17th May 2012, 02:13 | #821 | Link |
Selur, I think that I did something wrong in selecting the m2ts file from the playlist. I'll trying again now. Will report if something happens.
One more thing, can't select the largest file in the Stream folder and then get the file list mate? that would be easy, because, in the playlist, I see similar files and like alot. So, mistakenly I selected the wrong file to import. That could've been the reason for the above problem. |
17th May 2012, 07:33 | #822 | Link | ||
Blu-ray have extra Playlist files which contain informations regarding which files to playback in which order,... If you select a single file Hybrid will only open this one file. If you select the Blu-ray folder in Blu-ray mode Hybrid will show you a selection of all the playlists where you can choose which one you want. If you select a single playlist file, Hybrid will open the files linked in that playlist, in the order mentioned in the playlist. Quote:
17th May 2012, 13:46 | #824 | Link | |
20th May 2012, 10:20 | #834 | Link |
crf and 2pass aim for different things.
Use crf if you want a specific 'quality level' (crf 16-22 is normally fine for most people; most stick with 18). Use 2pass if you aim for a specific average bitrate or specific file size. -> you can't really compare these two since they aim for different things if crf&2pass use otherwise the same settings and the output size is the same, the quality will be the same,.. If size is not really a concern stick with crf 18. Cu Selur |
20th May 2012, 11:19 | #835 | Link |
Hybrid rev. 2012.05.20.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
20th May 2012, 16:42 | #840 | Link |
I don't know which priority you are speaking of. Assuming you mean the process priority decoders and encoders run in: Hybrid automatically sets everything to the lowest priority (idle / nice -n 19) and does not offer an option to change this. (Mainly because I see no good reason why one would want to,...)
