11th October 2018, 14:08 | #53121 | Link |
Madshi knows about this and tries to do something about it.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
11th October 2018, 14:26 | #53122 | Link | |
directcompute should be supported I cant play 4k resolution downscaled anyway, but even when I make a 1080p x265 HDR encode from my source which plays smoothly I get the same result.
11th October 2018, 16:58 | #53123 | Link | |
There are more specs to look at here: 1.) resolution -> UHD - 3840x2160 2.) color depth -> 12 bit per color 3.) Pixelformat -> RGB (no subsampling) or YCbCr 4:4:4 / 4:2:2 / 4:2:0 4.) matching refresh rate for framerate of video -> missing here It is supported by HDMI 2.0, but only for low refresh rates. The bandwidth of HDMI 2.0 is known and so you can calculate it by yourself, it isn't that hard |
11th October 2018, 17:13 | #53124 | Link |
Hi Guys, I recently upgraded my projector from an x5900 to an x9900 and so far I'm loving it. I have always preferred madVR tone mapping via pixel shades and find that 200 target nits with highlight recovery at (are you mad?) and balanced for the other setting gives me the best results.. However.. I find that the actual picture is lacking in colour it's pale and looks desaturated even with the Option at 35%.
Yesterday I went into the madVR settings and upped the saturation from 0 to 22 and I am absolutely loving what is on my screen. I have full pop as HDR should be and I have never seen HDR this great on a projector with accurate colour, shadow details, highlights blacks etc etc... Thank you to @madshi and all the fantastic members on here who always help and support this amazing piece of software. What I wanted to ask was by having my saturation at 22 is that ok? Will it cause an issue like picture noise etc? I haven't seen any I'll effects but am I the only one who finds that at 0 saturation the HDR looks a little lifeless? Would really appreciate some comments and feedback to help me understand better.. By the way I select 0-255, 10 bit or above, BT2020, powercurve 2.4 within MadVR and RGB 4.4.4 on my HTPC at 10bit for 24hz movies.. Here are some pics with the +22 within madVR.. Thanks for all your help... Sent from my moto g(6) using Tapatalk |
11th October 2018, 17:16 | #53125 | Link | |
11th October 2018, 17:35 | #53126 | Link | |
11th October 2018, 17:45 | #53127 | Link | |
AMD Ry 1500x - 8GB - RX460 4GB TV Philips 55pus6501+ Marantz 1608 avr WIN10(1903) 4K/444RGB Mediaportal - Mpc-hc MADVR-D3D11/10bit |
11th October 2018, 18:10 | #53128 | Link |
Sorry, but it is very humble. There is not only 50i/60i.
Every "flatscreen" (-> LCD/OLED/...) is native progressive. Only old CRTs were able to display interlaced content natively. AND the deinterlacers of TVs are not as good as software deinterlacers, just try them in comparison and we continue here. I tested also 20k TVs (20k is not the resolution ) |
11th October 2018, 18:57 | #53129 | Link |
Is it only me but has anyone else using 92.17 and that last xysubfilter build 3.1.0.752 found that madVRs ability to move subtitles into the black bars stopped? The option is moving subtitles down to the bottom of the movie but not into the black bars when they are there. I'm using LAV 0.73 in case thats important also.
11th October 2018, 19:39 | #53132 | Link | ||
i well know the HDMI spec. Quote:
and what software deinterlancer are you using in realtime which your HTPC? |
11th October 2018, 20:07 | #53133 | Link |
aren't they interlaced ? so what's the point of this discussion ? better 60i to deinterlaced 60/2 fps UHD rgb 10bit 4:4:4 or deinterlaced 60/2*2 fps UHD rgb 8bit 4:4:4 or 60i deinterlaced 60/2*2 fps UHD YCbCr 4:2:2 ? who knows? could be personal decision ? until hdmi stardad is like that, ppl have to deal with.
always imho
11th October 2018, 20:19 | #53135 | Link |
HDMI 2.1 will be nice but people care about 10/12 bit way too much, at least on most displays and using madVR it offers a very minimal quality improvement. If you want 60 Hz use 8 bit RGB, it is great quality and you probably couldn't tell whether or not it was using 10 or 12 bit in a blind test.
madVR options explained |
11th October 2018, 20:20 | #53136 | Link | |
ok so know makes sense. I thought they still are interlaced the UHD broadcasting. so no other choice for hdmi than YCbCr.
11th October 2018, 21:25 | #53140 | Link | |
I never deinterlace a source when creating a file, only while playing a deinterlacer should be placed. It doesn‘t matter which one of LAV you use, you will never get a better deinterlacer in a tv. If you use a madvr, you also prefer the updcaling of it and don‘t let your tv handle it, right? |
