5th February 2012, 18:34 | #8841 | Link | ||
Apparently the 295 beta that was just released has some new issues, though, so stick with 290
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th February 2012 at 18:36. |
5th February 2012, 18:46 | #8843 | Link | |
Thank you. Last edited by RBG; 5th February 2012 at 18:49. |
5th February 2012, 19:04 | #8844 | Link |
I think I'm gonna go back to 290.36, as well. Re-setup my custom profiles and leave it alone until someone says there's a better driver.
5th February 2012, 19:43 | #8845 | Link | |
http://www.mediafire.com/?y8uf88pd33sxx75 |
5th February 2012, 20:02 | #8846 | Link |
I'm trying to get a hanndle on LAV filters. I have replaced Haalli with LAV & finding some videos play without sound.
Specifically, the file below will play without sound, but, if I disable AC3 under Lav Audio formats, it plays just fine. Am I missing something? Thanks Player WMP Windows 7 Ultimate No other codecs installed. Video Card nVidea Gt460 No Bitstreaming selected. General Complete name : C:\Videos\Luck.S01E01.720p.HDTV.x264-IMMERSE.mkv Format : Matroska Format version : Version 2 File size : 2.59 GiB Duration : 1h 0mn Overall bit rate : 6 177 Kbps Writing application : x264.exe Writing library : mkv2rls x264-tv version built on 2011. febr. 17 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 0mn Bit rate : 5 670 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.257 Stream size : 2.38 GiB (92%) Writing library : x264 core 120 r2119 0637cd6 Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=36 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 1h 0mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 165 MiB (6%) Language : English Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : No Forced : No Last edited by Della; 5th February 2012 at 20:07. |
5th February 2012, 20:11 | #8847 | Link | |
Edit: And should be fixed
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th February 2012 at 21:31. |
5th February 2012, 22:00 | #8848 | Link |
what issues are you guys referring to? because I tried 295 on my 9800GTX and VMR9 becomes unstable after awhile and crashes. I reverted to 257 release drivers (which is also the last version that CUVID works right with interlaced VC-1 (havn't tested MPEG-2 or H.264)
Was this one of the known issues with 295 and 290.53? |
5th February 2012, 22:07 | #8850 | Link |
Well, after not being able to play the file on two Win 7 64 machines I found the solution was to uninstall LAV & re-install Haali Media Splitter. Playback works normally.
I couldn't get the video portion to play (it would remain on a fixed position as if paused) at all with LAV, but, interestingly works fine with Haali. Della [QUOTE=Della;1556128]I'm trying to get a hanndle on LAV filters. I have replaced Haalli with LAV & finding some videos play without sound. Specifically, the file below will play without sound, but, if I disable AC3 under Lav Audio formats, it plays just fine. Am I missing something? Thanks Player WMP Windows 7 Ultimate No other codecs installed. Video Card nVidea Gt460 No Bitstreaming selected. Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 1h 0mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 165 MiB (6%) Language : English Default : Yes Forced : No |
5th February 2012, 22:12 | #8851 | Link | |
You should decide what your problem is. There is a known issue with WMP being "stuck" like that when there is subtitles involved. I'm working on it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th February 2012 at 22:23. |
5th February 2012, 22:26 | #8852 | Link | |
I believe the problem with the audio is limited to 2 channel AAC as everything else seemed OK. I'd be happy to provide the sample, I can assure you there is a problem in the lav splitter or audio. Thanks for taking the time to respond. I see you edited the post, yes there are sub titles involved. Thank you. Della Last edited by Della; 5th February 2012 at 22:29. |
5th February 2012, 22:35 | #8853 | Link |
The video stalling issue should be fixed for the next version.
If a specific file doesn't work, a sample would be good.
6th February 2012, 00:07 | #8854 | Link |
isn't there something known about wrong sampling frequencies Della try to remux it with mkvmerge, does it fix the issue ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th February 2012 at 00:11. |
6th February 2012, 03:53 | #8856 | Link |
Nev, my HTPC was not splitting M4V videos (as well as not setting the splitter with git builds) I had to set MPC's internal MP4/MOV splitter or install Haali's splitter to get it to work.
I've fixed both of those issues by using a neat program called CodecTweakTool. Even after uninstalling Haali I still had references to it and there were numerous Cyberlink references also which were cleaned out. I can play with nightlies now! I'm a happy chappy. |
6th February 2012, 04:49 | #8858 | Link | |
6th February 2012, 08:25 | #8859 | Link |
I never claimed it was fast, but its Intra-only, so multi-threading it would be quite easy (and it should scale nearly linear)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 6th February 2012 at 09:27. |
6th February 2012, 09:19 | #8860 | Link | |
Thanks |
