17th March 2017, 13:10 | #43101 | Link | ||||||||||||||||||
Opinions, anyone else? Quote:
Generally, I wonder how much more sharpening you need when using NGU Sharp, thought? See also: Quote:
See the madVR trade quality option "scale chroma separately, if it saves performance". You'll get slightly higher quality if you upscale chroma to 4:4:4 first, then downscale both luma+chroma at the same time. But if you want to save performance, you can use that trade quality option. Then madVR won't upscale chroma in your specific situation. Quote:
If you already find the source image/video too soft, no upscaling algo will fix that for you. You'll need to use dedicated sharpening algos in that situation. Quote:
Image upscaling/doubling. |
17th March 2017, 17:57 | #43102 | Link |
Does anyone else have issues with 10-bit HEVC playback on AMD video cards?
I have a RX480 and when playing back 10-bit HEVC through MPC-BE (with MadVR) I am getting a black image. I've tried loads of different settings, but could never get an image (only sound). The weird part is that 8-bit HEVC plays back fine with MadVR. Only 10-bit is affected. My 10-bit HEVC files can be played back by MPC-BE with DXVA directly, without MadVR in between, so I don't think this is a driver issue. |
17th March 2017, 18:44 | #43103 | Link | |||
For me, the current NGU Sharp (high) lacks sharpness when doing FHD > UHD upscaling, compared to the old one and the current NGU Sharp (very high). Quote:
Nnedi16 < NGU-low < Nnedi32 < NGU-med < Nnedi64 < Nnedi128 < NGU-high < Nnedi256 < NGU-veryhigh Quality wise, NGU-high and Nnedi256 are very close, but the differences in performance are huge ! So NGU AA wins for this particular case. However, I have found NNEDI3 to be better than NGU AA in a lot of situations, for instance to reduce the chroma bleeding. Quote:
However, I don't have any dropped frames with NGU Sharp (high) for luma doubling and NGU Sharp (med) for chroma doubling (tested in v0.91.1 of course), and all the other settings are already maxed out for my GPU. So it would be awesome if you could allow that Last edited by Neo-XP; 18th March 2017 at 16:53. |
17th March 2017, 19:06 | #43104 | Link | |
17th March 2017, 19:41 | #43107 | Link |
Kid for Today
OK thanks a lot, and that's with SR2? Anyway, I've never been a big fan of sharp chroma as if I find it to somewhat interfere with luma too much so I don't think sharpness is the best benchmark to compare chroma upscalers to my eyes........anyway I run a 4:2:2 TV and test patterns are just that but fair enough I'll roll them all all over again on real-world content for OCD sake's ^^
17th March 2017, 20:08 | #43109 | Link | |
Thanks to NGU AA I think NNEDI3 has been superseded for chroma mostly due to its performance requirements. Last edited by ryrynz; 18th March 2017 at 06:42. |
18th March 2017, 00:15 | #43112 | Link | |
18th March 2017, 04:32 | #43113 | Link | |
QB the Slayer
QB
18th March 2017, 06:57 | #43114 | Link | ||||
Typo, I meant top. Every time I tried to enter something the scroll bar reset making me need to scroll back down again.
Where I thought sharpness was beneficial in stills while watching I realized it wasn't actually what I preferred. Quote:
Anyway, TBH NGU AA High is very nice for chroma IMO with medium and even low being good options too. Honestly given the performance and results of these I'd rather time was spent elsewhere.. perhaps a built in replacement for ffdshow raw? Being able to add in Avisynth+/Vapoursynth filters into madVR directly would allow for huge video customization and allow also for proper handling of 10 bit content (ATM I have to disable it for any of this video type to avoid 8 bit output) and hopefully be faster and more stable as a result. Last edited by ryrynz; 18th March 2017 at 08:38. |
18th March 2017, 09:22 | #43115 | Link |
madshi, subtitle bug to report. Win7, mVR 91.4, xySubFilter 3.1.0.746. I have mVR set to move the subs to the bottom of screen/window. Never had a problem until last night. Starting the movie was fine and the standard font subs displayed fine under the screen/window as they should per mVR settings. But then italics subs appeared being used to show dialogue from a character off screen and those italicized subs displayed in the window instead of below it. From that point on all subs were then displayed in the window whether italics or standard font, so mVR was now totally ignoring instructions to display the subs below the screen. Stopping media player then starting it again fixed the problem until the next time italics subs appeared then all were displayed back in the window again. Seems mVR does not like italics subs or switching from standard font to italics causes it to wig out?
The file is 7GB so uploading a sample with matching SRT subs would seem to be impossible... and not sure if this bug reported yet. Thanks much |
18th March 2017, 15:12 | #43117 | Link |
And this bug appears only when SRT subs are in an external file, but not when they are muxed into an MKV file. So one can avoid it by just remuxing a video with subs into a single container, though remuxing huge videos just for that purpose can be PITA, of course.
18th March 2017, 19:29 | #43118 | Link |
It's normal when I play an HDR video with Windows10 and KODI or MPC-HC, the madvr show me this info: matrix BT.2020 primaries BT.2020 HDR 4000 nits, BT.2020 -> DCI-P3 Why DCI-P3 and not BT.2020? This is for all HDR videos thanks a lot |
18th March 2017, 20:08 | #43119 | Link |
Because only expensive Devices can actually display the Full Bt 2020 space that are no option yet for consumers and inside Research Labs.
DCI-P3 is the most economical solution currently for the masses without tonemapping the entire result to something different, even payable expensive devices only emulate Bt 2020 to some degree. It will take some years and solds before Bt 2020 becomes reachable to normal consumers, some very long years when we predict it takes the same time as 10 bit finally reached end consumers or full bt 709 and also actually become payable to run them for a long time
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 18th March 2017 at 20:52. |
18th March 2017, 23:20 | #43120 | Link |
What might be causing dropped frames even when the render time is like 10ms for 24fps content? I understand dropped frames when the render time in seconds is greater than the reciprocal of the fps, but that's not the case here.
