25th November 2011, 00:53 | #11424 | Link | |
Folks,
http://en.wikibooks.org/wiki/Eac3to/How_to_Use About DTS-HD Master Audio tracks, Quote:
How do I fix this? The software is already installed, but eac3to for some reason, can't detect the decoder. And here we have broken links: http://forum.doom9.org/showthread.ph...21#post1168721 P.S. I am not using a trial version from TMT.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." |
25th November 2011, 23:12 | #11425 | Link |
For Eac3to to use the arcsoft decoder you need the checkactivate.dll in the arcsoft folder. Rename the attachment checkactivate.txt to checkactivate.dll en copy this file to your arcsoft folder.
It should work now. Greets |
28th November 2011, 05:59 | #11426 | Link |
LPCM stream not being decoded to WAV correctly
The WAV file that eac3to produces is garbage. The sample file contains a pure sinewave test tone. Not so the output.
I've tried it with and without the -down16 option, but it didn't make a difference. Sample file: http://vidiot.com/MPEG-LPCM-sample.ts (67,108,864 bytes) Stream 1 is the MPEG-2 480i video stream, stream 2 is the MPEG stereo audio stream and stream 3 is the stereo LPCM audio stream. Any help as to what the right options are to get a usable WAV file will be appreciated. |
3rd December 2011, 02:31 | #11427 | Link |
Does anyone have Nero 7 decoders working on Win7x64, and if so, could you please provide working instructions?
Despite asking some time ago, and having someone post advice, it doesn't work. Trying to run Regsvr32 on AdvrCntr2.dll works fine; running it on NeAudio2.ax fails (regsvr32 hangs and then crashes); and running it on NeEacDec.dll fails, it reports it can't find an entry-point DllRegisterServer. I have installed a retail version of Nero7Ultra with retail BluRay/HDDVD plugin and no go. Many thanks The REAL Joe
Cheers, The REAL Joe |
3rd December 2011, 04:11 | #11428 | Link |
Telewhining
You might not have the right version of NeAudio2.ax - I remember having a similar issue until I found a slightly different version of Nero 7. The SFV checksum for mine is: AD81926E
And I don't think you need to register NeEacDec.dll, just the other two. |
3rd December 2011, 12:11 | #11429 | Link | |
The PCM track is not recognized by tsMuxeR. How do you make your sample? I make a test. 1) Decode the mp2 track to wav: eac3to MPEG-LPCM-sample.ts 2: test.wav -down16 2) Mux the test.wav to MPEG-LPCM-sample.ts like 2nd audio track (the original PCM 2nd audio track was ignored) 3) Extract the 2nd audio PCM track without problems: eac3to MPEG-LPCM-sample-new.ts 3: test-new.wav
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 3rd December 2011 at 12:16. |
6th December 2011, 11:55 | #11431 | Link |
- Dolby recommend not include LFE in downmix.
- To play on TV or low cost audio equipment not include LFE. - To play on a good hi-fi stereo, mix LFE at your risk. The arithmetic mix of LFE can produce artifacts, or not.
6th December 2011, 12:21 | #11432 | Link | ||
7th December 2011, 19:13 | #11434 | Link | ||
I did not installed this "patch" since the link is offline. Before all that, eac3to told me I didn't had anything from Arcsoft. I tried converting a 7.1 DTS-HD MA track, from the movie "The Sound of Music", just to check if everything was fine. It failed to convert, since Arcsoft is the only one that recognizes that number of channels, as explained here: Quote:
Please, I beg all of you! For God's sake, DO NOT POST HERE LINKS THAT REDIRECT US TO THE DEVELOPER'S WEBSITE, ALWAYS UPLOAD COPIES FROM SUCH FILES ELSEWHERE, AND NEVER A SINGLE COPY LIKE YOU DID IN THIS CASE! This is another copy from the "arcsoft_totalmediatheatre_engintro.exe", this time stored in multiple servers: http://migre.me/72ZKQ http://migre.me/72ZMi If you upload these things in a single server, sooner or later the file will be deleted for inactivity. If people do not download this thing, it will be deleted for sure. Megaupload is one of servers that does not delete files for that reason (despite what their FAQ says). As a result, my only alternative is to use a software like SUPER from eRIGHTSOFT to convert this...
7th December 2011, 20:30 | #11435 | Link |
I did it! I solved the whole thing!
Thanks to this thread: http://forum.doom9.org/showthread.php?t=139946 All I had to do was browse this folder (using DOS prompt - it won't work using the Start Menu): C:\Program Files\ArcSoft\TotalMedia Theatre\Codec\ Where the file ASAudioHD.ax is located. After that, all we have to do is execute that command: regsvr32 ASAudioHD.ax And then: For the record, I only did this after reinstalling the last TMT version, and after that, updating the old one from the RS/Migre links. It looks like this old version is incompatible with Windows 7, I couldn't make it work even using the compatibility mode.
8th December 2011, 19:36 | #11436 | Link | |
Also - and off topic for eac3to (sorry!), when watching a movie with 5.1 do audio processors (eg ffdshow or even Windows mixer) ignore the LFE when downmixing to 2.0? Last edited by iSeries; 8th December 2011 at 19:39. |
9th December 2011, 11:51 | #11437 | Link | ||
The problem is how the original LFE was created, not matter the downmix output format. Quote:
9th December 2011, 12:51 | #11438 | Link |
Another little bug in eac3to, in the hope someday the programmer, or a friend of it, restart the project.
This is the log: eac3to v3.24 command line: "C:\MasProgramas\eac3to\eac3to.exe" "G:\Sc\H1.mkv" 2:"C:\Temp\VideoSynch\Vsy_Tmp_Audio_1.ac3" -320 -25.000 -changeTo23.976 ------------------------------------------------------------------------------ MKV, 1 video track, 1 audio track, 1 subtitle track, 0:22:43, 25p 1: h264/AVC, 1080p24 /1.001 (16:9) 2: MP3, Spanish, 2.0 channels, 320kbps, 48kHz, 1500ms "Audio en Castellano" 3: Subtitle (ASS), Spanish, "Subtítulos para el audio Castellano" [v01] The video bitstream framerate field doesn't match the container framerate. <WARNING> [a02] Extracting audio track number 2... [a02] Decoding with libav/ffmpeg... [a02] Applying RAW/PCM delay... [a02] Encoding AC3 <320kbps> with libAften... [a02] Clipping detected, a 2nd pass will be necessary. <WARNING> [a02] Creating file "C:\Temp\VideoSynch\Vsy_Tmp_Audio_1.ac3"... [a02] Starting 2nd pass... [a02] Extracting audio track number 2... [a02] Decoding with libav/ffmpeg... [a02] Applying RAW/PCM delay... [a02] Encoding AC3 <320kbps> with libAften... [a02] Applying -0,21dB gain... [a02] Creating file "C:\Temp\VideoSynch\Vsy_Tmp_Audio_1.ac3"... Video track 1 contains 34071 frames. eac3to processing took 23 seconds. Done. You can see I am trying to convert a mp3 track from a mkv video from 25.000 to 23.976. But the video is a 23.976 avc1 encode, converted by the mkv container to a 25.000 play speed. Eac3to doesn't does the framerate conversion. The workaround is simple: extract and convert after. |
9th December 2011, 18:58 | #11439 | Link | |
For nero 7 the only files you need are ( advrcntr2.dll msvcp71.dll msvcr71.dll NeAudio2.ax NeEacDec.dll ) and the correct registry keys from your nero 7. Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead] [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation] [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation\Families] [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation\Families\Nero 7] [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation\Families\Nero 7\Info] "Company"="" "EulaAccepted"="x" "MissingFilesState"="0" "Serial7_xxxxxxxxxxxx"="xxxx-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx" "User"="" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation\Families\Plugins] [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead\Installation\Families\Plugins\Info] "Serial7_xxxxxxxxxxx"="*xxxx-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx" For surcode you need the ( surcodedvd.exe Tables folder and lservrc ) and correct registry keys for surcode. Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Minnetonka Audio Software] @="" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Minnetonka Audio Software\SurCode DVD-DTS] "Home"="C:\\(path to folder)\\Surcode DTS Encoder" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Minnetonka Audio Software\SurCode DVD-DTS\1.0.10] @="" For arcsoft you need ( ASAudioHD.ax checkactivate.dll DtsDec.dll dtsdecoderdll.dll MagCore.dll MagPCMac.dll MagUIEngine.dll MagUIInter.dll msvcp71.dll msvcr71.dll ). A copy of msvcp71.dll & msvcr71.dll are required in the same folder as nero 7, arcsoft & eac3to folder. I worked out how everything works and put a package together myself with all these files. Last edited by dream88; 9th December 2011 at 19:19. |
12th December 2011, 06:04 | #11440 | Link |
hi..there's a way to make it work eac3to with audio that have different channels? for example an ac3 or dts that have the start on 2.0 and the rest of 5.1? because eac3to recognise it as 2.0... and destroy the audio (3 times longer)... to pass ac3s to wav i use besweet that solve the problem but i don't know how to do with dts
eac3to |
