8th April 2011, 17:28 | #1383 | Link | |
There still is a problem with PGS subtitles : they are displayed after some time = always missing the first 2-3 lines (any type of codec avc, vc-1, mpeg2 & decoder) and for the same files (m2ts or index.bdmv) MPC-HC's internal splitter doesn't have this problem (the missing first lines) it shows all the lines from the beginning
Intel UHD Graphics 750; Win 10 22H2 |
8th April 2011, 17:37 | #1384 | Link | |
8th April 2011, 17:58 | #1385 | Link |
Had some issues with MPC-HC's internal decoders and Microsoft's decoder either displaying frames in the wrong order or inserting black frames, but seeing as it also happens with Haali Media Splitter, you're off the hook.
8th April 2011, 18:02 | #1386 | Link |
Hello!
Audio Decoder sounds like chewed videotape in the beginning or when seeking with this file and audio goes out of sync. mediaInfo: [SPOILER] General Complete name : Conan the Barbarian\Conan the Barbarian.avi Format : AVI Format/Info : Audio Video Interleave File size : 724 MiB Duration : 2h 10mn Overall bit rate : 777 Kbps Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 1 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 2h 10mn Bit rate : 640 Kbps Width : 688 pixels Height : 320 pixels Display aspect ratio : 2.2:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.121 Stream size : 596 MiB (82%) Writing library : XviD 1.1.0 (UTC 2005-11-22) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Emphasis : 50/15ms Codec ID : 55 Codec ID/Hint : MP3 Duration : 2h 10mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Delay relative to video : 26ms Stream size : 119 MiB (16%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Title : Audio Stream Writing library : LAME3.97 [/SPOILER] Is it because of Conan the Barbarian? edit:Actually audio out of sync with every avi file I tried. Talking about 0.21 version Last edited by Damien147; 8th April 2011 at 18:52. |
8th April 2011, 19:40 | #1388 | Link |
It's been discussed very recently (in the last few pages, in fact). MPC-HC may change to facilitate being able to drop any filters you want into a directory within the MPC-HC dir, and then it'll automagically recognize them so that you can use what you want. Those will become the "internal" filters and won't even have to be registered in order to work, meaning it'll still remain quite portable.
8th April 2011, 20:03 | #1390 | Link |
I think you're missing the point. There won't BE any "built-in" splitters in MPC-HC. All the filters will be removed from the executable and moved to a separate folder if the current proposed design changes are implemented. This allows people to use whatever filters they want as "preferred internal". Rather than relying just on what's compiled into the executable. The internal filters page will be redesigned to show the filters that are added to the filters directory. So, in essence, yes, LAV Filters could "replace" the current splitters. It'll give you far more choice.
8th April 2011, 20:31 | #1391 | Link | |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
8th April 2011, 20:31 | #1392 | Link |
8th April 2011, 20:43 | #1393 | Link | |
Go into Options, Tweaks, and disable "Fast Seek (keyframe)", that allows full seeking again. I'll look into disabling the key-frame reporting for files where its not supported properly. MPC-HC should really fallback on normal seeking when the last keyframe syncpoint is too far away. Edit: Fixed, only active in MKV and AVI now, these formats i know that it works somewhat ok. Also fixed the stuttering in the OGM sample. Yay. I guess that just leaves embedded fonts from your list, eh.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th April 2011 at 21:44. |
8th April 2011, 21:25 | #1394 | Link |
nevermind that, next version will support embedded fonts in MKV.
Are embedded fonts used in any other kind of files? If so, anyone has samples?
8th April 2011, 22:06 | #1397 | Link | |
Since this is TrueHD in MPEG-TS, i would like to repeat the fact that TrueHD will NOT play *at all* when using the MPC-HC MPEG Splitter with LAV Audio - and this will not be fixed (well, at least not on my side, maybe some day someone fixes the MPC-HC Splitter) This is due to the fact that the MPC-HC Splitter really doesn't know about TrueHD, it misdetects it as AC3 and expects the audio decoder to figure out that its TrueHD - and in addition to that, also filter out the AC3 frames from inbetween - this is just total crap.
8th April 2011, 23:28 | #1399 | Link | |
MPC-HC 2.2.1 |
8th April 2011, 23:34 | #1400 | Link | |
