5th May 2012, 07:34 | #1161 | Link |
No release notes for R2 nothing i guess it's just the IVY update to 1.3 API, like it was floating around in the beta driver
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
5th May 2012, 08:08 | #1162 | Link | |
QuickSync Decoder author
Changes from the 2012 gold version are: * Three new H.264 profiles and 6 (all defined in standard) constrained flags were defined. This change should simplify Media SDK usage by providing direct access to constrained flag configuration. MFX_PROFILE_AVC_CONSTRAINT_SET0/1/2/3/4/5 MFX_PROFILE_AVC_CONSTRAINED_BASELINE MFX_PROFILE_AVC_CONSTRAINED_HIGH MFX_PROFILE_AVC_PROGRESSIVE_HIGH * View output mode was added for MVC encoder mfxExtCodingOption::ViewOutput. This flag instructs encoder to output each view in separate bitstream buffer and format them according to Blu-ray* and AVCHD* Format requirements. * MVC encode now supports interlace coding mode.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
5th May 2012, 19:53 | #1163 | Link |
Hey Eric,
i found a sample with quite an odd behaviour today. http://files.1f0.de/samples/h264-qs-timestamp-issue.mkv When i play this file with LAV in QS mode, it plays too fast (should be 24p, plays at 30p), running out of sync. I checked the timestamps of the file, and they are fine. Plays fine with software or other hardware codecs too. For some reason, the QS decoder insists on changing the timestamps, even though i turn off the timestamp mangling flag that you expose. I'm running driver 2696, happens both on my Ivy and Sandy systems. I just tried 2656, and the problem does not occur anymore. The driver dependency makes me believe its the MediaSDK itself causing this, and not your code directly. Can you maybe check if its something you can turn off, or maybe if the problem is just gone in a newer driver which i don't have yet? Edit: 2712 is also showing the problem. Either its a bug in the newer MediaSDK libraries which you should forward, or its a feature thats on by accident?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th May 2012 at 20:13. |
5th May 2012, 21:31 | #1164 | Link | |
I've root caused the problem: * H264 SPS header doesn't contain a frame rate (num_units_in_tick = time_scale = 0). * If I manually set the frame rate for the MSDK to 23.976 it will behave correctly. * This happens even when VPP is off and no time stamp calculation/manipulation. Nev, make sure the version of the MSDK HW DLL is 368 (from 2696) not 369 (from 2712). I've committed a patch that also fixes some DI issues along with a workaround for the above issue (r51). Here's my commit log: Code:
Experimental build - not stable enough for production SW. * Update to MSDK 2012 R2. * Workaround for MSDK bug - zero frame rate in H264 SPS header would cause a wrong frame rate. * Deinterlacing now works on frames stored as progressive but marked as interlaced content (many PAL TV broadcasts). * Telecined content not supported by DI (yet).
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 5th May 2012 at 22:27. |
6th May 2012, 07:26 | #1165 | Link |
Eric,
if you try the 4K clips posted by Wanezhiling and me, you can use PotPlayer's internal built-in codecs, because it has an option to "force" HW decoding above 1080p. The tab key shows CPU utilization of PotPlayer process alone and overall CPU utilization at the same time, separated by a "/". This is in case you want to check playback performance, not benchmarks of course. PotPlayer has an extra advantage: It has direct/ native internal DXVA playback and your QS decoder as an option, too. So you can check both (direct DXVA and QS decoder) in an easy way, until Nevcariel fixes LAV filters playing 4K in direct mode.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 6th May 2012 at 07:32. |
6th May 2012, 09:36 | #1166 | Link |
Tested 5 4K clips using LAV and ffdshow.
LAV and ffdshow showed very similar results so I just wrote LAV-QS score. The CPU% is how much the player's process took, not the entire system. All clips maxed out turbo at 3.4GHz. Performance wasn't constant during playback as the clips varied in bitrate - OldTownCross ran at 280mbps, peaking at 500 (!) mbps which is outside H264 spec. CrowdedRun 29% (up to 34%)-3.4GHz DucksTakeOff 36% (up to 42%) -3.4GHz InToTree 32% (up to 36%) -3.4GHz OldTownCross 36% (up to 42%) -3.4GHz ParkJoy 29% (up to 31%) -3.4GHz LAV DXVA-CB – half the CPU% of QS but drops a lot of frames (visually, EVR reports everything is OK). Clips are not playable. LAV DXVA-native – not working – uses libavcodec, maxes out CPU.
6th May 2012, 09:51 | #1167 | Link |
Native DXVA is limited to 1080p right now, because there are quite some issues with DXVA of 4K on AMD and NVIDIA.
Need to re-visit this in a while when everything has new drivers. Its not like 4K content is important right now. I probably should improve the logic to allow Intel, but will do that in one go when i check it again.
6th May 2012, 09:56 | #1168 | Link | |
6th May 2012, 11:14 | #1170 | Link | |
The HEVC standard isn't even finalized yet, and content providers will take years to adopt it anyway.
6th May 2012, 12:03 | #1171 | Link |
there is already an ARM chip that has HEVC support and that chip was released a while back. The final draft spec is out in july and ratified in january. Chip makers already have chips that can do HEVC hardware decoding such as qualcomm snapdragon and ziilabs: http://www.youtube.com/watch?v=vZfsULKG2Zo http://www.eetimes.com/electronics-n...ll-Android-SoC
So i'm pretty sure that intel could have support in haswell if they wanted to. Yes it will take a while for software support for HEVC but if they have hardware that can support it then your pc will be future proofed (video-wise) with a haswell cpu. Last edited by hajj_3; 6th May 2012 at 12:10. |
6th May 2012, 12:37 | #1172 | Link | ||
Intel would need a time machine to pull this off Quote:
6th May 2012, 14:38 | #1173 | Link |
New intel beta drivers for Windows 8, for both Sandy and Ivy.
They work also for Win 7 (I tried 32bit version with Core i5 and Win 7 SP1 x86) They include OpenGL 4 drivers for Ivy. You can download the HD Graphics driver v2927 (15.28.0.64.2729 (9.17.10.2729)) from this page 64bit: http://downloadcenter.intel.com/Deta...21180&lang=eng 32bit: http://downloadcenter.intel.com/Deta...21235&lang=eng
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
6th May 2012, 15:25 | #1175 | Link |
Ivy Bridge is either 2500 or 4000, none are 3000.
Both 2500 or 4000 should be able to play 4K.
6th May 2012, 16:14 | #1176 | Link | |
does it also fit performance wise 2000(GT1),2500(GT1),3000(GT2),4000(GT2?) ?
i doesn't looked @ a compare of 2500 (Ivy,GT1) vs 3000 (SB,GT2) yet though actually Ivy bridge has been renamed back to GT1 in that line so i guess it doesn't fit to continue the GT naming indeed as we talking about 6 (2500) vs 12 EUs (3000) and getting the same performance with half the EUs i doubt that (on the 3D part). And the speculation about Haswell also sound a little crazy 40 Eus with the Performance of what 80 or even 160 of the current EUs Quote:
Outch Normally i don't give much about Benchmarks but Microsofts Performance Index Shows a Performance Decrease of 1.1 Points on my HD 2000 for the Game Graphics Value before it was 5.8 (Aero Performance result stayed the same @ 5.2) that's a heavy drop before this drop it was constantly going up per driver release climaxing @ 5.8 with 2719 with 2729 now it dropped down to 4.7 (and becomes the final system result now compared to 5.2 before). This might indicates some big change here (maybe IQ wise ?) Have todo some real Engine tests to see if there is something realizable outside of Benchmarks I could swear Aero feels even snappier (this also constantly improved over driver releases) though (lower latency) even showing no real Benchmark improvement in the Performance Index. Yep definitely a good latency test is the Aero to Windows Basic change it's much much faster then it was in every previous driver (the mode change is almost fluid now, though Win 8 will be totally fluid WDDM 1.2 ) @egur Both Lav Video Quicksync as well as FFdshow Quicksync stopped working (DXVA works)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th May 2012 at 22:08. |
7th May 2012, 08:31 | #1177 | Link |
Windows 8 drivers have either broken MSDK DLLs or they are missing altogether. The Win8 drivers are beta and not fully functional.
7th May 2012, 08:54 | #1178 | Link |
I might be completely off in this matter but I can't enable QS on my i7-3770 (non K) and I can't find out why, LAV Filters lists it as "Not available" and it doesn't show up in ffdshow at all. Motherboard: MSI Z77A-GD65 OS: Windows 7 Pro 64-bit SP1 Driver: 8.15.10.2712 (link: http://downloadcenter.intel.com/Deta...adType=Drivers ) ffdshow: ffdshow_rev4441_20120430_xhmikosr_icl12.exe (I can give your build a go if you want to) LAV Filters: 0.50.2 Does it require lucid or something? //Danne |
7th May 2012, 10:58 | #1179 | Link | |
7th May 2012, 19:08 | #1180 | Link | |
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
