Old 27th February 2015, 20:57   #1181  |  Link
kadajawi
Originally Posted by LoRd_MuldeR View Post
It's not currently possible. But I could allow for even higher Opus bitrate in future versions, if there actually is demand for it.
(BTW: Did you actually try 256 kbps for your source and result was not satisfying?)
For multichannel content that would be nice. Currently I get around 40 kbit per channel, and that is too little. The same source with Ogg Vorbis q4 is around 380 kbit in total, and that's the quality I want. I could hear some artifacts, and that was on cheap speakers. I think with 320 kbit it should be fine, but 256 is too low IMHO. And imagine what happens with 7.2 audio sources...
kadajawi is offline   Reply With Quote
Old 28th February 2015, 16:01   #1182  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
With regard to 5.1 channel encodes. Have you tried using HE-AAC between 192Kbps and 256Kbps?
Old 8th March 2015, 18:25   #1183  |  Link
GMJCZP
GMJCZP's Avatar
LoRd_MuldeR, for CD ripping you recommend CUE Tools, Does the program fre:ac is equivalent? Thanks.
GMJCZP is offline   Reply With Quote
Old 8th March 2015, 18:34   #1184  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Do I?
Actually I use Exact Audio Copy (EAC) when I need to rip one of my Audio-CD's.
Since I don't use fre:ac, so I cannot say much about it.
But since it's a fully-fledged audio converter, I guess you would use either LameXP or fre:ac. You probably wouldn't use fre:ac for ripping your Audio-CD just to convert with LameXP afterwards
Anyway, whether the "ripping" capabilities of fre:ac are on par with EAC, I have no idea...
Old 8th March 2015, 18:52   #1185  |  Link
GMJCZP
GMJCZP's Avatar
Do I?
Sorry for my confusion, it was EAC and not Cue Tools, lol.
Thanks for your reply LoRd_MuldeR.
I know this question is already out of the post, but someone will clarify whether fre:ac is usable as EAC or Cue Tools for CD ripping?
Old 8th March 2015, 20:21   #1186  |  Link
LoRd_MuldeR
Software Developer
I don't know whether fre:ac uses any "external" program (or a specific library) for Audio CD ripping or whether it does this all by itself.
You probably want to ask the fre:ac author
Old 10th March 2015, 17:52   #1187  |  Link
soneca
If you want to extract also CDs scratched, those who are not in good condition recommend using programs like EAC, dBpoweramp and CUERipper to use secure mode to check and try to correct the errors and also extra verification by AccurateRip.
fre:ac would be more appropriate only for conversion between formats.
soneca is offline   Reply With Quote
Old 19th March 2015, 18:08   #1188  |  Link
SeeMoreDigital
Oh no... My binary has expired... It's the end of the world
Old 20th March 2015, 00:10   #1189  |  Link
lethedoom
lethedoom's Avatar
Time Limited License
Mine Too. Back to still reliable 4.10 final until further development of 4.11 is made available.
lethedoom is offline   Reply With Quote
Old 20th March 2015, 10:34   #1190  |  Link
Przemek_Sperling
Amen, brother, amen.
Przemek_Sperling is offline   Reply With Quote
Old 20th March 2015, 11:23   #1191  |  Link
Andouille
Registered sausage
Andouille's Avatar
Mine has expired 5 years ago (v3.18)...
I just have to click "OK" two times more and it works...
Andouille is offline   Reply With Quote
Old 21st March 2015, 00:04   #1192  |  Link
LoRd_MuldeR
Software Developer
Sorry, usually I will upload a new test build before the previous test build has expired.
However, this week I have been on a business trip, so no access to my development machine, ultra-slow hotel Internet connection, and no time anyway.
New build will be available soon, but I'll need to catch a snatch of sleep now
Old 21st March 2015, 08:39   #1193  |  Link
Przemek_Sperling
So sleep well :-)
Old 21st March 2015, 20:07   #1194  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.11 RC-3
Changes between v4.10 and v4.11 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2013 with Update-4
* Starting with this version, LameXP is based on the MUtilities library + massive code clean-up
* Added support for the DynamicAudioNormalizer normalization filter
* Updated Qt runtime libraries to v4.8.7 snapshot-4 (2015-02-16), compiled with MSVC 12.0
* Updated MediaInfo to v0.7.72 (2015-01-07), compiled with ICL 15.0 and MSVC 12.0
* Updated SoX to v14.4.2-Final (2015-02-22), compiled with ICL 15.0 and MSVC 12.0
* Updated Opus libraries to v1.1.x and Opus-Tools v0.1.9 to latest Git Master (2014-10-04)
* Updated mpg123 decoder to v1.22.0 (2015-02-24), compiled with GCC 4.9.2
* Updated Vorbis encoder to OggEnc v2.87 (2014-06-24), using libvorbis v1.3.4 and aoTuV b6.03_2014
* Updated Vorbis decoder to OggDec v1.10.1 (2014-06-25), using libVorbis v1.3.4
* Updated FLAC encoder/decoder to v1.3.1 (2014-11-26), compiled with ICL 15.0 and MSVC 12.0
* Updated GnuPG to v1.4.18 (2014-06-30), compiled with GCC 4.9.1
* Updated QAAC add-in to the latest to QAAC v2.44, including a fix for the --artwork option
* Fixed potential crash in Cue Sheet importer (occurred when all input files were missing)
* Fixed a severe performance bottleneck, especially with a large number of parallel instances
* Fixed a very rare problem that, occasionally, prevented the TEMP folder from being removed
* The limit for the maximum number of parallel instances has been increased to 32
* Experimental support for Windows 10 Technical Preview
* Updated language files (big thank-you to all contributors !!!)
Old 21st March 2015, 20:13   #1195  |  Link
SeeMoreDigital
Woohoo! The world is re-born
Old 22nd March 2015, 16:57   #1196  |  Link
manolito
manolito's Avatar
Thanks very much for the RC3 version...
Did a couple of tests (still my old WinXP on a non-SSE2 CPU), and I found only one bug.
The latest LameXP.qaac-addin.2014-01-19.zip does not work with the current Apple Application Support version. The AAC encoder is simply not recognized. It is necessary to use a newer qaac.exe version in the LameXP folder, the version from this archive does work:
https://yadi.sk/d/IaHUQp7wen9uX
Otherwise no problems at all, special thanks for still supporting my CPU (of course still need to switch to 16 bit colors).
And even the patched SoX version with integrated DynamicAudioNormalizer does not require SSE2 (as opposed to the version which ships with DynamicAudioNormalizer), much appreciated...
I also like the revamped audio normalizing setup, the channel coupling option is much more intuitive than the former method.
Thanks again,
Cheers
manolito
Old 22nd March 2015, 17:11   #1197  |  Link
LoRd_MuldeR
Software Developer
Interesting
I had a quick look at QAAC changelog and could not find a change (since the 2014-12-25 build) that explicitly addresses Apple Application Support compatibility:
https://github.com/nu774/qaac/commits/master
Anyway, I can try to make a fresh QAAC build from Git Master and we can check if that helps.
BTW: What version of Apple Application Support are you using and how can I get it? What is the newest version that still works with "my" QAAC binary?
Old 22nd March 2015, 17:52   #1198  |  Link
manolito
manolito's Avatar
I used the current version 2.3.6 dated from 07.10.2014. I extracted it from the current QuickTime installer.
I normally do not use Apple Application Support because it is a little too snoopy for my taste. I use portable qaac versions instead like the one from my link. But for testing the latest LameXP version I cleaned up everything and installed the qaac addon and Apple Application Support exactly like explained in the manual. And I only got it to work after replacing qaac.exe with the newer version.
Cheers
manolito
Old 22nd March 2015, 18:19   #1199  |  Link
LoRd_MuldeR
Software Developer
I tried with Apple Application Support version 3.1.2 (containing CoreAudioToolbox version 7.9.9.6) and it worked fine for me with latest QAAC Add-in for LameXP (2014-12-25)
Anyway, I am going to make a build of the the latest QAAC version now, just to be sure we aren't missing anything...
Old 22nd March 2015, 20:26   #1200  |  Link
LoRd_MuldeR
Software Developer
Updated QAAC Add-in for LameXP, based on QAAC v2.47 (2014-02-15)
http://sourceforge.net/projects/lame...2.zip/download
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
