Old 29th November 2003, 01:21   #61  |  Link
arman68
@xkodi
Thanks for the pack. I notice that since Microsoft fixed the vertical flip bug from v7, when used in conjonction with VSFilter/DVobSub, the picture is upside down. I gave the info to Gabest, and I think he will be fixing it in the next VSFilter version.
One problem I have though, is since the merit is raised to bypass the DivX 5 filter, the DivXG400 is excluded from the graph. Would it be possible to patch DivXG400 the same way you did DivXAF. Actually a better way to do it would be to ask PRR - the author of DivXAF and DivXG400 - to modify both filters. He's a very nice chap.
arman68 is offline   Reply With Quote
Old 29th November 2003, 17:34   #62  |  Link
mf
mf's Avatar
I actually made an installer for this thing when I heard about it, but I lost the executable due to a virus (well, the executable isn't lost but after virus+patching the checksum doesn't match and thus the installer won't load). I'll see if I have a backup somewhere, since people still seem to be interested in this MAIA thing. (I can't make new installers right now because of a strange OS incompatibility)
Edit: hmm, the "OS incompatibility" vanished with the wind . Find the installer at http://mf.creations.nl/DivX311b.exe.
It's compressed to the max, and I find 290KB pretty reasonable .
mf is offline   Reply With Quote
Old 7th December 2003, 12:23   #63  |  Link
xkodi
@arman68
currently i use DivXG400 v2.83, it originally has merit 00900000, which is equal to DivX_c32.ax merit form MAIA pack and DivXG400.ax loads correctly after DivX_c32.ax, so there are no problems with DivXG400 (at least with v2.83).
xkodi is offline   Reply With Quote
Old 7th December 2003, 12:48   #64  |  Link
BiaTch 5.0
Angel
BiaTch 5.0's Avatar
Thanx for the pack xkodi I recently encoded "Angle Season Two" with it & am very happy with the results.
Windows 2000 Pro
AthlonXP 1700+, ASUS/VIA KT266A, Seagate 80GB, Radeon 7000 VE, Creative Audigy, plexwriter 24/10/24A, Pioneer16 DVD.
BiaTch 5.0 is offline   Reply With Quote
Old 7th December 2003, 22:47   #65  |  Link
arman68
Are you sure?
I am also using v2.83, and if I remember correctly the merit was set to 00600000. I had to change it manually to 00900001 (same as your modified codecs) to include it in the graph.
I also talked to PRR and he said he did not want to take part in the "merit race"
Old 8th December 2003, 11:21   #66  |  Link
xkodi
if you use hex editor and go to offset 2BA48 in DivXG400.ax(v 2.83) you will see: 00 00 90 00, which is merit 00900000, so I am sure. if you change that value to 01 00 90 00, you will get merit 00900001.(register filter after patch to get right merit)
Old 9th December 2003, 14:00   #67  |  Link
arman68
@xkodi: thanks for the patch info.
The latest version of VSFilter 2.32 fixes the vertical flip
Old 9th December 2003, 20:25   #68  |  Link
xkodi
arman68, thank you for informing Gabest about the problem. I am glad to hear that the vertical flip problem with VSFilter/DVobSub is gone. Also thank you Gabest for your fast response.
Old 1st July 2004, 22:40   #69  |  Link
LordofStars
Stupid question. I know that previously the combination of choice was sbc + 3.11a.
How does this new version work with sbc?
NM I RTFM and answered it for myself. It seems to work perfectly with nandub.
LordofStars is offline   Reply With Quote
