Old 24th July 2013, 21:26   #1641  |  Link
Music Fan
Originally Posted by Selur View Post
You have to replace the ffmpeg.exe in the Hybrid folder,...
Of course, that's what I did.
read the post to zeranoes forum
Done, but I remember I had problems with mp4box (on 30 march according to modification's date of MP4Box.exe in my folder with all uninstalled programs).
Music Fan is offline   Reply With Quote
Old 24th July 2013, 21:33   #1642  |  Link
Selur
Selur's Avatar
Your Windows XP is up-to-date, regarding updates isn't it?
Just checked, latest version from zeranoe works fine in my WinXP VM.
(ffmpeg-20130723-git-55db06a-win32-static)
Seems like it's something with your system.
Probably a missing Visual Studio Runtime.
Old 24th July 2013, 22:22   #1643  |  Link
Brazil2
Yep, this version works fine on a real (not VM) XP here.
Brazil2 is offline   Reply With Quote
Old 25th July 2013, 13:53   #1644  |  Link
Music Fan
I install updates only if I need it.
I had noted for a previous Hybrid version that I needed Visual C++ 2008 SP1, so I installed this version (because I use another pc for a few months and I hadn't re-installed all programs I had installed on the previous pc) but Hybrid still crash.
Then I installed several things (including Visual C++ 2010) but it still crash.
I guess something has changed in Hybrid or ffmpeg because rev2013.04.09.1 worked until yesterday but I threw it (because I believed last version would work).
So I can't use Hybrid anymore, unless you find the cause of this problem.
Old 25th July 2013, 13:55   #1645  |  Link
Selur
Selur's Avatar
Problem is I can't reproduce the problem here at all.
What happens if you call ffmpeg in a console?
Old 25th July 2013, 14:00   #1646  |  Link
Music Fan
How to do that ? I tried Run, cmd, C:\Program Files\Hybrid\ffmpeg.exe, enter, but it does not work (command not recognized).
Old 25th July 2013, 14:01   #1647  |  Link
Music Fan
works with "
Old 25th July 2013, 14:02   #1648  |  Link
Selur
Selur's Avatar
and? does ffmpeg output anything?
Old 25th July 2013, 14:06   #1649  |  Link
Music Fan
I just see ffmpeg's help in the cmd window.
Old 25th July 2013, 14:08   #1650  |  Link
Selur
Selur's Avatar
but no "strncpy_s is not in msvcrt.dl" error occurs, but it does occur if you call Hybrid?
Old 25th July 2013, 14:19   #1651  |  Link
Music Fan
I don't have this message when I call ffmpeg and not anymore when opening Hybrid, I see directly this message : "Hybrid Encoder GUI met a problem and has to close" (I translate from french).
And as I said yesterday, I wonder if the problem could not come from mp4box, because in my Hybrid folder (not in C: but in the partition where I put all downloaded programs), I have a sub folder including mp4box.exe and some dll : js32.dll, libgpac.dll, mfc90.dll, msvcr90.dll.
I put these files in this folder on 30 march 2013, I guess I needed them to solve a problem.
Old 25th July 2013, 14:25   #1652  |  Link
Music Fan
Look at our discussion of the 30 march ;
http://forum.doom9.org/showthread.php?t=153035&page=73
I'm reading it, hoping to find a solution.
Old 25th July 2013, 14:29   #1653  |  Link
Selur
Selur's Avatar
Okay, that problem is not related to ffmpeg then.
If mp4box is the culprit should be easy to investigate: call it from the terminal
Back then installing " Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)" solved the problem for you.
I didn't change anything dlls that come with Hybrid since I don't know which dlls solved the problem for you.
Old 25th July 2013, 14:40   #1654  |  Link
Music Fan
I tried, and as with ffmpg, I see the help of the program, no bug.
That was a few months ago, on my other pc, but now it didn't help.
I also installed Visual C++ 2012 and SP3, does not help.
Old 25th July 2013, 14:51   #1655  |  Link
Selur
Selur's Avatar
send you a pm with a Hybrid version which should open a terminal window which should show what Hybrid is doing,...
Old 25th July 2013, 19:38   #1656  |  Link
Music Fan
About x264 settings ; I chose 4 reference frames but the file I encoded has only 3 reference frames according to MediaInfo.
With an older Hybrid version (and thus older x264), I had well 4 reference frames according to MediaInfo.
Old 25th July 2013, 19:41   #1657  |  Link
Selur
Selur's Avatar
Ne debugOutput -> no clue
Need to see the decoding call to know if Hybrid made a mistake.
Tried here, and for me '--ref' get's properly set.
Old 25th July 2013, 19:52   #1658  |  Link
Music Fan
I don't find the debugOutput option.
Do I have to encode again or I can get a debugOutput file just opening a video file ?
Old 25th July 2013, 19:58   #1659  |  Link
Selur
Selur's Avatar
"Config->Internals->Create debug file, level ..."
What you can do is analyse the output file with MediaInfo , it should contain the encoding settings, if the encoding settings show ref=4 and MediaInfo report the number of references as 3 something is off with MediaInfo.
Otherwise <ou would need to do it again, since DebugOutput need to be created properly to make any sense, otherwise I can't even hope to replace the problem.
Old 25th July 2013, 20:16   #1660  |  Link
Music Fan
You're right, there are well 4 ref in encoding settings.
But with the same MediaInfo's version, my previous encoding has well 4 ref (according to MediaInfo's main window).
With another mkv, the encoding settings are not shown.
