3rd June 2013, 08:50 | #2061 | Link |
Its very well possible that Handbrakes settings are not optimized for the new presets in Haswell yet, i wouldn't jump to conclusions too early.
3rd June 2013, 09:14 | #2062 | Link | |
But this refers to 4600, we know 5200 is double stronger than 4600. Last edited by wanezhiling; 3rd June 2013 at 09:23. |
3rd June 2013, 09:28 | #2063 | Link |
Yup, the 4600 will be adequate for lanczos as even the HD 3000 has no issues there, Jinc will probably be still a bit too demanding for some content though. But yeah the Iris Pro (HD 5200) is what I'm interested in too.
3rd June 2013, 09:57 | #2064 | Link |
http://en.wikipedia.org/wiki/Haswell...ile_processors
4750HQ 4850HQ 4950HQ |
3rd June 2013, 10:06 | #2065 | Link | |
The 4770R would be interesting, if they sell it soldered on a ITX board without a whole PC around it.
3rd June 2013, 11:31 | #2066 | Link | |
QuickSync Decoder author
You should check power and CPU utilization/speed at normal playback speeds. DXVA checker tries running at full speed which doesn't matter for playback. Even for transcoding, your conclusion is a little hasty. You need to sum up the power used for the entire clip in both cases and see which one is better. Looking the power draw alone is not enough as D3D9 will finish much sooner.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
3rd June 2013, 15:32 | #2067 | Link |
I read that with Haswell, the Display Controller also moved to the CPU. This could mean that we now have a common clock for audio (HDMI) and video!? It is quite an improvement that the video clock can now achieve an accurate 23.976Hz. This does not help a bit though if the audio resp. the DirectShow graph clock is off. Because the real problem has never been the inaccurate video clock but the deviation between audio/graph and video clock...
Bye Last edited by CiNcH; 3rd June 2013 at 16:17. |
3rd June 2013, 15:42 | #2068 | Link |
The digital display interfaces moved to the system agent (north bridge) within the processor instead of being transferred to via the DMI bus to the PCH. This is more efficient but as for the audio clock, I don't know.
3rd June 2013, 15:57 | #2069 | Link |
QS quality in Handbrake beta is not as good on an HD4000 as other implementations (Nero Recode, Arcsoft Media Converter, Media Coder). These implementations vary in quality, too, so I think there's probably a lot of tweaking that needs to happen to get the best results out of QS. Intel is reportedly working closely with the Handbrake team, so I'd expect improvements in future betas.
4th June 2013, 16:44 | #2070 | Link | |
According to anandtech they matched this target. Anand tested a 900/2500 GDDR5 650M. So they should match a 800 Mhz 650M with DDR3 memory. GT640 on the desktop side is difficult to say because its competitor will be a 65W BGA GT3e. |
4th June 2013, 16:47 | #2071 | Link | |
This is absolutely wrong. Handbrake QS quality is top notch for Ivy Bridge. I did lots of tests. As for Haswell there might be some issues with the new presets. Last edited by Yups; 4th June 2013 at 16:49. |
5th June 2013, 12:13 | #2074 | Link | ||
For me benchmarking with DXVA Checker exposes the potential of the hardware and has only one real use, transcoding, because it uses hardware at its limits - like benchmarking. The other real use is normal playback of course - more important to me. Well, during normal playback DXVA native and DXVA copy-back are by far the most power-efficient solutions. QS decoder power efficiency during playback is almost the same for various clips I tried under both situations - D3D11 and D3D9. So, it seems that the real advantage of D3D11 is the headless, no fake display use of QS decoder. Quote:
Iris Pro 5200 tested by Anand is inside a mobile CPU with lower TDP than desktop, but I think that the special version used in benchmarks of 55W is the top-performer GT3e that anyone could use regardless of Desktop-Mobile CPU package. Eric could tell us more about that...
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
5th June 2013, 14:32 | #2075 | Link |
I have a question to all ? Do people with a laptop with win8 and sandy or ivy bridge coupled with discrete GPU has tested it ?
Cause the last version of the intel drivers was supposed to permit to use intel quick sync technology even if the iGPU isn't used. But in my case when the dGPU is used the possibility to use quicksync through lav filters disappears |
5th June 2013, 15:39 | #2076 | Link | ||
The combined name for GT3+EDRAM is Iris Pro. Quote:
5th June 2013, 16:08 | #2077 | Link |
Thanks Eric.
http://ark.intel.com/compare/76087,76086,76085 I noticed that Max Memory Bandwidth of these three models is 76.8GB/s, and all other Haswell models(even 4770R) are 25.6GB/s. Is it true? |
5th June 2013, 16:22 | #2078 | Link | ||
Arcsoft is crap to be honest. High profile isn't possible and I can't even choose the preset. It must be the balanced or speed preset. Quality preset not possible. Quote:
GT650M 900/2500 GDDR5 GT 640 925/1700 DDR3 Despite having the slightly faster GPU GT640 loses by a good margin. Except BF3 Iris Pro isn't much slower than a GT640 925/1700. On this basis I would say Iris Pro should match a 800 Mhz 650M with DDR3. As for the 65W model Iris Pro is clearly TDP limited in a 47W power envelope, 55W Iris Pro runs 10% or so faster. 65W Iris Pro for desktop could be even faster slightly. Last edited by Yups; 6th June 2013 at 11:55. |
5th June 2013, 16:43 | #2079 | Link |
That's what i was doubting. Okay so i think that as you may have previously pointed out, Optimus disables entirely iGPU when dGPU is forced. So as for sure Nvidia won't do anything about it, i won't be able to use it in that way
5th June 2013, 16:51 | #2080 | Link | |
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
