
27th November 2017, 09:47 | #5790 | Link |
No
[Error] Log -[Information] Versions --[Information] MeGUI: 2787 x64 --[Information] System Information ---[Information] Operating System: Windows 10 Professional 1709 x64 (10.0.16299.64) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.7 (4.7.02556) --[Information] Component Information ---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) ---[Information] Haali DSS2: not installed ---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) ---[Information] MediaInfo: 17.10.0.0 (02-11-2017) ---[Information] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) ---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) ---[Information] 7z: 9.20 (18-11-2010) --[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2721.0 ----[Information] Date: 29-04-2017 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] File Version: 0.1 ----[Information] Date: 15-11-2017 ----[Information] Name: AviSynth+ 0.1 (r2544, MT, x86_64) ----[Information] Version: AviSynth+ 0.1 (r2544, MT, x86_64) ----[Information] AviSynth+: true ----[Information] MT: true ----[Information] Status: active ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] Date: 15-11-2017 ----[Information] Name: AviSynth+ 0.1 (r2544, MT, x86_64) ----[Information] Status: inactive -[Information] Update detection --[Information] [27.11.2017 09:41:48] Automatic update is disabled --[Information] [27.11.2017 09:41:48] Using cached update config and server: http://megui.tmebi.de/test/ --[Information] [27.11.2017 09:41:48] No package requires an update -[Information] HD Streams Extractor --[Information] [27.11.2017 09:42:17] Input: D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls --[Information] [27.11.2017 09:42:17] Arguments: "D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls" --[Information] [27.11.2017 09:42:18] 1) 00800.mpls, 00800.m2ts, 1:49:29 --[Information] [27.11.2017 09:42:18] - Chapters, 28 chapters --[Information] [27.11.2017 09:42:19] - h264/AVC, 1080p24 /1.001 (16:9) --[Information] [27.11.2017 09:42:19] - DTS Master Audio, English, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - DTS, French, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - DTS, German, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - DTS, Italian, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - DTS, Spanish, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - AC3, Czech, stereo, 48kHz --[Information] [27.11.2017 09:42:19] - AC3, Hungarian, multi-channel, 48kHz --[Information] [27.11.2017 09:42:19] - AC3, Polish, stereo, 48kHz --[Information] [27.11.2017 09:42:19] - AC3, Turkish, stereo, 48kHz --[Information] [27.11.2017 09:42:20] - AC3, English, stereo, 48kHz --[Information] [27.11.2017 09:42:20] Feature Retrieval Completed --[Information] [27.11.2017 09:42:20] Arguments: "D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls" 1) -progressnumbers --[Information] [27.11.2017 09:42:22] M2TS, 1 video track, 10 audio tracks, 24 subtitle tracks, 1:49:29, 24p /1.001 --[Information] [27.11.2017 09:42:22] 1: Chapters, 28 chapters --[Information] [27.11.2017 09:42:22] 2: h264/AVC, 1080p24 /1.001 (16:9) --[Information] [27.11.2017 09:42:22] 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz --[Information] [27.11.2017 09:42:23] (core: DTS, 5.1 channels, 1509kbps, 48kHz) --[Information] [27.11.2017 09:42:23] 4: DTS, French, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:23] 5: DTS, German, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:23] 6: DTS, Italian, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:23] 7: DTS, Spanish, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:23] 8: AC3 Surround, Czech, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:23] 9: AC3, Hungarian, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:23] 10: AC3, Polish, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:23] 11: AC3 Surround, Turkish, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:23] 12: AC3, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:24] 13: Subtitle (PGS), English --[Information] [27.11.2017 09:42:24] 14: Subtitle (PGS), French --[Information] [27.11.2017 09:42:24] 15: Subtitle (PGS), Danish --[Information] [27.11.2017 09:42:24] 16: Subtitle (PGS), Finnish --[Information] [27.11.2017 09:42:24] 17: Subtitle (PGS), German --[Information] [27.11.2017 09:42:24] 18: Subtitle (PGS), Italian --[Information] [27.11.2017 09:42:24] 19: Subtitle (PGS), Dutch --[Information] [27.11.2017 09:42:24] 20: Subtitle (PGS), Norwegian --[Information] [27.11.2017 09:42:24] 21: Subtitle (PGS), Spanish --[Information] [27.11.2017 09:42:24] 22: Subtitle (PGS), Swedish --[Information] [27.11.2017 09:42:25] 23: Subtitle (PGS), Czech --[Information] [27.11.2017 09:42:25] 24: Subtitle (PGS), Arabic --[Information] [27.11.2017 09:42:25] 25: Subtitle (PGS), Modern Greek --[Information] [27.11.2017 09:42:25] 26: Subtitle (PGS), Hungarian --[Information] [27.11.2017 09:42:25] 27: Subtitle (PGS), Icelandic --[Information] [27.11.2017 09:42:25] 28: Subtitle (PGS), Hebrew --[Information] [27.11.2017 09:42:25] 29: Subtitle (PGS), Polish --[Information] [27.11.2017 09:42:25] 30: Subtitle (PGS), Portuguese --[Information] [27.11.2017 09:42:25] 31: Subtitle (PGS), Turkish --[Information] [27.11.2017 09:42:25] 32: Subtitle (PGS), French --[Information] [27.11.2017 09:42:26] 33: Subtitle (PGS), German --[Information] [27.11.2017 09:42:26] 34: Subtitle (PGS), Italian --[Information] [27.11.2017 09:42:26] 35: Subtitle (PGS), Dutch --[Information] [27.11.2017 09:42:26] 36: Subtitle (PGS), Spanish --[Information] [27.11.2017 09:42:26] Stream Retrieval Completed --[Information] [27.11.2017 09:42:37] Input: D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls --[Information] [27.11.2017 09:42:37] Arguments: "D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls" --[Information] [27.11.2017 09:42:37] 1) 00800.mpls, 00800.m2ts, 1:49:29 --[Information] [27.11.2017 09:42:37] - Chapters, 28 chapters --[Information] [27.11.2017 09:42:37] - h264/AVC, 1080p24 /1.001 (16:9) --[Information] [27.11.2017 09:42:37] - DTS Master Audio, English, multi-channel, 48kHz --[Information] [27.11.2017 09:42:37] - DTS, French, multi-channel, 48kHz --[Information] [27.11.2017 09:42:37] - DTS, German, multi-channel, 48kHz --[Information] [27.11.2017 09:42:37] - DTS, Italian, multi-channel, 48kHz --[Information] [27.11.2017 09:42:37] - DTS, Spanish, multi-channel, 48kHz --[Information] [27.11.2017 09:42:37] - AC3, Czech, stereo, 48kHz --[Information] [27.11.2017 09:42:38] - AC3, Hungarian, multi-channel, 48kHz --[Information] [27.11.2017 09:42:38] - AC3, Polish, stereo, 48kHz --[Information] [27.11.2017 09:42:38] - AC3, Turkish, stereo, 48kHz --[Information] [27.11.2017 09:42:38] - AC3, English, stereo, 48kHz --[Information] [27.11.2017 09:42:38] Feature Retrieval Completed --[Information] [27.11.2017 09:42:38] Arguments: "D:\Temp\BluRay\GIRL_NEXT_DOOR_F2\BDMV\PLAYLIST\00800.mpls" 1) -progressnumbers --[Information] [27.11.2017 09:42:39] M2TS, 1 video track, 10 audio tracks, 24 subtitle tracks, 1:49:29, 24p /1.001 --[Information] [27.11.2017 09:42:39] 1: Chapters, 28 chapters --[Information] [27.11.2017 09:42:39] 2: h264/AVC, 1080p24 /1.001 (16:9) --[Information] [27.11.2017 09:42:40] 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz --[Information] [27.11.2017 09:42:40] (core: DTS, 5.1 channels, 1509kbps, 48kHz) --[Information] [27.11.2017 09:42:40] 4: DTS, French, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:40] 5: DTS, German, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:40] 6: DTS, Italian, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:40] 7: DTS, Spanish, 5.1 channels, 768kbps, 48kHz --[Information] [27.11.2017 09:42:40] 8: AC3 Surround, Czech, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:40] 9: AC3, Hungarian, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:40] 10: AC3, Polish, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:40] 11: AC3 Surround, Turkish, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:41] 12: AC3, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB --[Information] [27.11.2017 09:42:41] 13: Subtitle (PGS), English --[Information] [27.11.2017 09:42:41] 14: Subtitle (PGS), French --[Information] [27.11.2017 09:42:41] 15: Subtitle (PGS), Danish --[Information] [27.11.2017 09:42:41] 16: Subtitle (PGS), Finnish --[Information] [27.11.2017 09:42:41] 17: Subtitle (PGS), German --[Information] [27.11.2017 09:42:41] 18: Subtitle (PGS), Italian --[Information] [27.11.2017 09:42:41] 19: Subtitle (PGS), Dutch --[Information] [27.11.2017 09:42:41] 20: Subtitle (PGS), Norwegian --[Information] [27.11.2017 09:42:41] 21: Subtitle (PGS), Spanish --[Information] [27.11.2017 09:42:42] 22: Subtitle (PGS), Swedish --[Information] [27.11.2017 09:42:42] 23: Subtitle (PGS), Czech --[Information] [27.11.2017 09:42:42] 24: Subtitle (PGS), Arabic --[Information] [27.11.2017 09:42:42] 25: Subtitle (PGS), Modern Greek --[Information] [27.11.2017 09:42:42] 26: Subtitle (PGS), Hungarian --[Information] [27.11.2017 09:42:42] 27: Subtitle (PGS), Icelandic --[Information] [27.11.2017 09:42:42] 28: Subtitle (PGS), Hebrew --[Information] [27.11.2017 09:42:42] 29: Subtitle (PGS), Polish --[Information] [27.11.2017 09:42:42] 30: Subtitle (PGS), Portuguese --[Information] [27.11.2017 09:42:42] 31: Subtitle (PGS), Turkish --[Information] [27.11.2017 09:42:43] 32: Subtitle (PGS), French --[Information] [27.11.2017 09:42:43] 33: Subtitle (PGS), German --[Information] [27.11.2017 09:42:43] 34: Subtitle (PGS), Italian --[Information] [27.11.2017 09:42:43] 35: Subtitle (PGS), Dutch --[Information] [27.11.2017 09:42:43] 36: Subtitle (PGS), Spanish --[Information] [27.11.2017 09:42:43] Stream Retrieval Completed -[Information] FileIndexer -[Error] Unhandled error --[Information] [27.11.2017 09:42:43] Exception message ---[NoImage] Der Wert darf nicht NULL sein. ---[NoImage] Parametername: path1 --[Information] [27.11.2017 09:42:43] Stacktrace ---[NoImage] bei System.IO.Path.Combine(String path1, String path2) ---[NoImage] bei MeGUI.FileIndexerWindow.GetDVDSource(String fileName, MediaInfoFile& iFileTemp) ---[NoImage] bei MeGUI.FileIndexerWindow.openVideo(String fileName) ---[NoImage] bei MeGUI.FileIndexerWindow.setConfig(String input, String projectName, Int32 demuxType, Boolean showCloseOnQueue, Boolean closeOnQueue, Boolean loadOnComplete, Boolean updateMode) ---[NoImage] bei MeGUI.AviSynthWindow.openVideoSource(String videoInput, String indexFileTemp) ---[NoImage] bei MeGUI.AviSynthWindow.input_FileSelected(FileBar sender, FileBarEventArgs args) ---[NoImage] bei MeGUI.FileBar.triggerEvent() ---[NoImage] bei MeGUI.FileBar.openButton_Click(Object sender, EventArgs e) ---[NoImage] bei System.Windows.Forms.Control.OnClick(EventArgs e) ---[NoImage] bei System.Windows.Forms.Button.OnClick(EventArgs e) ---[NoImage] bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) ---[NoImage] bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) ---[NoImage] bei System.Windows.Forms.Control.WndProc(Message& m) ---[NoImage] bei System.Windows.Forms.ButtonBase.WndProc(Message& m) ---[NoImage] bei System.Windows.Forms.Button.WndProc(Message& m) ---[NoImage] bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) --[Information] [27.11.2017 09:42:43] Inner exception: null |
27th November 2017, 19:19 | #5792 | Link | ||
MeGUI 2787 won't add --b-adapt 2 to the command line when using x264's slow preset
Hello to everyone.
I've been encoding several files in MeGUI 2787, with x264 codec, using preset Slow, and ticking the "show advanced settings" checkbox to change ME method from hex to uneven multihex and "adaptive b-frames" to 2 (Optimal) (the default option for x264's slow preset now is 1 (fast), but in fact the default option in MeGUI is 2). The thing is I want to use --b-adapt 2 but even when I set it in the GUI, the command line is: Quote:
So, the encoded file is reported by Mediainfo as: Quote:
Thank you very much.
I like to remember things my own way. Not necessarily the way they happened. (Fred Madison) Last edited by numaios; 27th November 2017 at 19:36. Reason: (The bug still exists in 2787 dev version) |
27th November 2017, 19:49 | #5793 | Link |
Thanks, please test it with the debug build: http://megui.org/megui_debug.zip
EDIT: Ignore it, I found the line. But I do not know what is causing it... I tried several Blu-ray files and it does work as intended. Searching... Last edited by Zathor; 27th November 2017 at 20:23. |
27th November 2017, 19:53 | #5794 | Link |
As you wrote MeGUI is not adding anything related to --b-adapt as it is the default. So the problem likely is somewhere else. Could you maybe upload an encoding log if it is added there? Have you already tried to reset the profile to default?
27th November 2017, 20:02 | #5795 | Link |
27th November 2017, 20:16 | #5796 | Link | |
Preliminary log file only. During closing of MeGUI the well formed log file will be written. -[Information] Versions --[Information] MeGUI: 2787 x86 --[Information] MeGUI Debug Data: available -[Information] Operating System: Windows 10 Professional 1709 x64 (10.0.16299.64) -[Information] .NET Framework: 4.0 (4.0.0.0) -[Information] .NET Framework: 4.7 (4.7.02556) --[Information] System Information -[Information] Update detection --[Information] [27.11.2017 20:12:09] Automatic update is disabled -[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) -[Information] Haali DSS2: not installed -[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) --[Information] [27.11.2017 20:12:09] Using cached update config and server: http://megui.org/auto/ -[Information] MediaInfo: 17.10.0.0 (02-11-2017) -[Information] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) -[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) -[Information] 7z: 9.20 (18-11-2010) --[Information] Component Information --[Information] [27.11.2017 20:12:09] There are 14 packages which can be updated: MeGUI, MeGUI Libraries, MediaInfo, DGIndex, DGIndexNV, Xvid, FFmpeg, FFMS, AviSynth portable, AviSynth plugins, DGIndexIM, L-SMASH Works, x265, Runtime Files -[Information] Version: 1.0.2721.0 -[Information] Date: 29-04-2017 -[Information] Interface: n/a -[Information] AviSynth Wrapper -[Information] File Version: 0.1 -[Information] Date: 15-11-2017 -[Information] Name: AviSynth+ 0.1 (r2544, MT, i386) -[Error] Unhandled error --[Information] [27.11.2017 20:12:09] Exception message: Es wurde versucht, eine Datei mit einem falschen Format zu laden. (Ausnahme von HRESULT: 0x8007000B) -[NoImage] bei MeGUI.AviSynthClip.dimzon_avs_init_2(IntPtr& avs, String func, String arg, AVSDLLVideoInfo& vi, AviSynthColorspace& originalColorspace, AudioSampleType& originalSampleType, String cs) -[NoImage] bei MeGUI.AviSynthClip.CheckAvisynthInstallation(String& strVersion, Boolean& bIsAVS26, Boolean& bIsAVSPlus, Boolean& bIsMT) in D:\MeGUI\_MeGUI_clean\packages\tools\avscreator\AvisynthWrapper.cs:Zeile 481. -[NoImage] bei MeGUI.core.util.FileUtil.CheckAviSynth(LogItem& oLog) in D:\MeGUI\_MeGUI_clean\core\util\FileUtil.cs:Zeile 705. -[NoImage] bei MeGUI.MainForm.getVersionInformation() in D:\MeGUI\_MeGUI_clean\core\gui\MainForm.cs:Zeile 1385. -[NoImage] bei MeGUI.MainForm..ctor() in D:\MeGUI\_MeGUI_clean\core\gui\MainForm.cs:Zeile 170. -[NoImage] bei MeGUI.MainForm.Main(String[] args) in D:\MeGUI\_MeGUI_clean\core\gui\MainForm.cs:Zeile 1087. --[Information] [27.11.2017 20:12:09] Stacktrace --[Information] [27.11.2017 20:12:09] Inner exception: null |
27th November 2017, 20:23 | #5797 | Link | |||
http://git.videolan.org/?p=x264/x264...30eae3578c251d It's like if MeGUI "thought" it has an outdated x264 version. Quote:
[Warning] Log -[Information] Versions --[Information] MeGUI: 2787 x86 --[Information] System Information ---[Information] Operating System: Windows 10 Home 1607 x64 (10.0.14393.1884) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.7 (4.7.02053) --[Information] Component Information ---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) ---[Information] Haali DSS2: (14-04-2013) ---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (16-11-2017) ---[Information] MediaInfo: 17.10.0.0 (16-11-2017) ---[Information] MessageBoxExLib: 1.0.2218.28317 (16-11-2017) ---[Information] SevenZipSharp: 0.64.3890.29348 (16-11-2017) ---[Information] 7z: 9.20 (16-11-2017) --[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2721.0 ----[Information] Date: 16-11-2017 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] not installed ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] Date: 15-11-2017 ----[Information] Name: AviSynth+ 0.1 (r2544, MT, i386) ----[Information] Version: AviSynth+ 0.1 (r2544, MT, i386) ----[Information] AviSynth+: true ----[Information] MT: true ----[Information] Status: active [...] -[Information] Log for job505 (video, Cameo.mkv.avs -> Cameo_Video.264) --[Information] [27/11/2017 20:09:48] Started handling job --[Information] [27/11/2017 20:09:48] Preprocessing --[Information] [27/11/2017 20:09:48] AviSynth input script ---[NoImage] LoadPlugin("C:\Program Files (x86)\MeGUI-2774-32\tools\lsmash\LSMASHSource.dll") ---[NoImage] LWLibavVideoSource("D:\Users\J\Videos\0r51zqlt.40r\Cameo.mkv.lwi") ---[NoImage] #Not enough useful sections for source detection. Doing no processing ---[NoImage] #crop ---[NoImage] LanczosResize(720,404) # Lanczos (Sharp) ---[NoImage] #denoise --[Information] [27/11/2017 20:09:49] resolution: 720x404 --[Information] [27/11/2017 20:09:49] frame rate: 25/1 --[Information] [27/11/2017 20:09:49] frames: 439 --[Information] [27/11/2017 20:09:49] aspect ratio (avs): 180:101 (1.782) --[Information] [27/11/2017 20:09:49] Job command line: "C:\Program Files (x86)\MeGUI-2774-32\tools\x264\avs4x26x.exe" --x26x-binary "C:\Program Files (x86)\MeGUI-2774-32\tools\x264\x264.exe" --preset slow --tune film --crf 21.0 --me umh --sar 1:1 --output "D:\Users\J\Videos\0r51zqlt.40r\Cameo_Video.264" "D:\Users\J\Videos\0r51zqlt.40r\Cameo.mkv.avs" Quote:
-If you select "0-Off" in the dropdown list, " --b-adapt 0" is added to the command line. -If you select "1-Fast" in the dropdown list, " --b-adapt 1" is added to the command line. -If you select "2-Optimal" in the dropdown list, nothing is added to the command line (as if the default option was 2, but it isn't, so the x264 version used by MeGUI won't apply the correct setting)
I like to remember things my own way. Not necessarily the way they happened. (Fred Madison) Last edited by numaios; 27th November 2017 at 20:26. |
27th November 2017, 21:17 | #5800 | Link |
Please use: http://megui.org/megui_debug_x64.zip
