Old 26th May 2019, 02:09   #501  |  Link
Exaris
Inspector Gadget
What Vapoursynth filter should I use for color correction? Westworld's 4K BluRay has an ugly brown tint to everything that is not present in the 1080p BluRay release.
Also, how would I use the preview window to display HDR10 on an 8-bit monitor (like MadVR can) while I try to get rid of the tint?
Would I need to use mobius to tone map to SDR? Does StaxRip even have tonemapping filters for Vapoursynth?
Help would be much appreciated
Exaris is offline
Old 28th May 2019, 18:08   #502  |  Link
Natty
Noob
have been getting this error since a long time
https://imgur.com/download/Iwzeo7e
i thought this was because of low ram but many users are getting this issue,mostly when using too many avs filters. preview windows also does the same. encoding starts after retrying 2-3 times, its bad for queuing and batch processing.
Natty is offline
Old 29th May 2019, 18:21   #503  |  Link
RainyDog
Yeah I often get this too, usually when trying to run a batch of jobs.
Seems it's something to do with StaxRip not flushing open/completed jobs from memory unless the program is closed down.
A way around it is to create a job, send it to the queue and close StaxRip. Then re-open the program and run the job straight from the jobs queue without editing the job again.
But this obviously means you can only run one encode at a time or risk the memory error as there's a ram build up with each concurrent job until the program's closed.
RainyDog is offline
Old 29th May 2019, 19:46   #504  |  Link
Natty
Noob
i do that, setup job and save as srip file and restart stax. but it does not solve the issue always. i still get the error while using 3 or more avs filters mostly
Natty is offline
Old 29th May 2019, 19:47   #505  |  Link
Natty
Noob
its not appearing like that anymore. no idea what happened.
also --stylish doesn't work
updated to 2.0.2.1 today (i thought 2.0.2.2 was latest) , the bundled x265 3.0.0.24 was showing estimated file size, i updated it to 3.0.0.31 from msystem.waw.pl/x265. gcc 9.1.1 avx2 ver and it didn't show it. maybe your version is patched or modded?
Natty is offline
Old 29th May 2019, 21:11   #506  |  Link
stax76
stax76's Avatar
Usually I just pick random builds from users that are around for a while and I think can be trusted, it's a very nice feature, I try to find out where it comes from.
I try to do more test encodes. In 1.7 batch processing was well tested I think and problems were usually filters leaking memory.
Revan has expertise in this area, my 4K screens unfortunately don't have HDR support.
stax76 is offline
Old 30th May 2019, 11:03   #507  |  Link
vanden
Sorry, I may not be in the right forum ...
Here is my problem, I have 2 rip bluray 2160p and the problem is that it must miss some info.
Blade Runner 2049:
Do not pass with "madMeasureDynamicClipping", I rename the file .measurements.incomplete in .measurements and I open it with "madMeasureDynamicClipping":
************** Texte de l'exception **************
System.OverflowException: The arithmetic operation caused an overflow.
à madMeasureDynamicClipping.FrmMain.ImportData()
à madMeasureDynamicClipping.FrmMain.StartAnalysis()
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Button.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Reading it with "madMeasureDynamicClipping" I get this :
By removing all the .measurements.incomplete and .measurements files, I get this :
Pass in "Tone map HDR MadVR" :
Sully:
Do not pass with "madMeasureDynamicClipping" :
Do you have a solution ?
T2 Trainspotting everything is ok :
Ok avec "madMeasureDynamicClipping" :
By removing all the .measurements files, I get this :
EDIT : For sully :
After watching the movie I have some errors at the decompression : Frame that bug to 84274-84280, 85403-85426, 85448-85450, 85629-85646, 85794-85816 ... at this point MPC HC stops the movies, We put back after 59.44 Second ... 85917-85919, 89795-89824, 97386-97394, 98840-98857, 99819-99820, 99970-99971, 100328-100334, 100355-100371 ... at this point MPC HC stops the movies, We put back after 1H09min47sec ... 100401, 101005-101028, 101170-101172 ...
vanden is offline
Old 30th May 2019, 12:47   #508  |  Link
Natty
Noob
i checked dll files bundled with stax 2.0.2.1 in avsmeter64, needi3 is 32bit. is it ok?
Natty is offline
Old 31st May 2019, 07:24   #509  |  Link
stax76
stax76's Avatar
It cannot be 32bit because it would not work.
stax76 is offline
Old 31st May 2019, 10:47   #510  |  Link
katzenjoghurt
Originally Posted by jsdukeboy08 View Post
Edit: after doing some additional tests it appears that the 3.0_AU+8 works fine with zones and has no errors in staxrip upon encoding completion. The two other versions, +10 and +14, however do not work and will give the same corrupted heap error.
This still drives me crazy.
With every new x265 version I hope that things would start working again - but they don't.
Last time Ma fixed that error for me in version AU+8.
Afterwards they did another fix and things would start breaking again in StaxRip. And only for StaxRip.
I can't reproduce the problem when encoding via command line.
This one just works:
"w:\Tools\Video Tools\ffmpeg\ffmpeg.exe" -i aquaman-trailer-cut.mkv -f yuv4mpegpipe - | x265.exe - --crf 22 --tune grain --profile main10 --output-depth 10 --rskip --zones 0,200,b=1.2 --qcomp 0.8 --no-open-gop --no-deblock --no-strong-intra-smoothing --frames 430 --y4m -o output.hevc
...while in StaxRip (no matter if I use 1.7.0.6 or 2.0.0.2) it would crash with the same settings. (No matter what video file I try - long ones, short ones - the encoding will always crash after it has finished).
https://i.imgur.com/thOtxVT.png
This means:
In order to use a newer x265 version together with zones, you have to do the mkv merging yourself after the encoding finished (and crashed).
@Stax, Revan:
Would you mind investigating this issue if you find the time?
I failed in isolating whether this is an x265 or StaxRip related issue.
katzenjoghurt is offline
Old 31st May 2019, 11:45   #511  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
The Guy who ripped the UHDs has forgot to set the HDR10+ Metadates with x265. The following Commandline must be set by encoding:
--hdr-opt --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --range limited --bframes 4 --hrd --max-cll "1000,400" --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)"
-QfG- is offline
Old 31st May 2019, 14:41   #512  |  Link
stax76
stax76's Avatar
The error exit code is there, you are just not checking for it.
stax76 is offline
Old 31st May 2019, 17:17   #513  |  Link
Natty
Noob
plugin update
https://forum.doom9.org/showthread.p...69#post1875869
Natty is offline
Old 1st June 2019, 09:50   #514  |  Link
stax76
stax76's Avatar
Hey everyone, I've uploaded a new built with a few updates and minor improvements.
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/f/s!ArwKS_ZUR01gySQIE1QCL2i9F_uR
2.0.2.2
  • new icons added and credits in about (info) dialog updated,
    thanks to: Freepik, ilko-k, nulledone, vanontom
  • the progress bar in the processing window has better contrast
  • video encoding with ffmpeg shows now progress in the progress bar and task bar
  • if in the codec dialogs search field the enter key is pressed in order to cycle
    there is no longer an annoying sound made
  • encoding was failing when a ambersand (&) character was used in the path
  • new AV1 codec option added to ffmpeg encoder
  • various improvements and fixes made in the ffmpeg encoder
  • new vceenc switches added
  • new nvencc switches added
  • new x265 switches added
  • update: x265, Wolfberry build with avs input support,
    in the x265 options: Other > Piping Tool > None
  • update: mpvnet
  • update: ffmpeg, Wolfberry build with vpy input support
  • update: nvencc, untested
  • update: qsvencc, untested
  • update: vceencc, untested
stax76 is offline
Old 1st June 2019, 12:34   #515  |  Link
katzenjoghurt
Thanks for your reply, Stax!
Hm. Is there any way I COULD check for it from command line?
Old 1st June 2019, 13:35   #516  |  Link
stax76
stax76's Avatar
Thanks for the feedback! I've reported the issue here:
https://forum.doom9.org/showthread.p...63#post1875863
It shows how to check for it in Windows batch:
echo %ERRORLEVEL%
I don't know if there are other ways, I've never learned windows batch because I always thought it's a very bad language.
In PowerShell I do it like this:
function CheckExitCode {
    if ($LastExitCode -gt 0) {
        Write-Host "`nExit code $LastExitCode was returned.`n" -ForegroundColor Red
        exit
I've never verified that the code actually works, I hope it does, it's from a script I use to release mpv.net.
stax76 is offline
Old 1st June 2019, 16:25   #517  |  Link
vanden
Strange on the blade nfo I have:
Default: Yes
Forced: No
Color range: Limited
Color primaries: BT.2020
Transfer characteristics: PQ
Matrix coefficients: BT.2020 non-constant
Mastering display color primaries: R: x = 0.680000 y = 0.320000, G: x = 0.265000 y = 0.690000, B: x = 0.150000 y = 0.060000, White point: x = 0.312700 y = 0.329000
Mastering display luminance: min: 0.0050 cd / m2, max: 4000.0000 cd / m2
Maximum Content Light Level: 457 cd / m2
Maximum Frame-Average Light Level: 179 cd / m2
and on selui de Sully I have:
Default: Yes
Forced: No
Coordinates of chromaticity? BT.2020
Characteristics of the transfer: PQ
MasteringDisplay_ColorPrimaries: R: x = 0.680000 y = 0.320000, G: x = 0.265000 y = 0.690000, B: x = 0.150000 y = 0.060000, White point: x = 0.312700 y = 0.329000
MasteringDisplay_Luminance: min: 0.0050 cd / m2, max: 4000.0000 cd / m2
MaxCLL: 4000 cd / m2
MaxFALL: 290 cd / m2
The following Commandline must be set by encoding : Not possible to send after encoding (without all re-encode) ?
vanden is offline
Old 1st June 2019, 16:52   #518  |  Link
katzenjoghurt
Ahh... good stuff.
I swear to god I googled through several pages and didn't find anything.
And thanks for reporting. That was exactly what I had in mind to do.
I already upvoted an existing issue in gitlab weeks ago but as nothing happened I planned to make them aware in the forum too. I just failed to reproduce it via command line.
Thanks so much, Stax!!
I hope they see it and sort it out now.
Old 1st June 2019, 22:33   #519  |  Link
Natty
Noob
Natty is offline
Old 1st June 2019, 22:59   #520  |  Link
Natty
Noob
thanks. everything is working fine.
Natty is offline
aac, hdr, hevc, nvenc, staxrip, x264, x265
