15th November 2011, 19:42 | #7021 | Link | |
Sure i could do that, but then someone that cares could also try to help out, which might actually make me fix the problem, otherwise i might just ignore it
15th November 2011, 20:26 | #7023 | Link | |
Life's clearer in 4K UHD
After further tests, I've found I can't even get "std-def" AC3 and DTS audio to connect to LAV audio...
15th November 2011, 21:11 | #7025 | Link | |
[HKEY_CLASSES_ROOT\Wow6432Node\Media Type\Extensions\.m2ts] "Source Filter"="{B98D13E7-55DB-4385-A33D-09FD1BA26338}" and [HKEY_CLASSES_ROOT\Wow6432Node\Media Type\Extensions\.mkv] "Source Filter"="{B98D13E7-55DB-4385-A33D-09FD1BA26338}" If there is another value at this keys, just reinstall the LAV-filters and make sure these types are checked during installation. IIRC, these values are only written to the registry when installing, not when you check/uncheck these in the Lav-splitter settings tab after installation. |
15th November 2011, 21:12 | #7026 | Link |
Well would you "Adam and Eve" it...
After de-installing "LAV", re-booting, re-installing "LAV" and re-booting... I'm now able to bit-stream HD audio to my amplifier again Computers eh?
15th November 2011, 21:16 | #7027 | Link | |
----------------------------- Some news from the DVD front: Accepting and just eating up the subtitles seems to do the job, DVDs play fine now. Did need some trickery though, but all in all, its playing the dvds just fine. It is lacking the interactive menu overlays of course, and subtitles won't show. Considering the subtitles are used to render the button overlays as well, i'm kinda partial to the idea of drawing them directly onto the frames, in case no renderer accepts the AYUV/ARGB pictures. Forwarding the still encoded subtitles wouldn't work in this case.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 15th November 2011 at 22:07. |
15th November 2011, 21:41 | #7028 | Link | |
Did you install some other multi-media package or other codes after the last time you installed Lav-filters using the installer ? Does Lav-splitter now get used when you open .m2ts / .mkv files ? note : uninstalling Lav-filters probably was not needed, just reinstall over the existing installation should have done the trick, as long as you use the installer. |
15th November 2011, 22:08 | #7029 | Link | |
No...
16th November 2011, 02:19 | #7030 | Link | |
The weird thing is why we do see speakers instead of blabla AVR in your case? Checkout my listed audio renderers. Do you see any "speakers" statement? Are you sure Onkyo AVR (or whatsoever you have?) is selected by default on your playback devices? Or just speakers? Not sure your AVR is connected to your PC properly or recognized properly by your PC. The last test you should do to be sure, pls try this and forget bitstreaming for a while: And last question: why don't you get rid of those Realtek drivers? _ _ Last edited by rica; 16th November 2011 at 03:22. |
16th November 2011, 03:40 | #7031 | Link | |
After i've explored this post i'm not able to make any comment since i understood nothing? You are able to use lavfilters to bitsream HD audio? But you can not bitstream SD audio? But what "even" means here??? I should understand normally "i can not bitsream HD even SD audio".... or what??? What is yor HW? Dunno? How you connected your unknown AVR to your PC? Dunno? What is your problem really? Dunno? Last edited by rica; 16th November 2011 at 03:55. |
16th November 2011, 07:27 | #7032 | Link |
You should learn to read, he said his problem was already fixed.
16th November 2011, 09:57 | #7033 | Link |
Yes my issue has been fixed.
Many, many thanks to everyone who kindly offered help and their suggestions. It's much appreciated. Thank-you again...
16th November 2011, 13:07 | #7034 | Link |
Hi Nevcairiel. LAV Video 0.39 have trouble with playback this sample in Software mode(with CUVID play fine)
http://www.multiupload.com/ZGDZFMT4Q0 play with ~43fps and micro jitter. 0.38 and 0.37 play fine.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
16th November 2011, 13:38 | #7035 | Link | |
I'll try to look into it, but reporting it to them is a good idea no matter what. Edit: I found the offending commit, its http://git.videolan.org/?p=ffmpeg.gi...e678f425c7e4cf if anyone cares.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 16th November 2011 at 14:09. |
16th November 2011, 13:59 | #7036 | Link |
4:2:0 hater
Another bug report here. This file (SFD, MPEG-1 + ADX) fails to decode smoothly if splitted with LAV Splitter. MPC's internal splitter plays it fine. Screenshots and file:
LAV Splitter ---------------- MPC's internal http://www.mediafire.com/?tur04krbed4fdc4 |
16th November 2011, 14:44 | #7037 | Link |
Fixed locally, thanks for reporting!
16th November 2011, 15:18 | #7039 | Link |
Latest are usually fine.
