21st February 2014, 15:04 | #541 | Link | |
A 5 year old Intel i7 can test roughly 10 million AES keys per second with a simple AES implementation in C/C++. If you make use of its AES-NI instruction set, it will easily do - sit tight - 300 million per second. But this will only remove a couple of digits from your number, so subjectively nothing really changes |
21st February 2014, 20:38 | #542 | Link | |
But yeah, that really does not change anything, even if we get hardware capable of doing trillions of AES operations per second |
21st February 2014, 21:32 | #543 | Link | |
Well, and then there is another aes op required to verify, but that's all. 2^129 aes operations to verify all possible processing keys for any chosen one of the "slots" or whatever they are called. |
22nd February 2014, 14:22 | #544 | Link |
Well, OK, that depends on the approach (examining multiple subset-difference trees might be a better idea as you already have performed a key schedule for the given processing key you are testing). Anyway, you still get a processing key for a single MKB (or few, but not all, depends which tree you happen to crack).
23rd February 2014, 17:34 | #546 | Link |
Please read my reply with the calculations. OpenCL does not change anything at all, it is not a "magic technology that makes anything fast".
Anyway, even if you get a billion machines each verifying billions keys per second you would still not be able to get anything before the sun explodes, Earth is destroyed and universe ends. Even if you can get it a billion times faster with OpenCL it would still not be enough. |
5th July 2014, 16:23 | #549 | Link |
I just got a portable BD drive for my Macbook Pro. It is a Samsung SE-506CB. When I run aacskeys it says
The given Host Certficate / Private Key has been revoked by your drive. Code:
Problem with verifying the drive signature. Do I need a patch or could the problem be something else? Thanks in advance :-) |
7th July 2014, 22:32 | #550 | Link |
aacskeys 0.4.0c does not work with host certificates that have Bus Encryption Capable bit set, which is located in the second byte of the host cert. In short, aacskeys 0.4.0c does not support host certificates that start with 0201 (basically all recent ones).
However, the fix is trivial to make. In the aacskeys source code, locate file aacs_ecdsa.cpp. You will find 'aacs_set_cert' function there. Simply remove the first 'if' block (or modify it to allow second byte not to be zero) and recompile aacskeys, it should work. I believe there was also aacskeys 0.4.0e floating around, hacked by someone, that has this fix applied. |
9th July 2014, 21:45 | #551 | Link |
Thanks. I did the "fix" and recompiled - now it works. However, DumpHD will not use the recompiled libaacskeys.so and throws an exception:
Creating GUI... DONE Exception in thread "main" java.lang.UnsatisfiedLinkError: dumphd.aacs.AACSKeys.getVersionString()Ljava/lang/String; at dumphd.aacs.AACSKeys.getVersionString(Native Method) at dumphd.aacs.AACSDecrypter.<init>(AACSDecrypter.java:140) at dumphd.core.DumpHD.createDumpHD(DumpHD.java:153) at dumphd.core.DumpHD.<init>(DumpHD.java:125) at dumphd.gui.Manager.<init>(Manager.java:173) at dumphd.core.DumpHD.main(DumpHD.java:1032) By the way, is somebody working on getting more keys for aacskeys? It seems like all Blu-Rays up to MKBv31 will work, but no new keys have been found since MKBv31 and this is like more than a year ago? Or am I missing something? Is there other tools available than aackeys that will decrypt Blu-Ray discs on Linux and Mac OS X? I do not care about the keys or if it is not free - i just want to be able to play my BDs in VLC :-) Thanks in advance :-) |
9th July 2014, 23:24 | #552 | Link |
VLC supports on-the-fly decryption of AACS using libaacs, which is quite complete, maintained and works quite well. You don't need to use DumpHD, which is basically dead, if you just want to play a movie in VLC. Simply put libaacs library in your VLC directory and your keys in KEYDB.cfg file and it should work.
Obviously you must acquire all needed keys on your own. As for commercial solutions you can use MakeMKV, which allows you to dump movies or play them in VLC (latest versions can emulate libaacs, so you can play disc directly in VLC without dumping it). It supports latest versions of AACS and BD+ and you don't need any keys. |
7th March 2018, 21:07 | #555 | Link |
Someone sent me a new version of Aacskeys 0.4.0f with a fix for this bug so it accepts newer host certificates. The last public certificate just got revoked in MKBv63 though . The package contains source, Win/Linux executables and also DLL versions for use with DumpHD.
edit: included MacOS version is older and not version f Last edited by candela; 14th September 2018 at 17:34. |
31st May 2018, 14:44 | #556 | Link |
Tutorial
Hey guys,
I have tried to read through this thread but haven't really seen any kind of 1-10 or a-z tutorial of how to use this tool. I have Windows 10 Pro 64bit and am very comfortable using cmd as admin (I'm an IT Engineer), I could even throw together a Linux VM if needed. Could someone please point me to a "how to" for this. I know I'm missing something. I run the exe from a cmd window as admin. if i just run the exe it gives me a list of switches and examples of command structure but everything I try fails or hangs. For example, if I type in... C>:aacskeys e "E" is my drive. It just goes to a blinking cursor. I've let it sit there for 5 min and nothing ever comes up. I've tried some of the switches like... -v And still nothing happens. How long should it take? This is on 4K UHD discs. My drive is UHD "friendly" and recognizes the discs. I have even been able to rip some that I could find the hash keys for. I'd like to use this tool to get the keys directly of the discs that no one has posted yet. Thanks |
31st May 2018, 22:26 | #558 | Link |
Well, shoot. That's how I found this tool. On another forum some had said they had used this to get keys off of their 4K discs.
Bummer. Well, thanks for the quick response. Any idea if the dev is working on adding this feature? Thanks |
25th September 2018, 13:35 | #559 | Link |
Corresponding UV for Decrypted C-Value and Media Key
Hi all,
I've spent a few hours reading through this thread (more than once!) but I cannot find the answer for what I am seeking. AACS keys shows the 'Corresponding UV' that goes with the Decrypted C-Value to get the correct Media Key. What I would like to know is: Is this UV located somewhere in the MKB_RO.in file or, if it's not, can someone please explain how it is calculated. By reading the AACS documents, I've worked out how to decrypt the Media Key and Volume Id to get the VUK, but working out the UV has me stumped!! I'd really appreciate any words of wisdom! Thanks... |
3rd December 2018, 21:28 | #560 | Link |
4K Blueray MKB deducting and infirmations
With manuel: Introduction and Common Cryptographic Elements Book
Interprets Blueray version 61 AACS\MKBRO.inf and AACS\MKBRW.inf file records: 10 Manuel explain with Type and Version, MKBType 00041003 (yet 00031003 inside MKBRW.inf file) 21 Manuel explain with Host Revocation List 20 Manuel explain with Drive Revocation List 81 Manuel explain with Verify Media Key 7F Manuel exclude, yet text message inside forever MKB 1 2 3 .. 61 07 Manuel explain with Subset Difference Index 04 Manuel explain with Explicit Subset Difference 05 Manuel explain with Media Key Data 02 Manuel explain with End of Media Key Block Now on Blueray 4k discus with 256 ECDSA publick keys found: ContentRevocation.lst deducted before - identicle with manuel yet 256 ECDSA. Content000.cer deducted before - identicle with manuel yet 256 ECDSA. With trying many signings possible with cloud computing every files in 4K Blueray AACS directory. Only new signings now inside MKBRO.inf deducted with infirmations showed below. Interprets Blueray version 61 4K "2.0" AACS\MKBRO.inf file records: 10 Identicle with manuel, yet MKBType 48141003 21 Identicle with manuel same datums with same HD Blueray version 61 31 New and infirmations and hypoethsis following 07 Identicle with manuel yet more diffrent datums 20 Identicle with manuel same datums with same HD Blueray version 61 30 New and infirmations and hypoethsis following F8 New and infirmations and hypoethsis following 7F Identicle with Blureray text message MKB 1..61 86 New and infirmations and hypoethsis following 04 Identicle with manuel yet more diffrent datums 05 Identicle with manuel yet more diffrent datums 28 New and infirmations and hypoethsis following 02 Identicle with manuel 07 04 05 infirmations and hypoethsis: many more datums subset-diffrence structures with small "U" composition with every U-UV subsets excluding many keys of composition with every HD U-UV hypoethsis: 4K Blueray discus excluding HD Blueray from decryptions 31 infirmations and hypoethsis: 64 bytes datums 31 is 21 plus single bit added 10 Verifys as LA Publick Key 256 ECDSA signatureing records datums 10 21 Hypoethsis: AACS 2.0 Host Revocation List Verificaton Hypoethsis: bit 10 means 4K 30 infirmations and hypoethsis: 64 bytes datums 30 is 20 plus single bit added 10 Verifys as LA Publick Key 256 ECDSA signatureing records datums 10 20 Hypoethsis: AACS 2.0 Drive Revocation List Verificaton Hypoethsis: bit 10 means 4K F8 infirmations and hypoethsis: 0 bytes datums Hypoethsis: AACS 2.0 no deductings mysteryus please somebody help 86 infirmations and hypoethsis: no more MKB record 81, how now verify Media Key? 16 bytes datums, same identicle with AACS 81 record size Hypoethsis: AACS 2.0 Verify Media Key, yet some differing possible? 28 infirmations and hypoethsis: 64 bytes datums Verifys as LA Publick Key 256 ECDSA signatureing every before records 10 .. 05 datums Hypoethsis: AACS 2.0 Media Key Block Verificaton Please somebody put all 4K Blueray MKB versions if not 61 for downloadings and analyzings Please somebody put Patriot AACS.zip directory 2.1 for downloadings and analyzings Please somebody put Furry AACS.zip directory 2.1 for downloadings and analyzings There is more reasons for asking so many this questions. Somebody thank you. |
