14th December 2014, 22:39 | #21961 | Link | |
Recommend mount iso on virtual drive and try to play and see if something turns up.
If you fail to plan; you plan to fail, would you not agree? Think about it. |
15th December 2014, 00:15 | #21962 | Link | |
15th December 2014, 00:15 | #21963 | Link |
Funny that the only way I know there is a problem is with the verification. Because the disc reads and plays fine in several hardware and software blu ray players. I have even copied the entire BDMV and certificate folders from one drive to the other without any halt or read errors. It would not be so bad if Imageburn reported a bad sector or miscompare, which it doesn't, it's the crash and freeze which makes me wonder.
15th December 2014, 00:16 | #21964 | Link | |
15th December 2014, 01:02 | #21967 | Link |
Probably, at any rate the disc is playable and BDreb is consistently doing a great job. I appreciate you and others weighing in on this.
I find that many great movies which were available on DVD in the USA haven't produced blu-ray editions so I'm left buying Asian or European versions. And often enough without English subtitles. So if I really want to watch it, I have to put some work in. |
15th December 2014, 01:29 | #21968 | Link | |
You can also use the subtitles from the DVD by importing it -- and using what has been converted to BD by BD-RB. Last edited by jdobbs; 15th December 2014 at 01:35. |
15th December 2014, 16:53 | #21970 | Link | |
I'm guessing the real issue might be in the fact that DGDecNV uses multiple processes, while X264/LAVF doesn't. Could you run DGDecNV with MULTIPROCESS=0 to test it? I'll dig around and see if I can find a source to reproduce it. Last edited by jdobbs; 15th December 2014 at 16:55. |
15th December 2014, 21:53 | #21972 | Link | |
I was having the same problem with Imgburn when I moved to win 8.1. Updating the sata driver made the problem more intermittent rather completely go away. In the end i gave up and switched to nero burning rom. |
15th December 2014, 22:09 | #21974 | Link |
I've verified very few discs with Imgburn. The BD burning drive has proved itself, so I haven't seen the need yet. The few discs I have verified, passed with flying colors. That's the only time I use my iHES108. It's proven to be a bad BD-ROM reader. But quality of clean discs, seems to be reliable. Tiniest imperfection on an industrial disc, and there will be pixelation, skipping, etc. Or it won't run properly through BD rebuilder. I really don't like optical technology. But... it's a necessary evil sometimes LOL!
Only one rooster, need be in the hen house... |
16th December 2014, 03:07 | #21975 | Link |
I was wondering, since I have the LAV installed, can I just uninstall the haali splitter? Do I need that for anything else? I think on the first post here don't you say EITHER install one or the other? Should I uninstall the other one that goes with the Haali too?
16th December 2014, 18:41 | #21979 | Link |
@Jdobbs:
As requested i've re-run the same job with multiprocess=0 Conversion of the main title VID_00262 was with DGDecNV was succesful. I did notice the following though 1) for the main title, it still launched 2 processes of DGIndexNV (although i dont really know if this is bdrb's "fault" or native to DGIndexNV) but for the other smaller titles (extras, intro's, trailers) only 1 DGIndexNV process was launched 2) the x264 version that was launched for all titles was x264.exe and not x264-64.exe (although i don't really know if it's possible to launch 64bit version outside of LAVF) i figured i'd report none-the-less So it looks like the culprit is not the fact that DGDecNV is used as frameserver, but the multiprocess=n is the culprit. Now how this is possible i don't know or how to fix it. The quickest solution i can think of is to disable multiprocess on DTS-Express enabled discs if it is enabled, unless ofcourse it is a genuine bug and you can find a better fix. Attached is conversion log and "changed" ini file Code:
[12/16/14] BD Rebuilder v0.50.01 [15:24:42] Source: UNDERWORLD_RISE_OF_THE_LYCANS - Input BD size: 39,49 GB - Approximate total content: [02:56:17.757] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Output folder: C:\Blu-Ray Rebuilds\BDRB\ - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:24:43] PHASE ONE, Encoding - [15:24:43] Processing: VID_00260 (1 of 13) - [15:24:43] Extracting A/V streams [VID_00260] - [15:24:50] Reencoding video [VID_00260] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - Bitrate: 8.244 Kbs - [15:24:50] Reencoding: VID_00260, Pass 1 of 1 - [15:25:09] Video Encode complete - [15:25:09] Processing audio tracks - [15:25:09] Multiplexing M2TS - [15:25:13] Processing: VID_00262 (2 of 13) - [15:25:13] Extracting A/V streams [VID_00262] - [15:43:51] Reencoding video [VID_00262] - [15:43:51] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 133.033 frames - Bitrate: 13.757 Kbs - [16:02:37] Reencoding: VID_00262, Pass 1 of 1 - [17:21:20] Video Encode complete - [17:21:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4356 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [17:21:20] Multiplexing M2TS - [17:29:11] Processing: VID_00263 (3 of 13) - [17:29:11] Extracting A/V streams [VID_00263] - [17:29:31] Reencoding video [VID_00263] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.552 frames - Bitrate: 9.557 Kbs - [17:29:31] Reencoding: VID_00263, Pass 1 of 1 - [17:31:02] Video Encode complete - [17:31:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:31:02] Multiplexing M2TS - [17:31:09] Processing: VID_00264 (4 of 13) - [17:31:09] Extracting A/V streams [VID_00264] - [17:31:24] Reencoding video [VID_00264] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.929 frames - Bitrate: 9.645 Kbs - [17:31:24] Reencoding: VID_00264, Pass 1 of 1 - [17:32:31] Video Encode complete - [17:32:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:32:31] Multiplexing M2TS - [17:32:39] Processing: VID_00275 (5 of 13) - [17:32:39] Extracting A/V streams [VID_00275] - [17:32:55] Reencoding video [VID_00275] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.097 frames - Bitrate: 9.494 Kbs - [17:32:55] Reencoding: VID_00275, Pass 1 of 1 - [17:34:02] Video Encode complete - [17:34:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:34:02] Multiplexing M2TS - [17:34:08] Processing: VID_00276 (6 of 13) - [17:34:08] Extracting A/V streams [VID_00276] - [17:34:22] Reencoding video [VID_00276] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.120 frames - Bitrate: 8.816 Kbs - [17:34:22] Reencoding: VID_00276, Pass 1 of 1 - [17:35:22] Video Encode complete - [17:35:22] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:35:22] Multiplexing M2TS - [17:35:28] Processing: VID_00277 (7 of 13) - [17:35:28] Extracting A/V streams [VID_00277] - [17:35:43] Reencoding video [VID_00277] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.929 frames - Bitrate: 9.503 Kbs - [17:35:43] Reencoding: VID_00277, Pass 1 of 1 - [17:36:41] Video Encode complete - [17:36:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:36:41] Multiplexing M2TS - [17:36:47] Processing: VID_00285 (8 of 13) - [17:36:47] Extracting A/V streams [VID_00285] - [17:36:58] Reencoding video [VID_00285] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.993 frames - Bitrate: 9.493 Kbs - [17:36:58] Reencoding: VID_00285, Pass 1 of 1 - [17:37:39] Video Encode complete - [17:37:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:37:39] Multiplexing M2TS - [17:37:46] Processing: VID_00286 (9 of 13) - [17:37:46] Extracting A/V streams [VID_00286] - [17:38:16] Reencoding video [VID_00286] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5.545 frames - Bitrate: 14.688 Kbs - [17:38:16] Reencoding: VID_00286, Pass 1 of 1 - [17:40:29] Video Encode complete - [17:40:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:40:29] Multiplexing M2TS - [17:40:37] Processing: VID_00287 (10 of 13) - [17:40:37] Extracting A/V streams [VID_00287] - [17:41:41] Reencoding video [VID_00287] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 16.741 frames - Bitrate: 14.608 Kbs - [17:41:42] Reencoding: VID_00287, Pass 1 of 1 - [17:49:15] Video Encode complete - [17:49:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:49:15] Multiplexing M2TS - [17:49:33] Processing: VID_00288 (11 of 13) - [17:49:33] Extracting A/V streams [VID_00288] - [17:51:45] Reencoding video [VID_00288] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 35.926 frames - Bitrate: 14.609 Kbs - [17:51:45] Reencoding: VID_00288, Pass 1 of 1 - [18:06:53] Video Encode complete - [18:06:54] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:06:54] Multiplexing M2TS - [18:07:35] Processing: VID_00289 (12 of 13) - [18:07:35] Extracting A/V streams [VID_00289] - [18:09:04] Reencoding video [VID_00289] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 23.435 frames - Bitrate: 14.612 Kbs - [18:09:04] Reencoding: VID_00289, Pass 1 of 1 - [18:18:14] Video Encode complete - [18:18:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:18:14] Multiplexing M2TS - [18:18:35] Processing: VID_00330 (13 of 13) - [18:18:35] Extracting A/V streams [VID_00330] - [18:18:53] Reencoding video [VID_00330] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.386 frames - Bitrate: 9.317 Kbs - [18:18:53] Reencoding: VID_00330, Pass 1 of 1 - [18:20:11] Video Encode complete - [18:20:11] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:20:11] Multiplexing M2TS [18:20:18]PHASE ONE complete [18:20:18]PHASE TWO - Rebuild Started - [18:20:18] Rebuilding BD file Structure [18:21:22] - Encode and Rebuild complete [18:21:22] Writing BD structure to ISO file - ImgBurn completed successfully - UNDERWORLD_RISE_OF_THE_LYCANS folder removed. - WORKFILES folder removed. [18:34:59] JOB: UNDERWORLD_RISE_OF_THE_LYCANS finished. Code:
[Options] #video settings MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=0 OPEN_GOP=0 MOVIE_ONLY_LOOP=1 USE_FILTERS=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=1 SD_TO_1080=0 CONVERT_WIDE=0 MOVIEONLY_TYPE=0 ALTCRF=20 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 WIDE_PERCENT=40 WIDE_OFFSET=.85 RESIZE_1440=0 RESIZE_720=0 OUTPUT_3D=1 IGNORE_3D=0 NEROAAC=0 DGDECNV=1 USE_LAVF=0 #audio settings AUDIO_TO_KEEP=dut;eng;nld;und; DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 FULL_AVCHD=0 #subtitle settings SUBS_TO_KEEP=dut;eng;nld;und; #output settings REMOVE_WORKFILES=1 REMOVE_OUTPUT=1 REMOVE_IMPORT=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 PRIORITY_CLASS=1 TARGET_SIZE=23500 AUTO_BURN=2 QUICK_EXTRAS=0 #General Settings ENABLE_TEST=1 ENABLE_BLANKING=0 BLANK_THRESHOLD=60 MULTIPROCESS=0 MINIMIZE_TO_TRAY=1 SHUTDOWN_REBOOT=1 IMPORT_FOLDER=C:\TEMP VERBOSE_STATUS=1 BDMV_CERT_ONLY=1 AUTO_BLANK=0 UNMASK_CHAPTER=1 VERSION=0.50.0.1 COMPLETION_BEEP=1 BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav SD_PROGRESSIVE=1 MKV_CHAPTERS=1 SUPTITLE=0 OUTPUT_SBS=0 MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=1 MENU_START_WITH_MENU=1 OUTPUT_FOLDER=C:\Blu-Ray Rebuilds\BDRB\ FRIMSOURCE=0 ENCODER=0 DGDECIM=0 DECODER=3 [Paths] WORKING_PATH=C:\TEMP\LAVF\ SOURCE_PATH=Z:\BLU-RAY\DOUBLE LAYER\DTS-E\UNDERWORLD_RISE_OF_THE_LYCANS\ DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGDecodeNV.dll DirectShowMVCSource=C:\Program Files (x86)\BD_Rebuilder\Tools\MVCtoAVI.exe\DirectShowMVCSource.dll NeroAACPath=C:\Program Files (x86)\BD_Rebuilder\Tools\neroaacenc1.5.1\win32\neroAacEnc.exe The LAVF built iso came in at 19.0GB on the dot (19.927.488kb) The DGDC built iso came in at 20.9GB in size (21.919.936kb) a 2GB difference and still significant for both considering the default target size of 22.95GB. The DGDecNV built one was 2GB short of the target while the LAVF built one was a whopping 4GB smaller If you want me to run more tests, just lemme know |
