27th February 2012, 20:17 | #10821 | Link |
I started playing around with the distributed encoding and have some questions.
1. Distributed encoding window size is too tall for vertical screen size of 600 (800x600 on my remote desktop app for my tablet, and 1024x600 for my netbook) would be handy to have it all fit on the screen at that lower resolution. The blue bar with the statistics is cut off... 2. Why is there a 4 machine limit to distributed encoding? I have many more at my disposal... maybe the window could be redesigned with a grid style control with an add client button or similar function to enable more encoding servers... |
27th February 2012, 21:30 | #10822 | Link |
Audio gets stretched while trying to convert 60 fps to 30 fps
I'm trying to convert my camcorder files for uploading to Vimeo and am having trouble maintaining audio. The video is 60 fps progressive and Vimeo only accepts up to 30 fps. I had no problems converting my 1080 interlaced video, but when I tried to convert to 30 fps, the audio was stretched and the time showed double the original length. Using search terms 59.94 fps to 29.97 fps didn't come up with any threads, but I'm positive I've seen a discussion on this problem. Can someone point me in the right direction? Also, it would be a BIG help if Ripbot could read the playlists. Currently I have to create one big file before I can have Ripbot encode it. Using an avs file caused Ripbot to run out of memory on the second pass and I'm not sure what to set for max memory.
27th February 2012, 21:57 | #10823 | Link |
in script after .converttoyv12 add .selectevery(2).asumefps(29.97)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th February 2012 at 22:24. |
28th February 2012, 00:37 | #10824 | Link |
Ripbot, even the latest version, still doesn't like the Classic Star Trek episodes Bluray. Season 1 set worked ok but seasons 2 & 3 get demuxing error when it reaches 100%. I have to use Handbrake for these blu-ray.
28th February 2012, 00:56 | #10825 | Link |
Ok, I'm having huge issues. Easy H264 works fine for me. But when i try to use ripbot, this appears: "DirectShowSource: RenderFile, the filter graph manager won't talk to me
(C:\temp\RipBot264temp\job1\ge*tinfo.avs, line 2)" I've tried this fix: http://www.youtube.com/watch?v=k-552T0KLDc And it works sometimes, but the sound doesn't come with the file. I've re-installed ripbot/avisynth and ffdshow and all that. I'm importing/expoerting from different partitions and harddrive's but no improvement! Can anyone help me with this problem? Best regards, kalleiskogen. (P.S, on a side note, when i try to export with .mkv, it start the process, when the above fix works, but no file appears afterwards. Fix for this?) |
28th February 2012, 10:53 | #10826 | Link |
French Love
Hi kalleiskogen,
Remuxe your video in mkv with mkvmergegui (mmg.exe) and open your video with your Ripbot264 v1.16.5
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
28th February 2012, 23:44 | #10828 | Link | |
Fringe was a tricky one, I made my own scripts in the end for those (IIRC, season 3 was ok but it was 1 and 2 which had issues). You'd think they'd all be the same. The ONLY bluray which has so far defeated me is J Edgar |
28th February 2012, 23:52 | #10829 | Link | |
RipBot would go through the normal process of demuxing, read in the number of frames and build an uncompressed video file from the deltas. Then you would have to build a totally new movie using the original 2D video from the demux and the newly created one from the deltas. The result would be both movies sitting side by side each other. Once all that is finished you would encode in the normal way. Personally I encode with a res of 1920x1080 and 8GB file size. Looks really good to me and I'm happy with it. Took me longer to get the script working on forced subtitles than anything else. To be honest, a few times I very nearly gave up. Got there in the end though. When you consider a 2 pass encode of a 2D movie takes 1hr 45mins approx, 8 hours for a 3D is a big difference. Worth it though Last edited by glen8; 28th February 2012 at 23:54. |
29th February 2012, 13:38 | #10831 | Link | |
29th February 2012, 20:03 | #10832 | Link |
I've been using RipBot264 v1.16.5 for some time and just updated to v1.17.0, in the hope it might have better AAC encoding since its always resulted in muted and dull audio making it a poor choice for lower bitrate 5.1 audio since the lowest AC3 5.1 is 384k, though unfortunately it sounds equally dull comparing the two versions results.
That aside I did notice a difference in the encoder settings dialogue box, unless I'm missing something almost all of the settings available there have been removed and if one wants to do any tweaking now they're given a large text document to edit. While probably no one tweaked every one of those settings to their preference, the way it is now is anything but simple, which is something that's been touted from the start. Fewer features doesn't mean simpler, infact as in this case fewer features can mean ridiculously and unnecessarily complicated. Even trying to change something as simple as R-frames etc is now as complicated as it could possible be. It is anything but simple now. While avoiding RipBot for low bitrate 5.1 audio is one thing and rarely needed, if the encoder settings are are the way things are going then all I can say it's been nice and appreciated, though I'll personally be going back alternatives and looking for something new that does actually keep it simple and user friendly to change settings. |
29th February 2012, 23:04 | #10834 | Link |
i'm shocked that simple --ref x added to text field is to complicated for you! another thing .you are trying to compress ac3 384kbps which is very low for ac3 (quality is already destroyed) ac3 needs 640kps to be transparent. fhg aac will give you the best quality from uncompressed source or from lossless compression (DTS-MA/TRUE-HD/FLAC)
converting strongly compressed jpeg image to another newer format like jpeg-xr also won't improve quality
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 29th February 2012 at 23:11. |
1st March 2012, 00:36 | #10835 | Link | |
Hi!
Thx for your answer! Would it be possible to share your "my own program which sits alongside ripbot" so one can try ? As I allways encode in 10000kb/s set to a 2pass, I´m used to having to wait between 6-20h´s depending on the movie i "rip", but the result is amazing!!! So u mean that in the end it will end up playable on a ex. Samsung 3DTV so it works like the original, but encoded? Regards MaistroX Would Quote:
1st March 2012, 09:09 | #10836 | Link |
Slitheen and others with problems with star trek.
WHen ever ripbot gives me an error with any file simply use MakeMKV which will give you the DVD/BD as a like for like in a MKV container. Usually takes a minute MAX. Then load the MKV file into ripbot to compress with your usual settings. And to Atak_Snajpera - Any options in further release for more then one audio streams in MKV. 2 would be very very NICE!! |
1st March 2012, 18:22 | #10838 | Link | |
1st March 2012, 21:56 | #10840 | Link |
Guys,
I have looked at the differences between season 1 and 2/3 of Star Trek. The reason you can't get ripbot to demux is due to the subtitles. You will have to manually demux leaving out the subs. Certain movies are the same (might be because the subs contain images....who cares anyway, leave them out and it will be ok) |
