23rd July 2016, 18:56 | #2202 | Link |
Damn, I only now noticed that typo. Must have been there for quite a while.
Groucho's Avisynth Stuff |
23rd July 2016, 22:38 | #2203 | Link | |
I'll upload the pics from Task manager later and also perform it again with some settings that push the CPU harder. The differences are significant when I increase the load by substituting spline36 with nnedi3, here's the script. ffdshow_source() input4x = last.nnedi3_rpow2(rfactor=2, nsize=4, nns=1).nnedi3_rpow2(rfactor=2, nsize=4, nns=1,cshift="Spline36Resize") edgemask = last.aSobel.aBlur aWarp4(input4x,edgemask,depth=2) Prefetch(4) With SetFilterMTMode("DEFAULT_MT_MODE", 2) at top of script Without What's going on? Am using latest build 2082 with nnedi3 0.9.4.24 and pinterf's Awarpsharp. Last edited by ryrynz; 24th July 2016 at 11:36. |
24th July 2016, 11:24 | #2204 | Link | |
AVS+ Dev
I also do not yet see how this could be possible. Anyone else seeing this on their computer?
AviSynth+ |
24th July 2016, 17:17 | #2207 | Link | ||
24th July 2016, 22:06 | #2209 | Link | |
47.952fps@71.928Hz
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
25th July 2016, 12:02 | #2210 | Link |
Hi all!
Please advice way overwrite existing Avisynth.dll under Windows 10. I am try using Freecommander run like admin, I do not see Avisynth.dll Windows/system32, but windows search show me at Windows/system32. On my PC also run Avira antivirus. yup. |
25th July 2016, 12:06 | #2211 | Link |
If you use a 32 bit application as file manager, you have only access to the 32 bit system directory which is camouflaged as "Windows\system32" to a 32 bit application, but instead is "Windows\SysWOW64" in the file system under a 64 bit Windows OS. You need to use a 64 bit application as file manager to have access to both locations if you have a 64 bit Windows OS.
Being old enough to have used the Norton Commander during the DOS era, I still enjoy the Far manager. It is abailable as both 32 bit and 64 bit application. Once again for a clarification: a) You have a 32-bit version of Windows (usual up to Windows 7, later deprecated):
b) You have a 64-bit version of Windows (most probable from Windows 8 on, although already available earlier):
25th July 2016, 17:50 | #2213 | Link | |
Problem was related with jpsdr build nnedi3, after update all O'k. yup. |
25th July 2016, 18:19 | #2214 | Link | |
You can use my Redist installer, it has all the last runtimes for 2005 through to 2015, x86 and x64 versions (including the new 24212): Visual C++ Redist Installer V44 - https://1drv.ms/u/s!AmGuHbW3zvrBmJFCnPBSK-pMSdxshA |
26th July 2016, 10:09 | #2216 | Link |
After update to last version avs+ i am changed my script from
SetMemoryMax(1536) SetFilterMTMode("DEFAULT_MT_MODE",3) Edibob=AVISource("pre14last.avi")## source YUY2 50 fps bobbed SetFilterMTMode("DEFAULT_MT_MODE",2) Edibob=Edibob.AssumeTFF() Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, Edithreads=1, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5) nnedi3_rpow2(rfactor=2,nns=2, qual=1, fwidth=1004, fheight=752,cshift="Spline36Resize").Crop(22,16,-22,-16) unsharp(varY=465,varC=232,strength=0.3,U=3,V=3) ConvertToYV12(interlaced=false) ColorMatrix(mode="Rec.601->Rec.709") PreFetch(8) Code:
Edibob=AVISource("pre14last.avi")## source YUY2 50 fps bobbed Edibob=Edibob.AssumeTFF() Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, Edithreads=1, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5) nnedi3_rpow2(rfactor=2,nns=2, qual=1, fwidth=1004, fheight=752,cshift="Spline36Resize").Crop(22,16,-22,-16) unsharp(varY=465,varC=232,strength=0.3,U=3,V=3) ConvertToYV12(interlaced=false) ColorMatrix(mode="Rec.601->Rec.709") PreFetch(8) I am using 32 bit version because not all plugin available for 64. yup. |
26th July 2016, 11:39 | #2218 | Link |
14.0.24212-x86
http://download.microsoft.com/downlo...redist.x86.exe 14.0.24212-x64 http://download.microsoft.com/downlo...redist.x64.exe
See My Avisynth Stuff |
29th July 2016, 10:59 | #2219 | Link |
I made a new installer with the latest r2085 binaries.
Also, ricktendo updated his AIO runtime installer to include the 14.0.24212 runtimes. With ricktendo's installer you can also selectively install runtimes. I made a batch file for that: Code:
@echo off :VS2005 start/wait VBCRedist_AIO_x86_x64 /ai5 :VS2008 start/wait VBCRedist_AIO_x86_x64 /ai8 :VS2010 start/wait VBCRedist_AIO_x86_x64 /aiX :VS2012 start/wait VBCRedist_AIO_x86_x64 /ai2 :VS2013 start/wait VBCRedist_AIO_x86_x64 /ai3 :VS2015 start/wait VBCRedist_AIO_x86_x64 /aiV
Groucho's Avisynth Stuff Last edited by Groucho2004; 29th July 2016 at 11:07. |
