Old 15th July 2014, 00:31   #21  |  Link
sneaker_ger
That's a lower-case L, i.e. yuv420p10le and yuv420p16le.
le = little-endian
10 = 10 bit
16 = 16 bit (x264cli converts input to 16 bit before dithering in some cases)
Old 15th July 2014, 00:36   #22  |  Link
poisondeathray
yuv420p101e is 10bit 4:2:0, little endian. Basically your source file is incompatible, needs to be converted to 4:2:0 8bit
Also, if you're using x264 directly instead of avs input, I would add --force-cfr .
Same with ffmpeg libx264 using -x264opts force-cfr, and -pix_fmt yuv420p to convert to 8bit 4:2:0
EDIT: too slow
Old 15th July 2014, 02:12   #23  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Won't work. libx264 can only be either 8-bit or 10-bit, you can't switch between them at runtime. You need an ffmpeg built with 8-bit libx264.
Old 15th July 2014, 15:05   #24  |  Link
sneaker_ger
Note: --fps implies --force-cfr
Old 15th July 2014, 21:00   #25  |  Link
lyinawake
Wellll... I guess the cross-compile script I've been using takes that liberty of throwing on a 10-bit libx264. I'll try to find where it makes that choice, recompile, and retry with ffmpeg. And I am using -pix_fmt yuv420p as you can see in my initial ffmpeg commands.
Yes, you definitely need the --fps switch for x264. This isn't mentioned in the x264 bluray guide. Don't know if --cfr would work just as well but I think explicitly setting 60000/1001 is a good practice. Just forgot it again and Encore complained that the fps needs to be between 1 and 60 to be imported into the blu-ray project. Oy. What a minefield.
lyinawake is offline   Reply With Quote
Old 15th July 2014, 21:35   #26  |  Link
sneaker_ger
Basically x264 needs the exact fps ("60000/1001") and it needs to set the cfr flag. Like poisondeathray implied x264cli will set it to "cfr" for AviSynth input automatically (since AviSynth is only cfr natively) but "vfr" for other - possibly vfr - sources like mp4 files. So if you use avs or a pipe as input and the fps already gets correctly recognized neither "--fps" nor "--force-cfr" would be necessary. You never need to set "--force-cfr" when you already use "--fps" (but it does not do any harm either). I agree that the examples should probably all use "--fps" to reduce user error. It isn't explicitly mentioned in the doom9 thread either.
blu-ray, ffmpeg
