3rd May 2016, 14:25 | #101 | Link | |
unsigned int
http://ulozto.net/xTaV1SY2/imwri-r32-win64-7z Does it crash when you pass --info to vspipe or just when you make it output the clip?
Buy me a "coffee" and/or hire me to write code! |
4th May 2016, 08:47 | #102 | Link |
Users of ImageMagick (also indirectly by image conversion services, especially when available via web) shall close security holes immediately:
ImageTragick |
4th May 2016, 10:13 | #103 | Link | |
4th May 2016, 12:22 | #104 | Link | |
unsigned int
8th June 2016, 13:52 | #106 | Link | |
unsigned int
https://ulozto.net/xaWaZ5NM/imwri-wildcards-win32-7z https://ulozto.net/x9zryeNx/imwri-wildcards-win64-7z
16th June 2016, 15:31 | #109 | Link |
契約者
With this plugin, is it possible to read:
a) 16bit PNG sequence into RGB48 video? b) 4:2:0 JPEG sequence into YV12 video? (same for other variants of subsampling) If I am reading 16bit PNG sequence into RGBS video, will fmtc.bitdepth(clip, bits=16) produce RGB48 output identical to the case a) ? If not, is there a function that will? Last edited by Keiyakusha; 16th June 2016 at 15:35. |
16th June 2016, 15:39 | #110 | Link | |
Professional Code Monkey
b) No yuv output support because imagemagick hates stuff like that. You'll always get rgb. But FFMS2 should decode it properly to YUV. If you use round to nearest in the conversion, yes, since 32 bit float can accurately represent it. Not actually tested but that's what I expect.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 16th June 2016 at 15:43. Reason: Added solutions |
16th June 2016, 16:24 | #111 | Link | |
契約者
18th June 2016, 20:09 | #113 | Link |
It doesn't handle it so you'll have to use some python code to get around it.
6th January 2017, 19:21 | #116 | Link | ||
Can you post an example of using python to load and image sequence with ffms2 please, for a python newbie |
7th January 2017, 22:08 | #117 | Link | |
import vapoursynth as vs first_image = 4 num_images = 160 filename_pattern = 'D:/imgseq/output_{0:05d}.jpg' c = vs.get_core() placeholder_clip = c.std.BlankClip(clip=c.ffms2.Source(filename_pattern.format(first_image), cache=False), length=num_images) def image_loader(n): return c.ffms2.Source(filename_pattern.format(n + first_image), cache=False)[0] clip = c.std.FrameEval(placeholder_clip, image_loader) clip.set_output()
8th January 2017, 02:50 | #118 | Link | |
It works nicely, thanks Seek latency is a bit high, but I'm not complaining. Sometimes the vpy imagemagick plugin has problems with some formats and it's a nice alternative just in case |
15th February 2017, 13:04 | #120 | Link | ||
unsigned int
