26th April 2012, 17:29 | #13061 | Link | |
I have the UK version and the Planet Earth BDs are regular 23.976p apart from this one. I got the Life boxset too which is on the other hand 50i (and seems to work fine in video mode from the little testing I just did). Edit : Okay, my problem has nothing to do with performance and/or LAV at all! It's some strange bug. See for yourself: -75hz: flawless in windowed and FSE, queues are full 100% of the time, video mode deinterlacing does it job (solid 60fps), mpc-hc and JRiver MC17 give the same results. However, 60fps on 75hz does not look good so it's not a viable solution. -60hz: fine in windowed but NOT in windowed fullscreen or FSE, queues go mad every now and then, both players behave the same, reclock/video smooth don't change anything at all. Looks like a madVR (unlikely) or nvidia (very likely) issue, IMO. Last edited by kalston; 26th April 2012 at 20:18. |
26th April 2012, 18:52 | #13062 | Link | |
If you did, do you have "adaptive vsync" enabled ? I can't recommend it, but it could maybe explain the different behavior from 60 Hz versus 75 Hz refresh rate. I think your VP2 card is really to slow/buggy to handle 60i content. Get a cheap/used GTx-4xx or GTX-5xx VP4 now or wait till cheaper than the GTX-680 VP5 cards are released. (stay away from the so called VP5 GTx-520 NV card, it's too slow because off the slow/cheap RAM used) Last edited by Pat357; 26th April 2012 at 18:59. |
26th April 2012, 19:31 | #13063 | Link |
Got 296.10, haven't even thought about trying 300.xx drivers - newer drivers tend to just make things worse with older GPUs. I would use much older drivers (260.99 possibly) if it wasn't for a couple of games I own that need recent ones.
Aero being off, don't think I should have to worry about vsync. |
26th April 2012, 21:49 | #13064 | Link |
media player freeze
I often get a freeze if i open a file after the pc has ben restarted. It only happens once. Then it works. I mostly use hibernate/slumber so the error dosnt occur untell i restart the pc again some days later.
log attached is says: callstack crc : $56b52c58, $079f2a0f, $24210d46 exception number : 1 exception message : The process seems to be frozen. |
30th April 2012, 08:42 | #13065 | Link |
Hi.
Look at this sample. madVR got big problems when scene goes to B/W. I've checked every option and can't play without problems. I had to change for EVR render to watch the whole movie. http://netload.in/dateiEwSjy9qPhv/Cz...25fps).mkv.htm |
1st May 2012, 19:06 | #13067 | Link | |
2nd May 2012, 19:11 | #13070 | Link |
With nvidia 301.24 drivers and gtx 590 madvr do not upscale the video. When i use Evr everything works normal.
HTPC: Windows 8 64bit Nvdia GTX 690 i7 3570k Corsair H100 Water Cooling Corsair 128 Gb Force SSD x 2 Raid 0+ Samsung 2 TBx 2 Hard Disc Raid 0 Creative Titanium HD |
2nd May 2012, 20:46 | #13071 | Link | |
I am using 301.24 with a GT 540M, and everything works OK except that you have to uncheck the madVR option to use a separate presentation device. Otherwise, you just get a blank screen... |
2nd May 2012, 21:14 | #13072 | Link | |
3rd May 2012, 17:50 | #13075 | Link |
Has anyone else been having trouble playing DVDs lately?
It's been fine for me until recently, but I'm now getting "Macrovision Fail" errors again and I can't think of any reason why. (madVR and LAV Filters haven't had updates for a while) Update: It's LAV Filters 0.50.2 that breaks DVD playback. 0.50.1 works fine. I guess I just hadn't played a DVD since I last updated. Last edited by 6233638; 3rd May 2012 at 18:57. |
3rd May 2012, 19:14 | #13077 | Link | |
EVR on the other hand has terrible color management and is unable to display correct colors on my wide gamut display. Last edited by Asmodian; 4th May 2012 at 02:08. Reason: typo |
4th May 2012, 00:50 | #13080 | Link | |
Edit: seems it was hidden in filters->madvr->edit settings. Very logical :S Edit2: I was mainly interested in madvr because of the adjustable resizing stuff, very handy when 99,999% of material is below my display's resolution - so decent quality upscaling is a must. Last edited by Ihmemies; 4th May 2012 at 01:06. |
