23rd August 2011, 12:42 | #9441 | Link | |
Could the GPU memory size be a problem? Or what else? Its also suspicious to me that the GPU usage graph (in process explorer) never goes above ~15% if the GPU would lack the power wouldn't it be much higher? Why is there (can be) tearing in windowed mode, compared to exclusive? Also does exclusive means what it implies, that other programs can't use the GPU at all? |
23rd August 2011, 13:43 | #9442 | Link | |
You say 400000 means 25p or 50i. Is madVR able to make the difference between progressive and interlaced content? I just tried activating the ffdshow setting "Set interlaced flag in output media type". Reclock sees the difference, but madVR doesn't. |
23rd August 2011, 15:08 | #9443 | Link | |||||
4:2:0 hater
That default will cause bad levels on anything that is not madVR. Don't like that but as long as there is an option it's ok for me. |
23rd August 2011, 15:17 | #9444 | Link | |
It'll be replaced sooner or later anyway.
23rd August 2011, 16:59 | #9445 | Link |
force 25p to 24p not working
Hi, first post on doom9 for long-time user of HTPC!
I would like to use PAL speed-down from 25p to 24p, but cannot get it to work using madVR. My setup: ATI HD5750, HDMI output, MPC-HC (latest beta), madVR .73, ffdshow audio (latest beta), reclock (latest). ffdshow audio: decodes DD and DTS, outputting PCM madVR: "force to 24p" enabled "1080p24" and "1080p23" are available options in auto frequency reclock: "PAL slowdown force to 24p" enabled Using internal MPC splitter. Also tried LAV splitter. Playback does not used 24p, only 50p. While playing, reclock properties shows framerate is 23.976. madVR show it to be 50. These are PAL MKVs ripped from DVD using Handbrake. Any pointers, please? Have I misunderstood the feature? |
23rd August 2011, 18:06 | #9446 | Link | |
In my case I had a gtx295 that would in most cases constantly incremented the presentation glitches. I never totally solved the problem and in the end I had the card RMA'd due to driver crashes in benchmarks (madVR usage was fine). Since getting the new card (same model and pcb revision) I do not have a problem with presentation glitches. Please take this with a pinch of salt however, I am not in anyway saying presentation glitches are a warning of GFX card fault but if you are also having system instability playing 3D games and benchmarks it may be worth looking into. |
23rd August 2011, 20:54 | #9447 | Link | ||
50Hz DVD at 24p: My filter list in MPC-HC is: LAV Audio DecoderIn the playback > output section of the preferences, I have madVR selected for video and ReClock for Audio. Quote:
Last time I checked, I was still getting a black screen 90% of the time when using the built-in refresh rate switcher. (haven't checked it in the last couple of versions, but there hasn't been any mention of changes made to it) Last edited by 6233638; 23rd August 2011 at 20:57. |
23rd August 2011, 22:33 | #9448 | Link | |
24th August 2011, 02:23 | #9449 | Link |
For all those that have high CPU consumption when paused, on my Windows 7 I noticed that I have that same problem too (10-20) with the default settings. But when I uncheck the "Present Several Frames In Advance" setting, the problem goes away. Just thought I'd throw that out there
24th August 2011, 02:36 | #9450 | Link |
@STaRGaZeR. You do realize that Madshi is doing an outstanding work here, for free. This is the best renderer available, so stop whining and appreciate. Use something else if you don't like it. You sound like a unique child who has got too much attention.
@madshi. Thanks. Great job. I am very much impressed. I had some issue reading very high bitrate files in MPC-HC. I had several frame drops. I tried different filters and could not make it work. I have an OCed AMD X6 and dual 6870s. Sample Included......: YES Source...............: Remux Container............: MKV Length...............: 3h 55min Size.................: 23.7 GiB Total Bitrate........: 14.4 Mbps Codec................: DTSMA Bitrate..............: 3871 kbps/1510kbps Channels.............: 6.1 Language.............: English Subtitles............: English , Polish , Czech Codec ID.............: V_MPEG4/ISO/AVC Type.................: 1080p Resolution...........: 1920x800 Aspect Ratio.........: 2.40:1 Bitrate..............: 12.6 Mbps Framerate............: 23.976 fps Potplayer with madvr could render the file without frame drops. I thought I would report even though it seems to exclude madvr as a potential cause. Moreover, for all files, I get lots of frame drops when I go back to windowed mode. Moving the windows fixes the issue. Any clue how to fix this in the settings. Maybe different flushing strategy? Cheers and thanks! PS: I am still using .73 Last edited by GrandMax; 24th August 2011 at 02:42. |
24th August 2011, 04:27 | #9451 | Link | |
As for the OSD, I might not have been clear about the small grey OSD that pops up on top left corner of the screen while jumping a minute or 5 mins, I don't want it to be disabled completely, I want to use Potplayer's own OSD time-stamp while jumping or seeking.. Is there a way to do this? why does it only show up in full screen and not windowed?! - Also, I just noticed yesterday while trying to capture a frame I would get a blurred/corrupt image. This didn't happen when using EVR, so I'm guessing I need to configure something in madVR? Thanks for your time, and keep it up. |
24th August 2011, 05:17 | #9452 | Link |
Hi all
Sorry to have such a newby question, but 473 pages is too much to go through and the question too generic to search for running install.bat (as admin) pops up the usual dialog, and tells me the files haven't been copied anywhere but then madVR shows up in MPC-HC greyed out am using Win7 x64 (no SP) GTS250 card with 275.33 drivers MPC-HC 1.5.3.3677 (this might be the problem, I suspect) Thanks for any help, and I'll keep looking. I actually just discovered the LAV CUVID and ppls there reckon madVR is the best renderer to be using |
24th August 2011, 07:45 | #9455 | Link |
Just login as admin, then LEFT click on intall.bat. without right-click then run as admin. Just one left click will do, and it's normal for it to say that it did't copy any files because it doesn't need to, it says that so you won't move or delete that folder, always keep it in the same path/directory. Try again
24th August 2011, 08:25 | #9457 | Link | |||||||||||||
In exclusive mode other programs may eventually still be able to use the GPU, but they can't show anything visible. Quote:
madVR does not show an OSD when seeking, unless the media player asks for that. You may have to talk to the Potplayer developer about this. Can you reproduce that? If so, please upload a screenshot with madVR vs. EVR. |
24th August 2011, 08:42 | #9458 | Link | |
Oh and as for the OSD, last time , I want it to display it as EVR or Haali or even VMR9, (the same font, color, size..) madVR is the only one to show it's own OSD and I wanna know, if possible, how to revert to the original blue Potplayer OSD. I know I can let Potplayer not show it, but I need it, just not the black one lol Thanks. |
24th August 2011, 08:49 | #9459 | Link | |
Weird. Do you actually see the corrupted image on screen in PotPlayer? Or does the corruption only occur if you try to capture? How do you capture? Using PotPlayer's internal capture functionality? Or pressing Ctrl+Print? Or some other way?
24th August 2011, 08:51 | #9460 | Link |
I'm running 64bit MPC-HC.
Also tried just running the batch file, with the same result. Is madVR 32bit only? I guess I should have looked first before making a silly mistake like that. The Arcsoft drives were also 32bit, but gave a slightly different message. |
