7th November 2010, 14:04 | #10061 | Link | |
7th November 2010, 14:09 | #10062 | Link | ||
7th November 2010, 14:44 | #10064 | Link | |
Hi jdobbs, sorry for being inexplicit, english is not my native language.
Besides, I appreciate your incredible work for years (maybe you remember, years ago I sent you some bucks in a letter from germany) and have made a donation. Please carry on with developing these marvelous things. |
7th November 2010, 14:52 | #10065 | Link | |
- Corrected an error in which audio/sub tracks may be incorrectly identified by track/language when reencoded using movie-only mode from a multi-part source with a large number of segments. Last edited by jdobbs; 7th November 2010 at 14:58. |
7th November 2010, 15:26 | #10067 | Link | ||
Well, I will deselect German(deu) in setup and then do another encode. Quote:
Ps: Just deselected German(deu) and the german tracks have become deselected in the stream list. Will now start the encoding. Pps: Of course I selected the the german tracks manually in the stream list. Last edited by m.rup; 7th November 2010 at 15:33. Reason: Additional information |
7th November 2010, 17:19 | #10071 | Link |
jdobbs, i had both conversions one from 36.01 & one from 35.01 so I thought I would try burn another disc using all files from 36.01 but make one change, I deleted the m2ts video file from the stream directroy and replaced it with the one made from 35.01 and low and behold the disc played so the problem isn't all the other files in the folders from 36.01 its the video file that won't play. I have proved it by using all files from 36.01 but only changing out and using the m2ts file from 35.01. Maybe this will help. Another thing is I converted it twice with 36.01 once with the x264 from 36.01 and another after replacing 36.01 x264 files with the ones from 35.01 and that did not play either so its something that 36.01 is doing to the m2ts video file and not the x264 files since I have tried the ones from 35.01 and it did not work. Version 35.01 works and 36.01 does something to the m2ts file and the player does not like it thought it does play on the computer.
Shuttle99 Last edited by Shuttle99; 7th November 2010 at 17:38. |
7th November 2010, 19:40 | #10072 | Link |
jdobbs, I just got done trying 36.01 with strict AVCHD on and it still does not work. So back to my other post 36.01 is putting something into m2ts video file it self that is preventing it from loading because like I said in the other post all the files generated from 36.01 and the m2ts video file from 35.01 play fine.
7th November 2010, 20:16 | #10073 | Link |
BD Rebuilder doesn't like languages other than english
The encoding is finished now and the disc shows the same behavior as afore when German(deu) was deselected, the german tracks have disappeared though I have selected them manually in the stream list (in this case only for main feature, I did it for all streams in previous tests, the result was the same). I have attached the .inf and the .log file, maybe there are some hints of what's going on.
7th November 2010, 23:03 | #10074 | Link | |
Are you doing any kind of pre or post processing? I'm sure something is going on that is causing you to have an issue... but we're not going to find it by you telling me what my program is doing when I know better. Can you run it again and compare the command lines used for encoding the main feature (it is in the BD-RB folder and is called LASTCMD.TXT)? Last edited by jdobbs; 7th November 2010 at 23:14. |
7th November 2010, 23:34 | #10075 | Link |
jdobbs, I always create a new directory for all new versions of BDRebuilder so I currently have both version still installed in seperate directories and they both run independent of each other. I ran each version 35.01 & 36.01 on the same video and saved them in different folders, I burned both & 35.01 plays and 36.01 wants to play but kicks back to the dvd player menu. So I burned the 36.01 files only changing the m2ts video file using the one created with 35.01 and it played fine. I will burn another with the 35.01 files changing only the m2ts video from the 36.01 conversion and let you know if it will play. I have both files you asked about and I can send them to you to look at. The only thing on the 36.01 file I last ran I selected strict AVCHD in the setup. Let me know if I can send them to you some how.
7th November 2010, 23:37 | #10076 | Link | |
7th November 2010, 23:46 | #10077 | Link |
ok not sure what to look for but here are the files
35.01 D:\Video\BD-RBV03501\tools\x264-64.exe" "D:\WORKING 5\WORKFILES\00020.track_4113.vc1" --preset medium --demuxer lavf --force-cfr --b-pyramid strict --weightp 0 --qpmin=0 --bitrate 3759 --level 4.0 --qpfile "D:\WORKING 5\WORKFILES\VID_00020.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 17500 --threads auto --thread-input --stats "D:\WORKING 5\WORKFILES\00020.track_4113.vc1.264.stats" --pass 2 --output "D:\WORKING 5\WORKFILES\00020.track_4113.vc1.264" 36.01 "D:\Video\BD-RBV03601\tools\x264-64.exe" "D:\NEW FOLDER\WORKFILES\00020.track_4113.vc1" --preset medium --demuxer lavf --b-pyramid strict --weightp 0 --qpmin=0 --bitrate 3759 --level 4.0 --qpfile "D:\NEW FOLDER\WORKFILES\VID_00020.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 17500 --threads auto --thread-input --stats "D:\NEW FOLDER\WORKFILES\00020.track_4113.vc1.264.stats" --pass 2 --output "D:\NEW FOLDER\WORKFILES\00020.track_4113.vc1.264" |
7th November 2010, 23:58 | #10078 | Link |
Ok I just burned a disc that 35.01 created but used the m2ts video that 36.01 created and it will not work but the disc I burned using the files from 36.01 and video from 35.01 works so the m2ts video file from 35.01 works when burned with all other files created from either version but the m2ts video file created with 36.01 will not work with either version files. I have test this on two different videos with the same results.
8th November 2010, 02:09 | #10079 | Link |
It appears the log shows that with version 35.01 force-crf is set, but not with 36.01. Yet bitrate shows 3759 for both.
@Shuttle99; Do you let BD-RB create a new .ini file when you unzip the newest release? If not, you may want to try that. It is pretty simple to set up the new release with the features that you like, and avoid a potential conflict with previous versions to new releases. Last edited by Capsbackup; 8th November 2010 at 02:24. |
8th November 2010, 03:28 | #10080 | Link | |
