Old 24th December 2008, 16:27   #7521  |  Link
mrr19121970
OK, I mailled it to you, as my attachment needs approval.
mrr19121970 is offline
Old 24th December 2008, 16:47   #7522  |  Link
Thunderbolt8
upload it somewhere else, by the time it gets approved christmas is most likely already over
Thunderbolt8 is offline
Old 24th December 2008, 18:45   #7523  |  Link
wolfbane5
Originally Posted by madshi
Surcode is located by checking these registry values:
HKEY_LOCAL_MACHINE\Software\Minnetonka Audio Software\SurCode DVD-DTS\Home
HKEY_LOCAL_MACHINE\Software\Minnetonka Audio Software\SurCode DVD DTS\Home
Again, if you have properly installed Surcode, these registry values should be set.
I looked under Minnetonka Audio Software and found 2 folders: SurCode DVD DTS and SurCode Dolby Digital Premiere.
DVD DTS had the following: (Default) REG_SZ (value not set)
Dolby Digital had the following: (Default) REG_SZ
In that case, I'm assuming there should be a folder labeled SurCode DVD-DTS? and that SurCode DVD-DTS and SurCode DVD DTS are both missing a Home folder?
wolfbane5 is offline
Old 24th December 2008, 23:15   #7524  |  Link
zeropc
i just downloaded the free nero aac codec pack, because i need the decoder to decode aac for ac3 encoding. so what do i now to use the codecs with eac3to?
thanks for help
zeropc is offline
Old 25th December 2008, 00:21   #7525  |  Link
Chumbo
Chumbo's Avatar
thanks for help
I think you can just use piping to do what you need. Tebasuna has a post from a week or 2 back, I think, that shows how to use eac3to with an external encoder so search back to his posts.
[EDIT] Here's the post: tebasuna51 knows all
Chumbo
Last edited by Chumbo; 25th December 2008 at 00:24. Reason: Added pipe reference link
Chumbo is offline
Old 25th December 2008, 00:49   #7526  |  Link
asarian
Originally Posted by n0mag!c View Post
Please don't be hurry to change it while only one man states the issue!
I'm using PS3 and frequently removing dialog normalization with ea3to with no such issue.
I was just gonna say the same thing: I always remove dialog normalizatiion and never have an issue with it on my PS3; so let's not fix it if it ain't broken.
Gorgeous, delicious, deculture!
asarian is offline
Old 25th December 2008, 02:51   #7527  |  Link
alc0re
Read the post.
He said the fix he's going to implement won't affect the users that aren't having an issue. Stop saying not to fix it if there are users having issues with it. Just cause the issue doesn't effect you doesn't mean it isn't effecting others. Again, the fix he's planning will not effect you or the others that aren't currently having an issue with it, but it probably will help us that are having the issue, so why bother asking him not to fix it...
alc0re is offline
Old 25th December 2008, 03:44   #7528  |  Link
tebasuna51
tebasuna51's Avatar
Don't worry, with DialNorm = 31 all is ok.
I always use 31 instead 0 and work fine.
tebasuna51 is offline
Old 25th December 2008, 04:00   #7529  |  Link
rebkell
If I'm understanding this conversation, after the change, by setting dialnorm = 0, it would be the same as the default is now, won't it?
rebkell is offline
Old 25th December 2008, 12:51   #7530  |  Link
zeropc
unfortunately this doesn't help me cause i wanna decode aac and not encode.
zeropc is offline
Old 25th December 2008, 14:30   #7531  |  Link
Thunderbolt8
eac3to lists the 7.1 DTS-HD MA track of the nordic black hawk down edition with "(strange setup)" and "CAUTION: Decoding this track with ArcSoft results in low volume" , so heres a sample in case you are interested.
http://www.sendspace.com/file/n675tw
eac3to v2.84
command line: eac3to moviepath 1) 2: X:\hawk.mkv 4: X:\hawk.flac 4: X:\hawk.dtsma
M2TS, 1 video track, 2 audio tracks, 4 subtitle tracks, 2:23:43
1: Chapters, 12 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 640kbps, 48khz
4: DTS Master Audio, English, 7.1 (strange setup) channels, 16 bits, 48khz
   (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz)
5: Subtitle (PGS), Swedish
6: Subtitle (PGS), Danish
7: Subtitle (PGS), Norwegian
8: Subtitle (PGS), Finnish
CAUTION: Decoding this track with ArcSoft results in low volume.
[v02] Extracting video track number 2...
[a04] Extracting audio track number 4...
[v02] Muxing video to Matroska...
[a04] Decoding with ArcSoft DTS Decoder...
[a04] Encoding FLAC with libFlac...
[a04] Creating file "X:\hawk.dtsma"...
[a04] Creating file "X:\hawk.flac"...
[a04] The last DTS frame is incomplete and thus gets skipped.
[a04] The original audio track has a constant bit depth of 16 bits.
Added fps value to MKV header.
Video track 2 contains 206735 frames.
eac3to processing took 52 minutes, 6 seconds.
Done.
so I guess arcsoft does not process this track very well, is the channel order wrong? what would be if i used sonic instead, would these 5.1 channels then be the same 5.1 channels of a regular 5.1 track or would there be some mixing up? does 5.1 have the rear or side positions and are these 5.1 positions the same in 7.1 (when tracks are decoded with eac3to & played with madflac)?
Old 25th December 2008, 15:04   #7532  |  Link
nautilus7
nautilus7's Avatar
Don't you have Nero 7 installed?
Merry Christmas to all!!
nautilus7 is offline
Old 25th December 2008, 15:08   #7533  |  Link
rickardk
eac3to v2.84
Done.
Alos tried this one and got som kind of static noise in the by eac3to created FLAC. I guess the ArcSoft decoder does something wrong ...
rickardk is offline
Old 25th December 2008, 15:31   #7534  |  Link
Chumbo
Chumbo's Avatar
Ah, sorry, you're right. I miss-read your post. Ugh...
Chumbo
Chumbo is offline
Old 25th December 2008, 15:38   #7535  |  Link
Chumbo
Chumbo's Avatar
Originally Posted by nautilus7 View Post
...Merry Christmas to all!!
Merry Christmas to you as well!
  /o  \
 /   o \
/_ o   _\
Chumbo
Chumbo is offline
Old 25th December 2008, 15:56   #7536  |  Link
Thunderbolt8
same here :S
Old 25th December 2008, 21:27   #7537  |  Link
Thunderbolt8
got a problem with a H264 50i cap, when I try to slow it down to 23.976fps the audiotrack length increases to >5h (duration of video seems to be fine). might be a problem, because the track is rcognized by eac3to as 2.0, while its supposed to be 5.1. Already tried to fix it with delaycut, as Tebasuna once said with that flag that indicates a channel switch, but delaycut didn't report such a thing for this track here.
http://www.sendspace.com/file/iq4hgv
eac3to v2.84
command line: eac3to movie.ts G:\movie.mkv -slowdown
TS, 1 video track, 1 audio track, 1:50:05
1: h264/AVC, 1080i50 (16:9)
2: AC3, 2.0 channels, 384kbps, 48khz, dialnorm: -27dB, -732ms
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[a02] Decoding with DirectShow (Nero Audio Decoder 2)...
[v01] Muxing video to Matroska...
[a02] DirectShow reports 2.0 channels, 24 bits, 48khz
[a02] Applying RAW/PCM delay...
[a02] Changing FPS from 25.000 to 23.976...
[a02] Encoding AC3 <448kbps> with libAften...
[a02] Creating file "G:\movie - 2 - AC3, 2.0 channels, 384kbps, 48khz.ac3"...
[a02] The last (E-)AC3 frame is incomplete and thus gets skipped.
Video track 1 contains 330251 frames.
eac3to processing took 23 minutes, 52 seconds.
Done.
Old 25th December 2008, 22:32   #7538  |  Link
alc0re
Yes. But as he's stated, 31 is the same as using 0, so the new default will be the same except it will help us with decoders that don't process a value of 0 correctly.
alc0re is offline
Old 25th December 2008, 22:40   #7539  |  Link
rebkell
I understand that, I was just pointing out for the ones that are worried about the change, that if they set the value to 0, it will be identical to what they have now.
rebkell is offline
Old 26th December 2008, 01:18   #7540  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
Deleted.
Last edited by odin24; 26th December 2008 at 05:13. Reason: Commented in the wrong thread... I'm going nuts!
odin24 is offline
eac3to
