26th April 2011, 16:40 | #1861 | Link |
Thanks for the new version.
I have a issue when I switch the audio track using shortcut key. Mpchc (snv3052) crash with the message "Unspecified error" ("erreur non spécifiée" in french). It works using a mouse and the menu or key + internal splitter. It works for the subtitles. It would be great if Lavfsplitter supports internal mpchc shortcut key or includes his own shorcut key (eg: to be use with potplayer ) to switch stream. I use a remote on my htpc and send shortcut in order to control player (I guess I am not the only one ?) Thank you |
26th April 2011, 16:56 | #1863 | Link |
The only time i've seen that error was with AC3Filter, get rid of that and it should work.
26th April 2011, 17:34 | #1864 | Link | |
Is it a mpchc issue ? I guess I could do the same processing with ffdshow audio However, a shortcut key would be pleasant for using lavfsplitter and potplayer |
26th April 2011, 17:36 | #1865 | Link |
I have no plans to do this. Its the players responsibility to offer this, you can request it from them.
26th April 2011, 19:14 | #1867 | Link |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
26th April 2011, 19:23 | #1868 | Link |
VP7 is not supported, and unless ffmpeg some day supports it, it won't be.
26th April 2011, 19:25 | #1869 | Link | |
even old default OS avi splitter support VP7 in AVI.
26th April 2011, 19:36 | #1870 | Link |
But this is a MKV.
What decoder can actually decode them? There isn't much fun in trying without one.
26th April 2011, 19:44 | #1871 | Link |
There is just one afaik. The official On2 VP7 decoder.
MPC-HC 2.2.1 |
26th April 2011, 19:48 | #1872 | Link | |
VP7 can be downlad here.
26th April 2011, 19:49 | #1873 | Link | |
PS: I case it wasn't obvious, that means i fixed it. It'll now even try to demux unknown tracks, as long as a FourCC is specified in the container.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th April 2011 at 19:57. |
26th April 2011, 20:27 | #1874 | Link | |
Does this mean that it's a ffmpeg bug? Does MPC-HC internal TS use ffmpeg? Code:
Input #0, mpegts, from 'z:\bdmv\stream\00000.m2ts': Duration: 01:21:03.44, start: 599.958311, bitrate: 13992 kb/s Program 1 Stream #0.0[0x1011]: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0.1[0x1100](por): Audio: ac3, 0 channels, s16 Stream #0.2[0x1101](eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s Stream #0.3[0x1200](por): Subtitle: pgssub
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
26th April 2011, 20:53 | #1875 | Link | |
I can try to tune the code to try to catch really broken streams .. or just show them and let the users figure out that they don't work.
26th April 2011, 21:50 | #1876 | Link |
http://files.1f0.de/lavf/LAVFilters-0.24-4-gfc2264b.zip
@BatKnight Try this build. I'm not sure how well decoding will work, the file must be broken somehow or channel detection wouldn't fail. @hoborg: This should also work with your vp7 file.
27th April 2011, 07:01 | #1877 | Link |
Hi nev, I'm trying out your new splitter, but I've run into a weird issue. It could be the splitter or the way the mkv is muxed. Maybe madVR (.58), but it doesn't happen with the Haali or MPC-HC splitters. I'm getting like 4 dropped frames per second.
The problem is that it happens only with some mkvs (so far some anime muxed from blu-ray) AND the combination of LAVF Splitter (.24) and madVR. If I switch to another video renderer (tried EVR-CP or Sync) then it doesn't happen. Ditto if I switch to another splitter like I said above. To add to my confusion, I made those mkvs with Makemkv 1.6.7. I remuxed one of them with MKVMerge and the issues were gone. If it helps I ran the mkvinfo on them. If you have any ideas how to troubleshoot this, I'd be grateful. Here are the txt files. File name: mkvinfo.zip File size: 4.18 KB There's 3 files. makemkv-bad is the one that shows the dropped frames. remux-mkvmerge-good is the same file, remuxed by mkvmerge that plays fine. For comparison I included another one, makemkv-good, also muxed by makemkv 1.6.7, but also runs smoothly. They're all AVC format, 24p. |
27th April 2011, 07:13 | #1878 | Link |
Can you check if maybe all broken files have TrueHD audio? Thats the only obvious difference in those two, mkvmerge writes different headers for TrueHD then MakeMKV does, and your makemkv-good has DTS audio.
Also, which audio decoder are you using? Can you try again with my LAV Audio Decoder? Another thing, when using EVR-CP, please make sure that "Frame Time Correction" is OFF (press C), and see if it then drops frames as well - or if i was off all the time.
27th April 2011, 07:24 | #1880 | Link |
Another thing you can try is flipping the "Disable Audio Stream Parsing" option in the LAV Splitter Properties (Video won't have any effect, AVC1 in MKV does not get parsed)
I can probably try to rip a Blu-ray with TrueHD audio later with MakeMKV, and see if something funny happens. I don't think its related to the video stream, because like i mentioned, AVC1 in MKV will just be output as is, it does not usually get touched at all.. unless, its one of those funny files that does not have B-Frames, then it might actually break .. but i have never seen one of those on a Blu-ray. Can you download http://research.m1stereo.tv/ffmpeg/s...26-1da254b.zip, in the "bin" folder is ffprobe, and run this command: ffprobe -loglevel debug PATH://to/file And post the full output?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th April 2011 at 07:27. |
