Old 21st September 2014, 22:32   #1  |  Link
wotdaphuq
Pop-up menu and remote operations
I've got an out of mux pop-up menu added to a stream/playlist in Scenarist BD. I've noticed though that when the pop-up menu is open I'm not able to fast forward or rewind etc. and equally when I fast forward I can't access the pop-up menu. On other titles I've seen this possible, so you can access the pop-up while fast forwarding. Does anyone know how I might be able to fix this?
Thanks in advance!
wotdaphuq is offline   Reply With Quote
Old 22nd September 2014, 08:39   #2  |  Link
bigotti5
Spielberger
bigotti5's Avatar
Each menu page has its own UO-mask.
Enable UO20 and UO19 at page level.
bigotti5 is offline   Reply With Quote
Old 22nd September 2014, 10:09   #3  |  Link
wotdaphuq
Thanks Bigotti5. Will give that a go!
popup, scenarist bd, user operations
