Old 17th March 2012, 18:08   #9961  |  Link
nevcairiel
Then you're out of luck, i managed to reproduce a problem once, and now its fixed.
Old 17th March 2012, 18:15   #9962  |  Link
madshi
If the freeze is inside of LAV Filters, maybe it would help to provide a PDB file in a test build, so the madVR freeze report might include the LAV Filter internal stack traces? Just a thought...
Old 17th March 2012, 18:31   #9963  |  Link
nevcairiel
I suppose.
Here is a build with its pdb files
http://files.1f0.de/lavf/LAVFilters-...b88bb9+pdb.zip
Here is the link to the madVR Trace Tool
http://madshi.net/madTraceProcess.zip
Cause the freeze, run it, select the zplayer.exe process, and pastebin the output somewhere.
Only works if you use madVR as a renderer.
I still did fix one hang that i reproduced in ZP, didn't find any more. I've also been analyzing the code, and i don't see what condition could otherwise cause a deadlock now.
Old 17th March 2012, 20:39   #9964  |  Link
Gleb Egorych
madTraceProcess log of hung Zoom Player.
Gleb Egorych is offline   Reply With Quote
Old 17th March 2012, 20:40   #9965  |  Link
cengizhan
I also had several freezes with latest mpc-hc, lav and madvr while seeking forward. Will try with LAVFilters-0.49-9b88bb9.
cengizhan is offline   Reply With Quote
Old 17th March 2012, 20:48   #9966  |  Link
nevcairiel
I see not one thread in there that is doing anything in LAV.
Considering i cannot even figure out how to configure ZP to use LAV without turning off its "smart play", i suggest you start over with a factory-reset version of ZP and then try to replicate the issue, and once you can, tell me the config exactly.
Alternatively, maybe ZP can somehow export its config, so i can import it?
Edit:
I finally managed to convinced it to use LAV in Smart Play mode, but still no problem here.
Old 17th March 2012, 23:00   #9967  |  Link
madshi
I'm seeing two interesting things:
(1) One thread callstack looks like this:
thread $df0:
75f9ee32 +5d GDI32.dll              D3DKMTSignalSynchronizationObject
0923c642 +32 nvcuvid.dll            cuvidMapVideoFrame
0922a8a0 +20 nvcuvid.dll            cuvidParseVideoData
I think this is likely an LAV Video Decoder related thread, don't you agree? But somehow the callstack doesn't contain any LAV Video Decoder related callstack items. That makes me think that the PDB file somehow didn't work.
@Gleb Egorych, can you confirm that you had a "LAVVideo.pdb" file in the same directory as "LAVVideo.ax" when creating the freeze report? And you do have a "dbghelp.dll" file in the madVR directory, correct?
(2) ZP's main thread seems to be stuck here:
77638cd3 +16a33 ntdll.dll                               RtlEnterCriticalSection
005192a2 +0000e zplayer.exe  BaseClass        6911  +11 TBCCritSec.Lock
005204dc +000a4 zplayer.exe  DSFilter         1602  +30 TDCDSPFilter.Stop
00675681 +00025 zplayer.exe  mainunit         4125   +5 TMainForm.dsMediaControlStop
00679722 +00332 zplayer.exe  mainunit         5905  +86 TMainForm.StopMovie
006587fa +00076 zplayer.exe  mainunit          124  +16 TMainForm.StopButtonClick
Another ZP thread is here at the same time:
thread $40c: <priority:1>
00520cf8 +00014 zplayer.exe  DSFilter  2099  +2 TDCDSPFilter.CheckInputType
00518d5b +0001b zplayer.exe  BaseClass 6705  +2 TBCTransformInputPin.CheckMediaType
005189cd +001b9 zplayer.exe  BaseClass 5870 +46 TBCBaseInputPin.Receive
00519169 +00041 zplayer.exe  BaseClass 6840  +5 TBCTransformInputPin.Receive
0051db3b +000d3 zplayer.exe  DSFilter   391 +21 TDCDSPFilterInputPin.Receive
My interpretation of this is that the main thread is trying to react to a press on the ZP "stop" button, while the ZP DSP filter is busy receiving data. Both try to enter the same critical section at the same time while it might even already be in use by a 3rd thread. I think DSP is audio related, though?
Old 17th March 2012, 23:17   #9968  |  Link
nevcairiel
thread $df0:
Ah, i somehow missed that one. Thanks for looking
cuvidParseVideoData is a NVIDIA function i call, which in turn calls a callback function of LAV, in which i then call cuvidMapVideoFrame (which basically is the LockRect of CUVID)
This would indicate the decoder is still working just fine, and is not deadlocked somewhere (except if that function somehow hangs, but never seen that happen and wouldn't even know why/how). This is called directly from my decoder worker thread, and if that thread is working and processing a frame, then everything else is still running.
I agree with your interpretation.
Both the main thread and some other thread try to enter the same critical section, but that also means something else has to hold that one right now.
But DSP is audio indeed, so its rather unlikely to be related to my latest changes (not knowing ZP itself, not ruling anything out)
Old 17th March 2012, 23:26   #9969  |  Link
madshi
Yeah, but the thing that confuses me is that there's no trace whatsoever of LAVVideo.ax in the stack trace. Which would make sense only if either the LAV PDB files are missing or if the dbghlp.dll is missing in the madVR folder. If I do a test freeze report on my PC with LAV Video decoding, I see plenty of LAV Video callstack items (when using your test build with the PDB files). Though, I can't do a freeze report exactly when the graph is stopped. Maybe that's a special situation. Still, I would expect to at least see *some* LAV related stack items in the freeze report somewhere, if both PDB files and dbghlp.dll are there.
Yeah, it does seem to be audio related. But that could be just the final phase of the freeze. It's possible that something else made ZP end up in that situation. In any case I find it suspicious that the main thread is hanging in the "StopButtonClick" event handler. That's a clear indication that the problem occurs as a direct consequence of ZP trying to stop the playback. Did something change in LAV somewhere (splitter, video or audio) in regards to the graph being stopped?
Old 17th March 2012, 23:33   #9970  |  Link
nevcairiel
Audio and Splitter haven't changed at all since the release version, which he reported to work fine (short of a ffmpeg update)
The only change i did was to move the video decoding onto a worker thread, and i had some synchronization issues between the main processing thread (the one from the splitter) and that worker thread at first, but those seem to all be worked out.
Stopping in ZP doesn't even do anything special with the decoder, it just seeks to 0, so i get the usual seeking events (BeginFlush/EndFlush and NewSegment)
What i do find interesting though, why would the video decoder still have data to process while the player is stopping the graph (and frozen at that). Shouldn't the Graph stop the splitter first so that no new data is arriving? (He is using Haali, so i cannot say how it really works for it)
On the other hand, why would the Main Thread try to stop a single filter? But maybe some stack trace lines are missing there too from a DirectShow internal dll?
In any case, LAV does not seem to be directly involved in the freeze, and the main thread even looks like its supposed to do what it does.
Does anyone else still have some Freeze/Hang issues with the latest test version? Here is the link again for reference:
I included some debug symbols, so if it does hang and you happen to use madVR, you can get a better freeze report using its new tools.
Old 18th March 2012, 02:31   #9971  |  Link
suanm
i have not tested the last lav 0.49 verson yet,but the old lav 0.48 version works very perfectly with madvr 0.54 version (i dislike 0.55 version or newer ) on my pc(xp+sp3 or win7 x86).i didn't find any of frozen filter, screen or player during playback,pausing blayback or stopping playback
suanm is offline   Reply With Quote
Old 18th March 2012, 07:08   #9972  |  Link
CruNcher
CruNcher's Avatar
nev i still have that crash issue with Mainconcepts Decoder (on close,stop playback, drag and drop while playing) and Lavsplitter framework, not sure if it happens with Madvr too but if thats the way to trace whats going on ofcourse i gonna try it
PS: Actually wait i guess its fixed somehow, might be one of the recent lock fixes, yep seems really fixed tried multiple drag and drop operations no crash anymore , of course their are distortion issues with the Frame Accurate Seeking, so i have force it to seek on I frames only. Nope it's still crashing but it can hold up much more Drag and Drop operations now before it crashes @ some sample
It is about Time
Old 18th March 2012, 07:41   #9973  |  Link
Gleb Egorych
Yes.
Yes.
Here are my settings. Paste them in zplayer.local file and place it in zplayer.exe dir. I use Zoom Player 8.1.1 with this hotfix.
Hangs with some previous LAV versions were exposed by ZP internal DSP and stream switching filter. When you press "S" key Zoom Player stops the graph and sometimes it hangs on this action.
I reproduced the hang without LAV Video in the graph, only Haali splitter, ffdshow video decoder and LAV Audio. Log.
Old 18th March 2012, 07:49   #9974  |  Link
madshi
Ah, @Gleb, so this has nothing to do with nevcairiel's recent changes at all? The bug was there in some older LAV versions, too? Hmmmmm... And you're sure that it only occurs with LAV Audio and with no other audio decoder? According to the freeze report it more looks like a ZP bug to me. But if it is, it should probably occur with other audio decoders, as well.
Sorry for the stupid question, but just to be safe: You have the LAV PDB files in the path "C:\Program Files (x86)\codecs\LAV", correct? You didn't actually copy them to "C:\Program Files\codecs\LAV" instead of "C:\Program Files (x86)\codecs\LAV"?
Old 18th March 2012, 07:55   #9975  |  Link
CruNcher
CruNcher's Avatar
Perfect it crashes fast away with MadVR on Drag and Drop with Mainconcepts Decoder tried Lav Video no crash, i try to trace it
Here the report http://www.mediafire.com/?cmc46mv5otdvj59
the crash isn't as fast with EVR basic but it comes after some time only with Lav Splitter though
PS: Im 100% sure the Internal MPC-HC .ts splitter never triggers this MPC-HC crash Internal .ts/Lav Audio with Mainconcepts Decoder it's only Lav Splitter/Lav Audio
It is about Time
Old 18th March 2012, 08:04   #9976  |  Link
nevcairiel
That doesn't make any sense whatsoever. Specifically the part where you say 0.49 release works.
LAV Audio was not changed one single bit. The first versions you reported the problem on (0.49-19) didn't even have an ffmpeg update, i only did that later on.
Are you absolutely sure that 0.49 release works?
Maybe you should ask Blight to look into it, he can properly see where all the ZP threads are stuck, and then contact me directly if he sees something.
I remember being in contact with him about this problem before, but he confirmed it was fixed, and i never changed anything to change that.
Old 18th March 2012, 08:05   #9977  |  Link
Gleb Egorych
It was present for some time, the it was fixed (in 0.27, not sure). Then there were made some changes and it reappeared in in some 0.3x beta version and was fastly fixed by nevcairiel. No bug in 0.49 release, it only presents in recent betas.
Yes, I paste with replace the entire archive in the same directory, "C:\Program Files (x86)\codecs\LAV".
Old 18th March 2012, 08:11   #9978  |  Link
Gleb Egorych
I used 0.49 for a week and haven't faced the problem. At the same time ZP with 0.49-xx hung the same day I installed the update. I'll 0.49 release further.
I'll report the bug to Blight too.
Old 18th March 2012, 11:43   #9979  |  Link
Gleb Egorych
nevcairiel,
after some testing I can say that 0.49 and 0.48 are affected by the hang too. Need some time to find the last working version.
Old 18th March 2012, 11:54   #9980  |  Link
nevcairiel
nevcairiel,
Can you confirm that it works with for example ffdshow first?
Nothing major changed really in LAV for quite a while.
I still think that DSP filter is having the issue here.
The hang you got with 0.49-19 during normal playback was probably video related, which i fixed. Now that you do intensive testing, it may be related to something completely different.
