11th August 2009, 22:41 | #2222 | Link |
i receaved this error after a current clean install and using x264_dp_ Standalone-PS3-Xbox360_Fast.xml as the output.
[NoImage] Standard error stream: C:\Program Files\megui\tools\x264\x264.exe: unrecognised option `--no-mbtree' am i to assume the included presets have not been updated to the newer x264 cli options yet ?, if so, how do i fix it being new to this GUI. or is it, given `--no-mbtree' is one of the newer options, that the included x264 is running behind the preset updates,and is an older one in the auto update, so just manually replace it with a newer version, if so which one, or perhaps you will be providing the required auto update soon. ---------------------------- ohh,looking at the MeGUI change log it seems option two (the currently supplyed older Jeebs 1183 patched x264) is the problem. i wonder if there are also other external tools (mencoder and ffmpeg/libx264) that have been updated to the newest x264 options recently and so are also in need of new MeGUI updates inclusion? DS's latest http://mirror05.x264.nl/Dark/x264_mbtree13.exe testing 0.69.1195+2 5ed78fa isnt compiled for Mp4 output apparently (works for mkv, but that containers no good for direct 360 streaming use) so im not sure what the latest version is to use here or which D9 thread to find it posted... "0.3.1.1053 - (kurtnoise) [x264 Config] * add presets/tunings/mb-tree/rc-lookahead/no-psy options. Requires x264 revision 1206 or higher. * redesign config panel in 4 tabs (Main, the default one + Frame-type + Rate-Control + Analysis + Misc) * clean up the code for better reading. " Last edited by popper; 12th August 2009 at 01:22. |
12th August 2009, 07:15 | #2223 | Link | |
I'm having the same problem. I've tried several presets and they all end up with... Code:
--[NoImage] Standard error stream: C:\Program Files (x86)\megui\tools\x264\x264.exe: unrecognised option `--no-mbtree' I downloaded Jarod's 1206 x264 (x64) from here and replaced the copy in the megui folder. This did not work; there was an error in the MeGUI log stating that x264 could not open the AVS file. I replaced that copy with Jarod's 1206 x264 (x86) from the same link and so far this seems to be working in the sense that the encoding job is actually running now. |
26th August 2009, 06:32 | #2227 | Link | |
User of free A/V tools
26th August 2009, 19:00 | #2228 | Link |
well ive done what scottws has done, by replacing the x64 x264 with a x86 x264, and that hasnt solved my problem either, instead i get:
C:\Program Files (x86)\megui\tools\x264\x264.exe: unknown option -- nal-hrd--output |
26th August 2009, 19:04 | #2229 | Link |
For starters it should be
--nal-hrd --output Also you must make sure that the x264 version you are using is compiled with the nal-hrd patch. (when the command line is fixed) |
26th August 2009, 22:10 | #2230 | Link |
sorry for my technical mistake there on my previous post, however i am using the latest version onf MeGUI with all the latest updates, but as i said i replaced x264 with the x86 version of it. Not to forget to mention, that i am running all this on Windows 7 x64.
26th August 2009, 22:22 | #2231 | Link |
The question is if the version of x264 you downloaded was compiled with the nal-hrd patch. If you have an unpatched version, for instance the one from x264.nl or one of the unpatched builds the people on this forum provide, then --nal-hrd will of course not be recognized.
You can download an up do date patched build here http://forum.doom9.org/showthread.ph...50#post1318350 |
27th August 2009, 00:53 | #2233 | Link | |
okay, i am abit confused now, ive downloaded this one:
27th August 2009, 06:57 | #2234 | Link |
If the reason for this error was that two options got glued together, and are still connected without a space in between, then it doesn't matter which build you are trying, this double-option will never get recognised, a space in between is required to separate them.
